Page 2 of 5 1 2 3 4 5
Re: Having issues with my EZ EFI [Re: Burkenator] #1080170
09/25/11 10:25 AM
09/25/11 10:25 AM
Dalton, MA
Slipknot440 Offline OP
Dalton, MA
let me know how it goes. I'm so frustrated right now I'm thinking of selling the car after 26 years
Re: Having issues with my EZ EFI [Re: Slipknot440] #1080171
09/25/11 01:27 PM
09/25/11 01:27 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
I've never considered selling a car because of a carburator
Re: Having issues with my EZ EFI [Re: forphorty] #1080172
09/25/11 03:10 PM
09/25/11 03:10 PM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
From everything I have read the majority of the problems with these systems relate to power and ground issues. I would go back and confirm the basics first. Power and ground direct from the battery for both the computer and the handheld. Good chassis to motor ground. Good solid connections.
Scott 1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed) 2002 Dodge Ram 1500 Quad Cab 1976 Corvette
Re: Having issues with my EZ EFI [Re: finadk] #1080173
09/25/11 05:51 PM
09/25/11 05:51 PM
Dalton, MA
Dalton, MA
looks like it may be something with the fuel delivery. Everything else seems in order but I spent 30 mins trying to get the thing to start and it just wouldn't turn over. I put 5 extra gallons of gas in (10 total) and jacked up the rear so it was nose down and got it to start. It ran like crap and felt like it was struggling to stay running. If i held the idle at 1200-1300 rpms it would stay running. Letting it just idle by it's self it would run down to 600 sound like it was going to die then run it's self back up to 1100 for a few seconds before it went through the cycle of winding down then up. Maybe the fuel filters are clogged up?
Re: Having issues with my EZ EFI [Re: Slipknot440] #1080174
09/25/11 07:49 PM
09/25/11 07:49 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
you really need to start from scratch - and look at how it was installed.
Go over every nut and bolt of the installation.
Read the directions over and over till it's understood.
( you are complaining about cold starts - well they take the longest to learn ) you need to get it running warm and then the cold starts take care of themselvs
What fuel system are you using? how are you getting fuel to the tank?
what size if the supply AND return lines
are your efi boxes near the ignition at all?
what coil? if stock did you ground the noise filter correctly?
power? direct to battery?
I had mine on over a year and a half - I had a few bugs to work out in the beginning but it has been running strong for over a year and a half now with no issues
Re: Having issues with my EZ EFI [Re: DJVCuda] #1080175
09/25/11 08:49 PM
09/25/11 08:49 PM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
where is the power hooked up at? numerous guys have asked and you refuse to answer this simple question for some reason...
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: Having issues with my EZ EFI [Re: abodyjoe] #1080176
09/25/11 10:52 PM
09/25/11 10:52 PM
Dalton, MA
Dalton, MA
power is directly to battery and so is negative. 3/8 lines. Computer is mounted just above the high beam switch on the floor. I've gone over all connections and grounds 2 or 3 times. The coil is an MSD masterblaster2, and it is was wired correctly. I had the unit professionally installed to make sure that I didn't screw anything up. At this point I'm thinking of taking off the fuel pump to check the filters and check the filter in the tank to make sure it's not gummed up
Re: Having issues with my EZ EFI [Re: Slipknot440] #1080177
09/26/11 12:28 PM
09/26/11 12:28 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
What about your 12V key on source????!!!!! This is one of, if not the most important connection on the system.
If your fuel system is having issues it would be as simple as noticing a serious fuel pressure fluctuation at NO load or under load. We lost a fuel pump early on in our first build and it simply would not run past idle....no backfires or erratic idles....just would not run.
1968 Pro-Touring Dodge Charger
*2011 Optima Ultimate Street Car Challenge Invitee
http://www.popularhotrodding.com/features/1203phr_1968_dodge_charger/index.html
Re: Having issues with my EZ EFI [Re: Viol8r] #1080178
09/26/11 01:35 PM
09/26/11 01:35 PM
So. Cal. For Now But Texas Bou...
69sixpackbee Offline
I had the EZ on my BBC in my Chevy truck. It ran decent but was never stellar. I did put it in with a lot of fore thought as I am no novice with EFI systems. After some tuning and driving it got better but I eventually went back to the carb and HEI. Simple is best.
Take heed to everyone's suggestions here as we have "been here and done that"
You will get it sorted out. But, comparing apples to oranges, simplicity will always win me over. Just my $.02
The EZ-EFI is a good system but my next iteration will be a mill and the associated OEM components that work in unison. Enough of the "bolt on" trial and tribulations crap for me.
Good luck,
Bud
Re: Having issues with my EZ EFI [Re: Viol8r] #1080179
09/26/11 05:44 PM
09/26/11 05:44 PM
Dalton, MA
Dalton, MA
since i didn't wire I'm assuming it's keyed directly to the ignition when I turn my key. The guy who did followed the instructions to the letter
Re: Having issues with my EZ EFI [Re: 69sixpackbee] #1080180
09/26/11 05:45 PM
09/26/11 05:45 PM
IL
furious70 Offline
furious70  Offline
IL
If you suspect the pump, hook up your battery charger to the car, unhook the return at the tank and put it in a 5 gal can and see how much it will pump in 1 minute. Make sure your battery charger is putting 14v to the battery and that you're getting 13.5v (or at least the same amt of volts you get with the car running) to the pump itself and give it a test.
I ruined my first efi pump quickly cuz of crap in the tank that got stirred up and I neglected to replace the first piece of rubber hose out of the pickup. Packed the pump full of rubber bits.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Having issues with my EZ EFI [Re: Slipknot440] #1080181
09/27/11 08:22 AM
09/27/11 08:22 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
that didnt work for me - if it in fact is in the fuse box.
it needs to be a direct lead from the battery, via switch or relay -
when you tie the key power into the stock wiring harness, it introduces noise from the ignition system and will never run right,
there is a reading you can get for the interference on the system, its on the 4th page - i dont have it in front of me but look into that reading it will tell you if its a wiring issue.
Re: Having issues with my EZ EFI [Re: DJVCuda] #1080182
09/28/11 02:38 PM
09/28/11 02:38 PM
Dalton, MA
Dalton, MA
keyed directly to the ignition switch, and I'm not getting any error codes. I took pics of my computer at 1400 rpms and a few just at idle, 800 rpms (but set to 900). First 4 pics are at 1400 next for at at 800. do my numbers look normal?
Re: Having issues with my EZ EFI [Re: Slipknot440] #1080183
09/28/11 02:39 PM
09/28/11 02:39 PM
Dalton, MA
Dalton, MA
2
Re: Having issues with my EZ EFI [Re: Slipknot440] #1080184
09/28/11 02:40 PM
09/28/11 02:40 PM
Dalton, MA
Dalton, MA
3
Re: Having issues with my EZ EFI [Re: Slipknot440] #1080185
09/28/11 02:41 PM
09/28/11 02:41 PM
Dalton, MA
Dalton, MA
Re: Having issues with my EZ EFI [Re: Slipknot440] #1080186
09/28/11 02:43 PM
09/28/11 02:43 PM
Dalton, MA
Dalton, MA
800 rpm 1
Re: Having issues with my EZ EFI [Re: Slipknot440] #1080187
09/28/11 02:46 PM
09/28/11 02:46 PM
Dalton, MA
Dalton, MA
2..
Re: Having issues with my EZ EFI [Re: Slipknot440] #1080188
09/28/11 02:47 PM
09/28/11 02:47 PM
Dalton, MA
Dalton, MA
3..
Re: Having issues with my EZ EFI [Re: Slipknot440] #1080189
09/28/11 02:48 PM
09/28/11 02:48 PM
Dalton, MA
Dalton, MA
4..
