C body motor mount torque straps #1080500
09/22/11 06:08 PM
09/22/11 06:08 PM
minnarusta
TX9H6E4CUDA Offline OP
minnarusta
A buddy of mine was telling me about how big C body cars had some torque straps that held the motor mount together and kept the motor from shifting. Does anyone have a picture of this set up or of the straps themselves? Im going to a yard next weekend and I am going try and find a set to put into my car. Also what models and years of c bodies have you seen them in?
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
Re: C body motor mount torque straps [Re: TX9H6E4CUDA] #1080501
09/22/11 06:22 PM
09/22/11 06:22 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
I believe they were on police and taxi cars only. It shows it in the FSM I think, but I've never seen them in person.
Re: C body motor mount torque straps [Re: 440newport] #1080502
09/22/11 06:44 PM
09/22/11 06:44 PM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
I have something that may or may not be one , it was in my 69 Superbee when I bought it back from a freind that had put a 383 from a 69 Polara in it , it was neither a police car or a taxi though but I did also get a set of 15x6 H wheels off it also .
It's just a short piece of steel cable with 2 crimped on ends with some sort of spacer , it grabbed one engine ear bolt and the bolt thru the K frame ...
You are lucky that you can still go yarding and find 60's - 70's mopars , around here they crushed pretty much everything when steel was going overseas for big bucks
Re: C body motor mount torque straps [Re: JohnRR] #1080503
09/22/11 06:59 PM
09/22/11 06:59 PM
minnarusta
minnarusta
Yeah I am lucky, the yard I am going to has not crushed a car since the late 50's. It is a amazing place and they have cars stacked on top of other cars. Its starting to become a little overgrown and I am actually bringing my chain saw with to clear a path and to get to some cars. Ill have pics next weekend of this place.
Re: C body motor mount torque straps [Re: JohnRR] #1080504
09/22/11 08:37 PM
09/22/11 08:37 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
I found them on my '69 Newport vert when I pulled the engine. Runs from an upper mount boss to bottom. Oddly, my passenger side mount was broken.
Re: C body motor mount torque straps [Re: TX9H6E4CUDA] #1080505
09/22/11 09:37 PM
09/22/11 09:37 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I have a few somewhere also.Mine came out of some Imps I pulled motors from.Looks like a cable with 2 eyes.Rocky
Chrysler Firepower
Re: C body motor mount torque straps [Re: therocks] #1080506
09/22/11 09:57 PM
09/22/11 09:57 PM
minnarusta
minnarusta
Ok so was there only one for the drivers side or two for both sides?
Re: C body motor mount torque straps [Re: 440newport] #1080507
09/22/11 11:22 PM
09/22/11 11:22 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
my aug 68 69 383 4 BBL VIP has one on dr side... mine is exactly like the above pic! dan
Re: C body motor mount torque straps [Re: ph23vo] #1080508
09/23/11 07:59 AM
09/23/11 07:59 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
my 69 imperial had one just like the one in the pic, on the drivers side.
Re: C body motor mount torque straps [Re: 65rbdodge] #1080509
09/23/11 08:39 AM
09/23/11 08:39 AM
London, England
Gavin Offline
Gavin  Offline
London, England
Hmmmm.....simple and effective (assuming it is up to the job). I kinda like that....
Re: C body motor mount torque straps [Re: Gavin] #1080510
09/23/11 08:52 AM
09/23/11 08:52 AM
Westfield, MA
rbrogle Offline
super street
rbrogle  Offline
super street
Westfield, MA
Must have been a '69 thing because I parted a rough '69 300 convertible several years ago and it had that strap on the driver's side mount only. I saved it and plan on using it on either my current convertible or my '68 300 someday.
I have another friend in central Mass. that took one from a parted '69 C body and is currently using it on his '70 6 BBL. 'Cuda. Works like a charm and protects the fan shroud and shaker hood stuff. THey should have used it on all BB cars of that era.
Rob '70 Fury III 'vert (GT Clone)was 318 3 on the tree,now 440 automatic '68 300 2 Door HT vinyl/cloth bench '68 Newport Custom 4 Dr. HT, 383/2, FULLY LOADED! '68 New Yorker 4 Door HT, 440/Auto, loaded! 2004 Chrysler 300M Special daily driver
Re: C body motor mount torque straps [Re: TX9H6E4CUDA] #1080511
09/23/11 09:06 AM
09/23/11 09:06 AM
Would only be on the drivers side , the passenger mount is in compression when the engine is trying to spin itself .
They should have definitely installed that on all 4 speed cars at a minimum.
Re: C body motor mount torque straps [Re: JohnRR] #1080512
09/23/11 06:18 PM
09/23/11 06:18 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Kinda reminds me that I remember GM having a cable around the upper control arm bushing to the eng for the same reason as I used to see that on GM cars in the late 60's. Ron
Re: C body motor mount torque straps [Re: 383man] #1080513
09/23/11 07:35 PM
09/23/11 07:35 PM
Back in NJ....
E
EWJ Offline
EWJ  Offline
E
Back in NJ....
Might not be just a 1969 thing : The one I have came out of a 68 Newport 383/2bl/ 3-on-the-tree manual trans car I cut up.
Ed
EastCoast Land Yacht Assoc.
1967 Newport Conv: 440/4 speed
1969 GTX: 440/4 speed, TX9/TX9, A34, N96
1970 Super Bee: 383/4 speed, B5/B7
1970 Coronet RT: 440/4 speed, A34, N96
1970 Coronet RT: 440/auto, A36, N96
1970 Road Runner convertible: 383/4 speed TX9/D6XW
1970 GTX: 440+6/727, A32, N96
2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed
"The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: C body motor mount torque straps [Re: EWJ] #1080514
09/23/11 08:25 PM
09/23/11 08:25 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
have had a few of them,cleaned them up and resold, maybe we can get a nice sample and get them reproduced....i have 1 of the spacers...
Re: C body motor mount torque straps [Re: Joesixpack] #1080515
09/23/11 10:07 PM
09/23/11 10:07 PM
Grand Rapids, MI
11secondC Offline
11secondC  Offline
Grand Rapids, MI
Had one on my 2nd owner '67 VIP w/ 383 SuperCommando...
Re: C body motor mount torque straps [Re: 11secondC] #1080516
11/27/11 01:17 PM
11/27/11 01:17 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Does anyone have a length on these cables? Wondering how much slack if any they had.
Re: C body motor mount torque straps [Re: NTOLERANCE] #1080517
11/27/11 01:22 PM
11/27/11 01:22 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Re: C body motor mount torque straps [Re: NTOLERANCE] #1080518
11/27/11 05:19 PM
11/27/11 05:19 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
Approximately 7.5" OC.
Re: C body motor mount torque straps [Re: TX9H6E4CUDA] #1080519
11/27/11 05:41 PM
11/27/11 05:41 PM
Canada
CrAzYMoPaRGuY Offline
Canada
I bought a 1969 Chrysler station wagon years ago with a 383, it had the driver's side strap.
4bbl, high flow exhausts, 3.23 sure grip, and the gas cap said "premium fuel only".
CrAzYMoPaRGuY
