what is your experience with composite lifters ? #1077865
09/18/11 11:25 PM
09/18/11 11:25 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
who has used them and what was your experience ?
good bad or indifferent
this is in a flat tappet cam big block
i know you need more spring pressure and valve bounce will kill them
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: what is your experience with composite lifters ? [Re: tex013] #1077866
09/19/11 03:47 AM
09/19/11 03:47 AM
Netherlands
72Challenger Offline
Netherlands
I've used them for the last 7 years now without any problems. Used them when I've built my 528 pumpgas KB Hemi back then. At first in street / strip application running mid 10's while the last years in a race only app running around 9.0's. Still the same engine. Not a single issue.
Only think, price wise, I could have gone roller back then for around the same money.
Re: what is your experience with composite lifters ? [Re: tex013] #1077867
09/19/11 10:43 AM
09/19/11 10:43 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I bought a set to use when I dyno test. That way I can swap camshafts without the need for a new set of lifters each time.
I think the main advantage of them in a different situation would be if you race in a class that limits you to a flat tappet. At least with the composite lifter you can run more spring pressure for the r.p.m. potential.
Keith
Re: what is your experience with composite lifters ? [Re: Dunnuck Racing] #1077868
09/19/11 11:40 AM
09/19/11 11:40 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Where can you get them these days? Seemed there was one manufacturer and he is not easy to get hold of, order from? I haven't really researched it lately, so I could(probably am) be wrong.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: what is your experience with composite lifters ? [Re: OhioMopar] #1077869
09/19/11 11:45 AM
09/19/11 11:45 AM
AndyF Offline
AndyF  Offline
I'm pretty sure that Don at FBO still carries them.
I have a used set that I'll sell. I used them for some dyno testing but I doubt that I'll need them again since I've now switched everything over to rollers.
Re: what is your experience with composite lifters ? [Re: AndyF] #1077870
09/19/11 11:50 AM
09/19/11 11:50 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Okay, cool. Hadn't heard much about them lately.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: what is your experience with composite lifters ? [Re: AndyF] #1077871
09/19/11 01:01 PM
09/19/11 01:01 PM
dogdays Offline
dogdays  Offline
So, Andy, what roller grind do you use to replace the surprisingly good Mopar .528?
R.
Re: what is your experience with composite lifters ? [Re: dogdays] #1077872
09/19/11 01:43 PM
09/19/11 01:43 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Andy, I sent a email on the lifters.
I love them and use them in all my solid cam motors for one main reason, I never worry one bit, sorta like putting the dana in the car as well...
Ive one set with so much time on them, ive got to measure the bodies soon and maybe get them replaced, as the inserts are still as perfect as the day I got them.
Re: what is your experience with composite lifters ? [Re: quick77rt ] #1077873
09/19/11 01:52 PM
09/19/11 01:52 PM
Nebraska
70VcodeCoronetRT Offline
Nebraska
Use them in the Bee. Going on 3 years now. Never a problem. Will use them again.
Re: what is your experience with composite lifters ? [Re: 70VcodeCoronetRT] #1077874
09/19/11 06:41 PM
09/19/11 06:41 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
thanks guys for your input.
definately worth thinking about.
maybe i am am just a Luddite,but a flat tappet for daily driver/strip use seems to work.
even if just for reduced maintenance
Tex
New best MPH 130.32
Re: what is your experience with composite lifters ? [Re: tex013] #1077875
09/20/11 04:25 AM
09/20/11 04:25 AM
New Mexico.U.S.A.
Q
quickwedge Offline
quickwedge  Offline
Q
New Mexico.U.S.A.
I have sold and used many sets since Joe started making them,one customer had 3 of them push the composite out of the lifter body .060-.080,after he forgot to turn his fan and pump on.He said that the temp was over 280 before he noticed.Excessive heat would cause the lifter to spread as the epoxy expanded at high temp.This was on one of Joe's early sets that had been in the engine 3 years with 2 different cams.I have been using SM lifters since Smith tooled up.the Schubeck lifters in my 63 Max Wedge have been in 6 years-4 different engines with no problems.I have sold 4 sets of the SM this year 2 tool steel and 2 regular sets.Don't Drop them and Don't run to much lash and they should work great.
Richard
CrossRoads Racing
