Page 1 of 3 1 2 3
Damaged Engine ? oil pump bronze gear etc #1080449
09/22/11 04:26 PM
09/22/11 04:26 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
I have just got the car running over the last couple weeks so there isn't a lot of time with the car.
The oil pressure was fine until about a day or 2.
The oil pressure is below 10 at idle and 35-40 at 4000 rpm.
(oil pressure guage is comp electrical guage)
Never had any experience chasingthis kind of problem and would love some advice
It has an external oil single line, deep pan.
The engine is a Mopar 500 inch crate engine I bought used. The engine is about 5-6 years old, Eddy heads Small hydralic roller cam.
I was thinking of just pulling the pan and seeing if there is any crap at the pickup? (easy to do with the modified oil k-frame)
(oil changed recently, had some dye in it to find some oil leaks)
What should I look for in the oil pump when I remove that?
Anything I should check. It is noisy for a hydralic cam.
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: Kam*Kuda] #1080450
09/22/11 04:29 PM
09/22/11 04:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Number one thing... check it with a mech gauge
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: MR_P_BODY] #1080451
09/22/11 04:44 PM
09/22/11 04:44 PM
ont,canada
mopartuner Offline
mopartuner  Offline
ont,canada
I have one here Rob
410 pump gas solis flat tappet cam 10.95 so far
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: mopartuner] #1080452
09/22/11 04:53 PM
09/22/11 04:53 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
not much in the pump to screw up. its easy to take off and look at. maybe try a different filter? could have a crack in the pick-up and sucking some air.
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: Kam*Kuda] #1080453
09/22/11 04:57 PM
09/22/11 04:57 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
are the lifter bores bushed? Too much lifter bore clearance is one culprit. Many original blocks have bores that are worn out and some are even oversize from the factory and had oversize lifters to "fix" it. What type of rocker gear is on it?
MB
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: HPMike] #1080454
09/22/11 05:23 PM
09/22/11 05:23 PM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
I know it sounds too simple but I have had the screw that hold the relief spring in the pump back out.
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: mac56] #1080455
09/22/11 05:40 PM
09/22/11 05:40 PM
Mid Missouri
E
ETASPEN Offline
ETASPEN  Offline
E
Mid Missouri
Buddy had one come all the way out during a pass...I don't have to tell you the rest of the story.
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: mac56] #1080456
09/22/11 05:48 PM
09/22/11 05:48 PM
Washington State
lorenr Offline
lorenr  Offline
Washington State
I've seen this with full grove engine bearings. Excessive oil clearance on the rod and main bearings as well as the lifter bores will also do it.
Roller lifters can also expose oil grooves to the rockers.
Light weight engine oils sometimes reduce pressure, but also increase volume. I often see synthetics that I swear won't develop much oil pressure. Volume is better than pressure. New cars don't have oil pressure gauges because if the buyer knew what the oil pressure really was with 20 weight synthetic they would demand a new motor.
30 to 40 pounds is fine. 10 pounds at idle is low, but also fine. However check it with a known mechanical gauge to be sure.
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: lorenr] #1080457
09/22/11 05:54 PM
09/22/11 05:54 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Dont make the same mistake as i did with my Hemi a few years back (some of you know) Re check with atleast TWO (2) other gauges.
second check the pickup
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: MR_P_BODY] #1080458
09/22/11 06:04 PM
09/22/11 06:04 PM
Toronto
mshred Offline
mshred  Offline
Toronto
after having the opposite issues of you, this is the first thing I would do...don't go crazy pulling your pan and such if its just a gauge issue
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: mshred] #1080459
09/22/11 07:13 PM
09/22/11 07:13 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Does it have a Fram filter on it? If the gauge checks out change the filter to a Wix (napa gold) and if the pressure is still low cut the old filter to check for shrapnel. Check the relief valve as was posted above. The spring could be broke or the valve stuck in its bore. Easy to check.
Kevin
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: HPMike] #1080460
09/22/11 09:42 PM
09/22/11 09:42 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
Crane gold rockers and I and crane hydralic roller lifters
Thanks Bob I will come down to borrow it
1654.5 Mustang
1955 Land Rover
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: Kam*Kuda] #1080461
09/22/11 09:47 PM
09/22/11 09:47 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Any raw gas in your oil??
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: Kam*Kuda] #1080462
09/22/11 10:07 PM
09/22/11 10:07 PM
it sounds like the bypass valve in the oil pump is stuck partially open especailly when it was good one day and bad the next time you used it Let us know what you find
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: Cab_Burge] #1080463
09/23/11 01:05 AM
09/23/11 01:05 AM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
I found a mechanical oil pressure guage at the house and installed it but it was too late to start the car
If the pressure is the same I will
1. Check the pressure relief in the pump
2. Change the oil and filter (It was a fram filter and synthetic oil) I will check with our Napa
3. Check for any fuel in the oil (it is an EFI engine with 83 lb injectors wheer 36 lb would probably do, but I will be procharging it and need those injectors in the future)
Anything else?
1654.5 Mustang
1955 Land Rover
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: Kam*Kuda] #1080464
09/23/11 10:37 AM
09/23/11 10:37 AM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Rob..hope you get your oil pressure problem solved..with an EASY FIX! Sure missed ya' at Norwalk! Had a GREAT time,as usual!...and Doc had a GREAT run going on Saturday night,which I'm sure you've heard already! Good Luck..and let us know what you find!
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: Kam*Kuda] #1080465
09/23/11 07:16 PM
09/23/11 07:16 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
Well I hope there is an easy answer but here is what I have done.
Checked with a mechanical gauge, still 10 lbs at idle.
I removed the plug and spring for the pressure relief (Milodon Single line - new) to static pickup
I could not see the valve . I could not feel it with my little finger.
I changed the oil to Brad Penn 20W50 and a Napa Gold filter.
I started it and now have 0 (zero) oil pressure.
Note The line from the oil pump to the pan is very short (only a few inches)
1654.5 Mustang
1955 Land Rover
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: Kam*Kuda] #1080466
09/23/11 07:20 PM
09/23/11 07:20 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
To get at the oil pump will be a pain so it there is anything I can do before removing the pump... would love to hear it
Engine Plate
Mid Plate and transshield,
Engine lower one inch and back 1 inch
Hard to raise the engine
1654.5 Mustang
1955 Land Rover
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: Kam*Kuda] #1080467
09/23/11 07:21 PM
09/23/11 07:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Pull the dist and intermediate shaft and use a priming rod
and see what happens(no more start up's till you figure it out
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: Kam*Kuda] #1080468
09/23/11 08:15 PM
09/23/11 08:15 PM
Two things, the oil pump must have a bypass spring and check valve in it to work You can add shims between the spring and the cup that the spring sits in to up the pressure , be careful though, not to much It is NOT UNCOMMON for the Milidon external oiling systems to loose the prime when you open the system, IE remove the check valve plug or oil lines, even changing the oil and filter can cause the loss of prime some times Let us know what you find, like Raff has suggested try priming it before starting it again
Page 1 of 3 1 2 3
