This can't be right (can it?)
#1079946
09/21/11 05:54 PM
09/21/11 05:54 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I'm using Wallace Racing Calculator to determine my Conv slip %
Using 132.66 mph/7000 Rpm at the line/ 4:56 gear ratio/ and the advertised roll out of my tires as 97"
I came up with 17.511 %
I tried varying the rpm and tire size a little figuring I might be going a little under what I think I see on the tack or thinking I might have to acct for tire growth but it still comes in as what I think is a way high slip percentage.
For some reason I was expecting somewhere around a 5 or 6 % number.
Can this be right?
Re: This can't be right (can it?)
[Re: StrokerAspen]
#1079949
09/21/11 06:08 PM
09/21/11 06:08 PM
WILD BILL
BROOK PARK, OH
Yes, they are 31's but why are you using the diameter?
The calulator I see wants MPH, RPM, Gear, & CIRCUMFERENCE (inches}
[Re: WILD BILL]
#1079951
09/21/11 06:13 PM
09/21/11 06:13 PM
Posts: 1,600 Alberta Canada
StrokerAspen
Alberta Canada
The calculator I am using works off diameter. Basically the calculator I am using takes the diameter, and uses the circumference based on the diameter.
31" X 3.1416 = 97.3896"
I have used this calculator to calculated quite a few cars and it has worked for me. I have had good luck with the Wallace stuff too though.
[Re: WILD BILL]
#1079953
09/21/11 06:36 PM
09/21/11 06:36 PM
Posts: 16,925 NC
440Jim
NC
You are inputing gear ratio with a colon (4:56) instead of the proper way which is a decimal (4.56)
[Re: StrokerAspen]
#1079954
09/21/11 06:41 PM
09/21/11 06:41 PM
WILD BILL
BROOK PARK, OH
Now I see what I was doing wrong
I was typing in 4:56 instead of 4.56 and that's what gave me the high slip.
Once I put in 4.56 I got 5.962 %
However, that said, I was starting to think that with the high slip that I was leaving some ET on the table and that a tighter conv would help get it to where it seems everyone thinks it should be running.
Now, I don't know what to think.
How do you know if you have the right (best) conv for your car?
[Re: WILD BILL]
#1079955
09/21/11 06:49 PM
09/21/11 06:49 PM
StrokerAspen
Alberta Canada
I would say 6% isn't too bad. What size is the converter? if it is an 8", maybe you could get a 9" converter built that will still get you off the mark the same. I would say everything is working well. There is a little simple math problem that gives you an idea. 1320/MPH = Optimum ET. 1320/132.5 = 9.962 An exapmle of one that ISN'T working to its full potential is My car But that's to be expected with a big loose converter and 3.23 gears. 1320/128 = 10.313..... I have gone 10.68. Is it a scientific math formula? No, I think it's a fluke that it works. haha. OR maybe it is and I don't know why it works. But it does. -Kenny
[Re: Sport440]
#1079957
09/21/11 07:02 PM
09/21/11 07:02 PM
WILD BILL
BROOK PARK, OH
Calculated 60' for that pass was 1.383467
Actual 60' was 1.361
[Re: VernMotor]
#1079959
09/21/11 10:06 PM
09/21/11 10:06 PM
Guitar Jones
It's all math...and physics, math and physics. Why didn't I pay more attention in school...
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: roadhazard]
#1079961
09/21/11 11:13 PM
09/21/11 11:13 PM
WILD BILL
BROOK PARK, OH
I've seen a few of your recent posts Guitar Jones and wonder if we're brothers
No need to insult the guy Greg
And thanks
[Re: Sport440]
#1079963
09/22/11 12:20 AM
09/22/11 12:20 AM
WILD BILL
BROOK PARK, OH
Doesn't sound like I'll be able to squeeze much more out of it then
On the other hand, that also means I can just put it away for the winter and NOT have to on it
[Re: WILD BILL]
#1079964
09/22/11 12:24 AM
09/22/11 12:24 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Have you tried anything on the tune up Bill... its real close for the HP to weight(at that given time)
