Reversion Plates #1077944
09/19/11 06:23 AM
09/19/11 06:23 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
When should one be considered?
Re: Reversion Plates [Re: Scamp408] #1077945
09/19/11 09:05 AM
09/19/11 09:05 AM
Finland
mafo Offline
mafo  Offline
Finland
I would say, with a big plenum like a sheet metal tunnelram, but I have been wrong before
great place to get them
http://www.product-engr.com/shear_plates.htm
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: Reversion Plates [Re: Scamp408] #1077946
09/19/11 11:29 AM
09/19/11 11:29 AM
AndyF Offline
AndyF  Offline
I use them on a tall spacer. Not sure they actually help in this application but it doesn't seem to hurt.
Re: Reversion Plates [Re: AndyF] #1077947
09/19/11 11:48 AM
09/19/11 11:48 AM
PA
W5DART66 Offline
W5DART66  Offline
PA
Do you make the big spacer?
Re: Reversion Plates [Re: W5DART66] #1077948
09/19/11 01:11 PM
09/19/11 01:11 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
A racer friend said I was choppy at 2000 to 3000 rpm.I never noticed it till he pointed it out and said itd from reversion in the intake.
Re: Reversion Plates [Re: W5DART66] #1077949
09/19/11 01:40 PM
09/19/11 01:40 PM
AndyF Offline
AndyF  Offline
Yes, I had to make these spacers since nobody sells anything like this. I tapered the spacer to work with the shear plate and I put a profile on the bottom of the spacer to match the Super Victor plenum shape.
Re: Reversion Plates [Re: AndyF] #1077950
09/24/11 03:14 AM
09/24/11 03:14 AM
NEW JERSEY
BIGSPEED Offline
BIGSPEED  Offline
NEW JERSEY
In most cases a shear plate is a plus but the manifold has to be configured so the reversion energy will help accelerate the incoming charge,best results gained with a trip to the dyno.Bill C.
Ceralli Racing Engines & Checkered Flag Machine Racing engines , CNC porting & induction development http://www.checkeredflagmachine.net/
Re: Reversion Plates [Re: BIGSPEED] #1077951
09/24/11 12:18 PM
09/24/11 12:18 PM
AndyF Offline
AndyF  Offline
I doubt that a trip to the dyno would reveal much. I spent 4 days on the dyno trying several different spacers and didn't prove anything.
Re: Reversion Plates [Re: AndyF] #1077952
09/24/11 03:27 PM
09/24/11 03:27 PM
NEW JERSEY
BIGSPEED Offline
BIGSPEED  Offline
NEW JERSEY
You must have gone to the wrong dyno with the wrong spacers and the wrong people,our testing with Wideband O2 in each cylinder has been interesting,knowledge gathering and the end results have given us more power and acceleration.Bill C.
Re: Reversion Plates [Re: BIGSPEED] #1077953
09/25/11 01:21 AM
09/25/11 01:21 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I am thinking of running wilson shear plates on the hemi with a stageV intake, I dont know what it takes to install them but I am hoping they help. Tim
Re: Reversion Plates [Re: astjp2] #1077954
09/25/11 01:06 PM
09/25/11 01:06 PM
AndyF Offline
AndyF  Offline
It takes a lot of grinding to use shear plates on a cast intake. That was why I had the custom spacers built.
A set of shear plates might work okay on a Stage V intake but it will cost you a fair amount of time and money to make it all fit. I spent a couple of grand testing spacers and shear plates earlier this year and didn't find any power on my 514. But I guess I did help stimulate the economy a little bit!
Re: Reversion Plates [Re: AndyF] #1077955
09/25/11 02:52 PM
09/25/11 02:52 PM
NEW JERSEY
BIGSPEED Offline
BIGSPEED  Offline
NEW JERSEY
Andy if you saw absolutley no changes there is something restricting air flow,head or manifold CSA or camshaft events.Bill C.
