O-ring blocks and heads questions #1081233
09/24/11 12:13 AM
09/24/11 12:13 AM
Rock Springs
Bob_Coomer Offline OP
Rock Springs
What if a cylinder head has a O-ring receiver groove machined into the heads, and your not going that route. I know decking will take care of it, but what if you dont want to deck out the groove?
The block will not have the groove in this case. I dont see how it can effect the seal as long as the O-ring is inside or even out side the head gasket fire ring?
Re: O-ring blocks and heads questions [Re: Bob_Coomer] #1081234
09/24/11 12:31 AM
09/24/11 12:31 AM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Mine is used with a copper head gasket, I never thought about what to do if useing like a cometic or 1009 or anyother type. Good question. Seems it would have to be inline close to the fire ring tho, not sure. I will see if I can find a pic of my block for viewing for other guys posting. It may help
Re: O-ring blocks and heads questions [Re: Mopar-Al] #1081235
09/24/11 01:01 AM
09/24/11 01:01 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
When I assembled my 572 Keith Black I removed the o-ring wire from my set of Indy 440-1's and used a standard Felpro gasket.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: O-ring blocks and heads questions [Re: Bob_Coomer] #1081236
09/24/11 03:30 AM
09/24/11 03:30 AM
Been there done that more than once, go for it Make absolutely sure that the head gasket will seal up before the O ring groove, don't have the O ring groove in the combustion chamber area and cross over under the gasket
Re: O-ring blocks and heads questions [Re: Cab_Burge] #1081237
09/24/11 05:25 AM
09/24/11 05:25 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
You could always use copper wire in the O-ring groove. Then file the wire down flat.
Leon
Re: O-ring blocks and heads questions [Re: Leon441] #1081238
09/24/11 09:18 AM
09/24/11 09:18 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Leon
I've done that on the block before... never did a head
that way
