Best header for Volare with 440 #1079836
09/21/11 02:18 PM
09/21/11 02:18 PM
Mansfield, Ohio
GenoVol Offline OP
GenoVol  Offline OP
Mansfield, Ohio
I have recently swapped a 440 in my 1980 Volare and was hoping someone can tell me what brand of header will fit without major dents to the pipes. I tried a used set of Hooker Super Comps.and they hit passenger side inner fender well and on the drivers side the rear pipe would have to be beat halfway closed to clear the steering coupler.If anyone here has made this swap what header did you use? Thank you.
Re: Best header for Volare with 440 [Re: GenoVol] #1079837
09/21/11 02:59 PM
09/21/11 02:59 PM
ill
dennismopar73 Offline
ill
there really none, the ones i used where b body bb headers i had to move 2 tubes on drivers side, passenger side worked real well
Re: Best header for Volare with 440 [Re: GenoVol] #1079838
09/21/11 03:12 PM
09/21/11 03:12 PM
AndyF Offline
AndyF  Offline
Call TTi to see if they have any suggestions. I don't know of a header made for that application but the guys at TTi might have an idea if anything exists.
Re: Best header for Volare with 440 [Re: AndyF] #1079839
09/21/11 03:26 PM
09/21/11 03:26 PM
Mansfield, Ohio
GenoVol Offline OP
GenoVol  Offline OP
Mansfield, Ohio
I checked with TTI and they didn't have any suggestions either. Thanx for the reply.
Re: Best header for Volare with 440 [Re: dennismopar73] #1079840
09/21/11 03:31 PM
09/21/11 03:31 PM
Mansfield, Ohio
GenoVol Offline OP
GenoVol  Offline OP
Mansfield, Ohio
I was hoping for a easier fix but I'll keep that option in mind. Thanx for your reply
Re: Best header for Volare with 440 [Re: GenoVol] #1079841
09/21/11 07:26 PM
09/21/11 07:26 PM
Columbus, OH
redruM Offline
redruM  Offline
Columbus, OH
2" tti b body headers on my volare fit with no issues with a rb
Re: Best header for Volare with 440 [Re: GenoVol] #1079842
09/21/11 09:01 PM
09/21/11 09:01 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Mopar Action did an article on this years ago. They used B body headers, don't remember the brand. They put an extra joint in the steering shaft.
Re: Best header for Volare with 440 [Re: forphorty] #1079843
09/21/11 09:11 PM
09/21/11 09:11 PM
Columbus, OH
redruM Offline
redruM  Offline
Columbus, OH
I welded a tube on mine to extend the shaft for a non ps gearbox I put on, so that wasn't an issue for me.
Re: Best header for Volare with 440 [Re: forphorty] #1079844
09/22/11 02:00 AM
09/22/11 02:00 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Hooker "competition" headers...... NOT "super competition headers". B body. I used the "super comps" on my Mirada and it tooks some work.
Re: Best header for Volare with 440 [Re: forphorty] #1079845
09/22/11 02:55 PM
09/22/11 02:55 PM
Mansfield, Ohio
GenoVol Offline OP
GenoVol  Offline OP
Mansfield, Ohio
Thank you for the help.
Re: Best header for Volare with 440 [Re: J_BODY] #1079846
09/22/11 03:01 PM
09/22/11 03:01 PM
Mansfield, Ohio
GenoVol Offline OP
GenoVol  Offline OP
Mansfield, Ohio
Thanks for the tip, didn't think about Hooker "Comps"
Re: Best header for Volare with 440 [Re: GenoVol] #1079847
09/22/11 07:30 PM
09/22/11 07:30 PM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
We just installed a pair of Hooker 1 7/8s A Body fenderwell headers.Once you get back part of the inner fenderwell cut they fit and take no time to install.
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: Best header for Volare with 440 [Re: slippery440] #1079848
09/22/11 10:52 PM
09/22/11 10:52 PM
Salisbury North Carolina
8secDart Offline
8secDart  Offline
2in A-body from TTI.Fit better in the F-body then an A-body,LOL
Re: Best header for Volare with 440 [Re: 8secDart] #1079849
09/23/11 11:34 PM
09/23/11 11:34 PM
Mansfield, Ohio
GenoVol Offline OP
GenoVol  Offline OP
Mansfield, Ohio
Is that with a RB engine in the Volare ? Thanks
Re: Best header for Volare with 440 [Re: GenoVol] #1079850
09/24/11 12:23 AM
09/24/11 12:23 AM
gtx69 Offline
super gas
gtx69  Offline
super gas
A 440 is a RB engine
Re: Best header for Volare with 440 [Re: gtx69] #1079851
09/24/11 01:29 AM
09/24/11 01:29 AM
8secDart Offline
8secDart  Offline
I have done both.Low deck with Indy heads and 440 with stock heads.I see no problem with any combo.
Re: Best header for Volare with 440 [Re: 8secDart] #1079852
09/24/11 03:47 PM
09/24/11 03:47 PM
Mansfield, Ohio
GenoVol Offline OP
GenoVol  Offline OP
Mansfield, Ohio
Thanks to all for the replies, you've been very helpful.
Re: Best header for Volare with 440 [Re: slippery440] #1079853
09/25/11 08:50 PM
09/25/11 08:50 PM
Mansfield, Ohio
GenoVol Offline OP
GenoVol  Offline OP
Mansfield, Ohio
Do you have any pics of the areas that need to be cut? Thanks in advance.
