that was close!roller clutch was gone. #1079364
09/20/11 04:28 PM
09/20/11 04:28 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
i was messing with the carbs for 2 days and put it in drive,reverse a few times so i finaly go up to tech in and i lost 1st gear pulling away to go back to my pit.i went back in 2nd after hearing the telltale rattling of bolt in a can sound.i put the car in the trailer emediatly to keep myself from blowing it up in my pit messing with it.i was just there to tune the car a little so i was not about to pull the trans and rebuild it there.it was from there on.i dropped the pan and it looks like the roller springs went in the sprag.that could have been bad on the starting line.time to get the trans out and fixed so maybe i can get out yet again this yr for more tunning.
Re: that was close!roller clutch was gone. [Re: Clanton] #1079365
09/20/11 04:43 PM
09/20/11 04:43 PM
organ
maximum entropy Offline
organ
was that a stock overrunning clutch?
Re: that was close!roller clutch was gone. [Re: maximum entropy] #1079366
09/20/11 04:50 PM
09/20/11 04:50 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
no way it wat not stock. a bolt in but i cant say what 1 but it has about 300 runs on it.
Re: that was close!roller clutch was gone. [Re: Clanton] #1079367
09/20/11 08:56 PM
09/20/11 08:56 PM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
Ouch! Better you caught it now and not the hard way. Going to make any upgrades while it's apart?
Randy
Re: that was close!roller clutch was gone. [Re: Dartin] #1079368
09/20/11 09:09 PM
09/20/11 09:09 PM
Guitar Jones Offline
Yeah that could have been real ugly.
Re: that was close!roller clutch was gone. [Re: Dartin] #1079369
09/20/11 09:29 PM
09/20/11 09:29 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
i will sent the convertor to ptc to get tightin up fro 5K to 4500 or get a new convertor alltogather.the trans has a billet drum,4 pinion sun gears,
Randy thanks for stopping at my pit at norwalk and talking to me!
Re: that was close!roller clutch was gone. [Re: Clanton] #1079370
09/20/11 09:33 PM
09/20/11 09:33 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Good catch, Michael. Guess you were actually real lucky your car let you know something was up.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
