I have a Lokar cable on it, and it just doesn't seem to be consistent. Is there a linkage that will work ok with the following?
360/904/RPM/Holley 650 mech linkage
No issues with mine other than it slips once in a while. Bracket design from Edelbrock isn't the best...I also added a spring down on the trans that helped, so there is one below from a bracket to the kick-down cable not seen up top.
'70 Cuda,...605 EFI Hemi Street Car (6.20 best pass, 1.33 60ft)
https://www.youtube.com/watch?v=WYw6RA-k5Bk (6.25 at 108.75mph from inside car)
https://www.youtube.com/watch?v=3zQEb9uxFng (6.25 at 108mph from outside car)
'66 Barracuda AWB Stretched nose Blown 440 Car in build stage
'71 Duster Drag Car 400 Low Deck 512 best 6.002 at 115.44mph
https://www.youtube.com/watch?v=Znuo3jMUXTk
