Lower Radiator Hose for Champion in Duster
#1080646
09/22/11 09:22 PM
09/22/11 09:22 PM
Posts: 1,018 Hazlet, NJ
440Satellite
super gas
super gas
Hazlet, NJ
Hey guys, I'm putting a 26" small block champion 3 core radiator in my 72 Duster with a 360 it has a right exiting water pump and right side lower hose conection on the radiator . Does anyone know what lower radiator hose will work with this setup. I bought a hose for a 74 Duster 360 (Dayco 70780) but it doesnt seem to be the right one. Anyone have a clue?
Butch
1972 Duster
318 4 speed
1958 392 Hemi engine
waiting to be built!!!!!
Re: Lower Radiator Hose for Champion in Duster
[Re: 440Satellite]
#1080647
09/22/11 09:57 PM
09/22/11 09:57 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Hmm, when I converted my 72 Swinger from /6 to 360 I used the stock type V8 radiator and lower hose without issue, so what is not right about yours?
[Re: Supercuda]
#1080648
09/23/11 06:35 AM
09/23/11 06:35 AM
440Satellite
super gas
super gas
Hazlet, NJ
Seems a little long, and you have to bend it to get it to work. I went from a 318 to 360 but the car originally was a /6 so I'm not sure what radiator was in it. I think the one that was on the 318 would work but I sold the motor with it on and am not sure what application it was from seeing as the car was not stock.
Butch
1972 Duster
318 4 speed
[Re: 440Satellite]
#1080649
09/23/11 09:32 AM
09/23/11 09:32 AM
Posts: 8,087 Elk Grove, Calif.
bigblock340power
Elk Grove, Calif.
Most hoses are not direct fit. Meaning, you sometimes have to trim them to fit. I found this to be the case more often than not. So mock it up, get a good idea of where you want it, and cut the part that's making it not fit off. Good luck.
