Re: Edlebrock RPM dual plane/Holley 650 DP kick down?
[Re: da50r]
#1078792
09/20/11 01:23 AM
09/20/11 01:23 AM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
I have a Lokar cable on it, and it just doesn't seem to be consistent. Is there a linkage that will work ok with the following? 360/904/RPM/Holley 650 mech linkage
I was able to hook up my factory 318 kickdown linkage, but i had to build up the bracket that bolts on the intake, I lifted it up 2", you must use the throttle adapter from holley for it to work good, Anymore i just install a MVB & problem solved, plus the tranny shifts sooooo much better.
