67 gtx rocker moldings installation ?? #1079823
09/21/11 01:38 PM
09/21/11 01:38 PM
Lake County, Ohio
RJF Offline OP
RJF  Offline OP
Lake County, Ohio
How do you install the rocker panel moldings on a 67 Plymouth b-body. The front butterfly clips are on each side (never took them off when painting the car). I have a set of new plastic clips but don't know where to go from here. Any help would be greatly appreciated............
Re: 67 gtx rocker moldings installation ?? [Re: RJF] #1079824
09/22/11 11:23 AM
09/22/11 11:23 AM
Calgary, Alberta Canada
a12rag Online content
a12rag  Online Content
Did your rocker panels have rivets sticking out that the plastic clips mount to, then you snap the rocker molding over the plastic clips . . . or did you replace the rocker panels and no longer have these studs ?? If that is the case, then you have to drill holes in the rockers and install rivets for the plastic clips, or screw the clips on . . . .
Hope that helps . . .
Cheers
Mark
Re: 67 gtx rocker moldings installation ?? [Re: RJF] #1079825
09/22/11 02:27 PM
09/22/11 02:27 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
The 67 GTX does not use any rivets.
The clips are plastic and they have the 4 fingers that push into a hole on the body, then you push a round plastic dowel in the hole to expand the fingers. The butterfly clips go into the back of the moulding, put the stud through the hole in the fender, snap the rocker moulding over the plastic clips described above, install the nut on the butterfly clip. Done.
Re: 67 gtx rocker moldings installation ?? [Re: NANKET] #1079826
09/22/11 06:18 PM
09/22/11 06:18 PM
Lake County, Ohio
RJF Offline OP
RJF  Offline OP
Lake County, Ohio
Thanks for the reply, you are correct about the plastic clips and the holes already there. Is there a trick to getting the butterfly clip to lock into the molding with the butterful clip still on the car ? Or do I have to remove the butterfly clip from the car, insert it into the molding and then secure the butterfly clip from behind ?
Thanks again..........
Re: 67 gtx rocker moldings installation ?? [Re: RJF] #1079827
09/24/11 09:05 AM
09/24/11 09:05 AM
North Carolina, USA
Silverbullet2 Offline
North Carolina, USA
Yes, the metal butterfly clip should be secured in the molding first. Those moldings dent easily (Ask me how I know) so be gentle and avoid bumping it in the middle when snapping it on the plastic clips.
Re: 67 gtx rocker moldings installation ?? [Re: Silverbullet2] #1079828
09/26/11 02:46 PM
09/26/11 02:46 PM
Lake County, Ohio
RJF Offline OP
RJF  Offline OP
Lake County, Ohio
Thanks for all replies, I followed silver bullets advise and the mouldings are on. They look good and are very tight & secure
RF
