How do I remove this Horn Ring????? #1077936
09/19/11 04:28 AM
09/19/11 04:28 AM
Fresno, CA.
Mikesmopars01 Offline OP
Fresno, CA.
How do I remove this Horn Ring??????????
Re: How do I remove this Horn Ring????? [Re: Mikesmopars01] #1077937
09/19/11 05:47 AM
09/19/11 05:47 AM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
Im guessing but arent there screws in the front Between the dash and the wheel?
Re: How do I remove this Horn Ring????? [Re: CYACOP] #1077938
09/19/11 05:53 AM
09/19/11 05:53 AM
Fresno, CA.
Fresno, CA.
I have been looking for screws. I do not see any. I tryed pushing and turning, turning, pulling, yelling!! Nothing seems to work.
Re: How do I remove this Horn Ring????? [Re: Mikesmopars01] #1077939
09/19/11 07:43 AM
09/19/11 07:43 AM
okla.
O
okie Offline
okie  Offline
O
okla.
The center has got to come out and there is a bolt under it. I just use a small screw driver to pop the center out. Ronnie
Re: How do I remove this Horn Ring????? [Re: okie] #1077940
09/19/11 10:45 AM
09/19/11 10:45 AM
DELAWARE
bee71mopar Offline
bee71mopar  Offline
DELAWARE
Yup center vinyl piece comes out first.
Re: How do I remove this Horn Ring????? [Re: Mikesmopars01] #1077941
09/19/11 11:01 AM
09/19/11 11:01 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
the little plastic piece with the dodge or plymouth emblem in the middle comes out first , be careful not to destroy it , then there is a bolt under it.
Re: How do I remove this Horn Ring????? [Re: JohnRR] #1077942
09/19/11 04:32 PM
09/19/11 04:32 PM
Fresno, CA.
Fresno, CA.
The job is done. Thank you
Re: How do I remove this Horn Ring????? [Re: Mikesmopars01] #1077943
09/19/11 08:13 PM
09/19/11 08:13 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
thanks for saying"job done" seems some take the advice given by many here with good knowledge and never post a completion or update. refreshing
