This can't be right (can it?)
#1079946
09/21/11 05:54 PM
09/21/11 05:54 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I'm using Wallace Racing Calculator to determine my Conv slip %
Using 132.66 mph/7000 Rpm at the line/ 4:56 gear ratio/ and the advertised roll out of my tires as 97"
I came up with 17.511 %
I tried varying the rpm and tire size a little figuring I might be going a little under what I think I see on the tack or thinking I might have to acct for tire growth but it still comes in as what I think is a way high slip percentage.
For some reason I was expecting somewhere around a 5 or 6 % number.
Can this be right?
Re: This can't be right (can it?)
[Re: StrokerAspen]
#1079949
09/21/11 06:08 PM
09/21/11 06:08 PM
WILD BILL
BROOK PARK, OH
Yes, they are 31's but why are you using the diameter?
The calulator I see wants MPH, RPM, Gear, & CIRCUMFERENCE (inches}
[Re: WILD BILL]
#1079951
09/21/11 06:13 PM
09/21/11 06:13 PM
Posts: 1,600 Alberta Canada
StrokerAspen
Alberta Canada
The calculator I am using works off diameter. Basically the calculator I am using takes the diameter, and uses the circumference based on the diameter.
31" X 3.1416 = 97.3896"
I have used this calculator to calculated quite a few cars and it has worked for me. I have had good luck with the Wallace stuff too though.
[Re: WILD BILL]
#1079953
09/21/11 06:36 PM
09/21/11 06:36 PM
Posts: 16,930 NC
440Jim
NC
You are inputing gear ratio with a colon (4:56) instead of the proper way which is a decimal (4.56)
[Re: StrokerAspen]
#1079954
09/21/11 06:41 PM
09/21/11 06:41 PM
WILD BILL
BROOK PARK, OH
Now I see what I was doing wrong
I was typing in 4:56 instead of 4.56 and that's what gave me the high slip.
Once I put in 4.56 I got 5.962 %
However, that said, I was starting to think that with the high slip that I was leaving some ET on the table and that a tighter conv would help get it to where it seems everyone thinks it should be running.
Now, I don't know what to think.
How do you know if you have the right (best) conv for your car?
[Re: WILD BILL]
#1079955
09/21/11 06:49 PM
09/21/11 06:49 PM
StrokerAspen
Alberta Canada
I would say 6% isn't too bad. What size is the converter? if it is an 8", maybe you could get a 9" converter built that will still get you off the mark the same. I would say everything is working well. There is a little simple math problem that gives you an idea. 1320/MPH = Optimum ET. 1320/132.5 = 9.962 An exapmle of one that ISN'T working to its full potential is My car But that's to be expected with a big loose converter and 3.23 gears. 1320/128 = 10.313..... I have gone 10.68. Is it a scientific math formula? No, I think it's a fluke that it works. haha. OR maybe it is and I don't know why it works. But it does. -Kenny
[Re: Sport440]
#1079957
09/21/11 07:02 PM
09/21/11 07:02 PM
WILD BILL
BROOK PARK, OH
Calculated 60' for that pass was 1.383467
Actual 60' was 1.361
[Re: VernMotor]
#1079959
09/21/11 10:06 PM
09/21/11 10:06 PM
Posts: 20,662 in a cattle trailer down by th...
Guitar Jones
It's all math...and physics, math and physics. Why didn't I pay more attention in school...
[Re: roadhazard]
#1079961
09/21/11 11:13 PM
09/21/11 11:13 PM
WILD BILL
BROOK PARK, OH
I've seen a few of your recent posts Guitar Jones and wonder if we're brothers
No need to insult the guy Greg
And thanks
[Re: Sport440]
#1079963
09/22/11 12:20 AM
09/22/11 12:20 AM
WILD BILL
BROOK PARK, OH
Doesn't sound like I'll be able to squeeze much more out of it then
On the other hand, that also means I can just put it away for the winter and NOT have to on it
[Re: WILD BILL]
#1079964
09/22/11 12:24 AM
09/22/11 12:24 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Have you tried anything on the tune up Bill... its real close for the HP to weight(at that given time)
