what is your experience with composite lifters ?
#1077865
09/18/11 11:25 PM
09/18/11 11:25 PM
Posts: 2,473 Sydney,Australia
tex013
Sydney,Australia
who has used them and what was your experience ? good bad or indifferent
this is in a flat tappet cam big block i know you need more spring pressure and valve bounce will kill them
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: what is your experience with composite lifters ?
[Re: tex013]
#1077866
09/19/11 03:47 AM
09/19/11 03:47 AM
Posts: 1,262 Netherlands
72Challenger
Netherlands
I've used them for the last 7 years now without any problems. Used them when I've built my 528 pumpgas KB Hemi back then. At first in street / strip application running mid 10's while the last years in a race only app running around 9.0's. Still the same engine. Not a single issue.
Only think, price wise, I could have gone roller back then for around the same money.
[Re: Dunnuck Racing]
#1077868
09/19/11 11:40 AM
09/19/11 11:40 AM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
Where can you get them these days? Seemed there was one manufacturer and he is not easy to get hold of, order from? I haven't really researched it lately, so I could(probably am) be wrong.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: AndyF]
#1077870
09/19/11 11:50 AM
09/19/11 11:50 AM
OhioMopar
Mt.Gilead, Ohio
Okay, cool. Hadn't heard much about them lately.
[Re: 70VcodeCoronetRT]
#1077874
09/19/11 06:41 PM
09/19/11 06:41 PM
tex013
Sydney,Australia
thanks guys for your input. definately worth thinking about. maybe i am am just a Luddite,but a flat tappet for daily driver/strip use seems to work. even if just for reduced maintenance
Tex
