did some air bleed tests,? #1077755
09/18/11 09:13 PM
09/18/11 09:13 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
but never made a pass at norwalk as i lost 1st gear pulling away from getting teched in on friday.
so i have a 3circuit dom and used a LM-1 trying to tune in my pit space as much as i could to get things going to make a pass.the idle A/F is 12.8/1 and i change3d the bleeds in the int and got the A/F down to 16/1 but it still stumbles but the sypmtom i am trying to cure is with the intercooler it leans out to almost 18/1 but stays running now at least.i put a .023 bleed in[smallest]stock bleed is 68 and with that the A/F was about 20/1.i have the pv's blocked.any ideas?
Re: did some air bleed tests,? [Re: Clanton] #1077756
09/18/11 11:00 PM
09/18/11 11:00 PM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
Mine was stumbling when I tried to free rev the motor, or drive around the pits. Carb is a Pro-Systems 3 circuit Dominator with blocked powervalves. Patrick suggested running a 4.5 PV in the front and jetting down 10. Did that last night and the engine is running really clean now.
Re: did some air bleed tests,? [Re: PolyDart] #1077757
09/19/11 08:50 AM
09/19/11 08:50 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
thanks.i am sure that is good info but i have a roots blown engine.i have 2 holley 1250cfm 80532-1 carbs.
Re: did some air bleed tests,? [Re: Clanton] #1077758
09/19/11 06:44 PM
09/19/11 06:44 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
i do understand that there is not much draw on the fuel with the engine not being under load or with it in gear and x amount of rpm.maybe one of you has warmed the engine and matched the A/F with load,no load info?
Re: did some air bleed tests,? [Re: Clanton] #1077759
09/19/11 08:06 PM
09/19/11 08:06 PM
Ohio
3404 Offline
3404  Offline
Ohio
Shouldn't idle A/F be adjusted with the idle screws and not the air bleeds? also why are you hitting such lean numbers with the adjustments of the air bleeds?
Re: did some air bleed tests,? [Re: 3404] #1077760
09/19/11 08:37 PM
09/19/11 08:37 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
i did open the idle air bleed because i could only turn it out 1/4 turn[8 screws on 2 4bbls] and it was still rich so now the idle screws are out 3/4 and i need the extra fuel for the intercooler effect on it.now for the lean # with the air bleed in the intermediat circuit i am not sure why but the reduction on bleed size and the result effect on the A/F ratio shows it has an effect so i am confident the readings are good for under load.i have results power braking the convertor from last yr and it was in the uppper teens a/f.i have a video of it and will get it.
Re: did some air bleed tests,? [Re: Clanton] #1077761
09/19/11 08:44 PM
09/19/11 08:44 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
here is the video with the LC-1
http://www.youtube.com/watch?v=NIigVBZ8TME
Re: did some air bleed tests,? [Re: Clanton] #1077762
09/19/11 11:29 PM
09/19/11 11:29 PM
Ohio
3404 Offline
3404  Offline
Ohio
I would suggest a Holley carb performance book to get a good understanding how everything works and how they are all tied together.
There are many things that IMO have to be looked at and air bleeds may be the last thing to try.
Your video looks like trial under a load, so I think power valves and if the carbs are turned sideway maybe jet extensions on all 8 jets or raise the floats a bit?
A vacuum gage showing how much vacuum you have at a cruise speed will help you choose the proper power valve.
Idle screws richen the idle mixture when you open them and air bleeds will lean things out when you make them larger in size.
If you have the butterflys open just a bit to much the idle circuit completely drops out and you start pulling on the main circuit.
Re: did some air bleed tests,? [Re: 3404] #1077763
09/20/11 08:51 AM
09/20/11 08:51 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thanks for the tips!it is allways good to review the carb function to help figure things out.
Re: did some air bleed tests,? [Re: Clanton] #1077764
09/20/11 12:40 PM
09/20/11 12:40 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Idle screws actually only meter the Volume of the emulsified idle mixture... The channel restriction changes the ratio...
Re: did some air bleed tests,? [Re: RemCharger] #1077765
09/21/11 09:13 PM
09/21/11 09:13 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
so who has changed the channel restrictor or emulsion bleed and what was the result effect %?
Re: did some air bleed tests,? [Re: Clanton] #1077766
09/22/11 07:57 PM
09/22/11 07:57 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
i talked to quick fuel and thay said i could only drill out my main feed starting by .010 bigger and the main discharge in the metering block by the same.
Re: did some air bleed tests,? [Re: Clanton] #1077767
09/22/11 07:59 PM
09/22/11 07:59 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
i am not sure where the main discharge is in the plate.
Re: did some air bleed tests,? [Re: Clanton] #1077768
09/22/11 08:00 PM
09/22/11 08:00 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
or on this side.
Re: did some air bleed tests,? [Re: Clanton] #1077769
09/22/11 08:51 PM
09/22/11 08:51 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
i see in this pic the intermediat discharge is on the lower corners and is where i should drill.
anyone have any input?
Re: did some air bleed tests,? [Re: Clanton] #1077770
09/23/11 11:56 AM
09/23/11 11:56 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Needs bigger jets..
Re: did some air bleed tests,? [Re: RemCharger] #1077771
09/23/11 12:22 PM
09/23/11 12:22 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Needs bigger jets..
i think i ment the intermediat discharge jet as shown above.my metering plate as above is not adjustable so maybe i will buy billet plates [34-77]
Re: did some air bleed tests,? [Re: Clanton] #1077772
09/23/11 01:44 PM
09/23/11 01:44 PM
Ohio
3404 Offline
3404  Offline
Ohio
Needs bigger jets..
Clanton, in my opinion you might want to have your carbs set up by someone who does that kind of work. With you being in Northern Ohio you have a few shops close by like APD in Sadusky and Dale Cubic (CFM) in Medina. Trying to run dual carbs is a bit of a different animal and like I said just my drilling holes may be a no no or a quick way to end up with 2 junk carbs.
Air Bleeds and drilling holes is usually done after you have your carbs really close to being perfect and maybe something that is totally not necessary unless you are running pro-stock....
Re: did some air bleed tests,? [Re: Clanton] #1077773
09/23/11 01:46 PM
09/23/11 01:46 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Needs bigger jets..
Sorry, what i meant was,,, WHAT SIZE ARE THOSE JETS???
Re: did some air bleed tests,? [Re: 3404] #1077774
09/23/11 02:24 PM
09/23/11 02:24 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Needs bigger jets..
Thank you 3404 and i agree i dont want to endup with junk
carbs!
the jets in the plate are 110. the high speed does ok at 12.8 a/f but needs more with those jets.
