This can't be right (can it?) #1079946
09/21/11 05:54 PM
09/21/11 05:54 PM
BROOK PARK, OH
WILD BILL Offline OP
BROOK PARK, OH
I'm using Wallace Racing Calculator to determine my Conv slip %
Using 132.66 mph/7000 Rpm at the line/ 4:56 gear ratio/ and the advertised roll out of my tires as 97"
I came up with 17.511 %
I tried varying the rpm and tire size a little figuring I might be going a little under what I think I see on the tack or thinking I might have to acct for tire growth but it still comes in as what I think is a way high slip percentage.
For some reason I was expecting somewhere around a 5 or 6 % number.
Can this be right?
Re: This can't be right (can it?) [Re: WILD BILL] #1079947
09/21/11 05:59 PM
09/21/11 05:59 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
That would put you around 1150 horse adjusted ! Not far off.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: This can't be right (can it?) [Re: WILD BILL] #1079948
09/21/11 06:02 PM
09/21/11 06:02 PM
Alberta Canada
StrokerAspen Offline
Alberta Canada
HM.... I come up with 6.5% slip... I am using a diameter of 31" is this correct?
-Kenny
Re: This can't be right (can it?) [Re: StrokerAspen] #1079949
09/21/11 06:08 PM
09/21/11 06:08 PM
BROOK PARK, OH
BROOK PARK, OH
Yes, they are 31's but why are you using the diameter?
The calulator I see wants MPH, RPM, Gear, & CIRCUMFERENCE (inches}
Re: This can't be right (can it?) [Re: WILD BILL] #1079950
09/21/11 06:11 PM
09/21/11 06:11 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
I used the numbers you supplied and came up with 5.962%
Russ
Re: This can't be right (can it?) [Re: WILD BILL] #1079951
09/21/11 06:13 PM
09/21/11 06:13 PM
Alberta Canada
Alberta Canada
The calculator I am using works off diameter. Basically the calculator I am using takes the diameter, and uses the circumference based on the diameter.
31" X 3.1416 = 97.3896"
I have used this calculator to calculated quite a few cars and it has worked for me. I have had good luck with the Wallace stuff too though.
Re: This can't be right (can it?) [Re: max_maniac] #1079952
09/21/11 06:34 PM
09/21/11 06:34 PM
NC
440Jim Offline
440Jim  Offline
NC
Russ
I came up with the same thing using the Wallace Calculator
http://www.wallaceracing.com/converter-slip.php
Re: This can't be right (can it?) [Re: WILD BILL] #1079953
09/21/11 06:36 PM
09/21/11 06:36 PM
NC
440Jim Offline
440Jim  Offline
NC
You are inputing gear ratio with a colon (4:56) instead of the proper way which is a decimal (4.56)
Re: This can't be right (can it?) [Re: StrokerAspen] #1079954
09/21/11 06:41 PM
09/21/11 06:41 PM
BROOK PARK, OH
BROOK PARK, OH
Now I see what I was doing wrong
I was typing in 4:56 instead of 4.56 and that's what gave me the high slip.
Once I put in 4.56 I got 5.962 %
However, that said, I was starting to think that with the high slip that I was leaving some ET on the table and that a tighter conv would help get it to where it seems everyone thinks it should be running.
Now, I don't know what to think.
How do you know if you have the right (best) conv for your car?
Re: This can't be right (can it?) [Re: WILD BILL] #1079955
09/21/11 06:49 PM
09/21/11 06:49 PM
Alberta Canada
Alberta Canada
I would say 6% isn't too bad. What size is the converter? if it is an 8", maybe you could get a 9" converter built that will still get you off the mark the same.
I would say everything is working well. There is a little simple math problem that gives you an idea.
1320/MPH = Optimum ET.
1320/132.5 = 9.962
An exapmle of one that ISN'T working to its full potential is My car But that's to be expected with a big loose converter and 3.23 gears.
1320/128 = 10.313..... I have gone 10.68.
Is it a scientific math formula? No, I think it's a fluke that it works. haha. OR maybe it is and I don't know why it works. But it does.
-Kenny
Re: This can't be right (can it?) [Re: WILD BILL] #1079956
09/21/11 06:49 PM
09/21/11 06:49 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Yep as you know you were doing it wrong. Your slip will be just abit higher then that because of tire growth. MT tires will grow about 1" according to MT.
IMO, you your vert is ideal when the 60 fts are inline with the MPH for its ET.
But theres more to it then that. Some verts will have more torque multiplication then others. Most of the Good names should be in the same range of multiplication IMO. But maybe not. Congrats on your 9,s.
Re: This can't be right (can it?) [Re: Sport440] #1079957
09/21/11 07:02 PM
09/21/11 07:02 PM
BROOK PARK, OH
BROOK PARK, OH
Calculated 60' for that pass was 1.383467
Actual 60' was 1.361
Re: This can't be right (can it?) [Re: WILD BILL] #1079958
09/21/11 08:31 PM
09/21/11 08:31 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
well for me it says I got 8.14% slip. But that 1320/120 says 11.00 we run allot of 11.0s
Re: This can't be right (can it?) [Re: VernMotor] #1079959
09/21/11 10:06 PM
09/21/11 10:06 PM
Guitar Jones Offline
It's all math...and physics, math and physics. Why didn't I pay more attention in school...
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: This can't be right (can it?) [Re: Guitar Jones] #1079960
09/21/11 10:32 PM
09/21/11 10:32 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I've seen a few of your recent posts Guitar Jones and wonder if we're brothers
I'm going to run mine now & try the "Stroker Aspen Math"
Congrats on that 9 Bill
Re: This can't be right (can it?) [Re: roadhazard] #1079961
09/21/11 11:13 PM
09/21/11 11:13 PM
BROOK PARK, OH
BROOK PARK, OH
No need to insult the guy Greg
And thanks
Re: This can't be right (can it?) [Re: WILD BILL] #1079962
09/22/11 12:10 AM
09/22/11 12:10 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
That 1.361 60 ft. is inline with your et IMO Your MPH is just a touch low, but well withen normal perimeters for your et.
My summary, your 60 ft. and ET and vert slip is well within range. Your MPH is close to optimum too.
Re: This can't be right (can it?) [Re: Sport440] #1079963
09/22/11 12:20 AM
09/22/11 12:20 AM
BROOK PARK, OH
BROOK PARK, OH
Doesn't sound like I'll be able to squeeze much more out of it then
On the other hand, that also means I can just put it away for the winter and NOT have to on it
Re: This can't be right (can it?) [Re: WILD BILL] #1079964
09/22/11 12:24 AM
09/22/11 12:24 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Have you tried anything on the tune up Bill... its
real close for the HP to weight(at that given time)
Re: This can't be right (can it?) [Re: MR_P_BODY] #1079965
09/22/11 12:42 AM
09/22/11 12:42 AM
BROOK PARK, OH
BROOK PARK, OH
Aside from jetting it up a bit no.
I was planning on going a little more on the jetting next year to see if I could get the MPH to fall off but that's it.
