Re: did some air bleed tests,? [Re: Clanton] #1077775
09/23/11 02:45 PM
09/23/11 02:45 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
i am wondering if i can drill my power valve blank in the pic above and put a jet in it or screw in adjuster to fattinup the intermediat. or all and i can use [Edited by Moparts - Family Friendly Site - Keep it clean] bleeds in the hs then.
Re: did some air bleed tests,? [Re: Clanton] #1077776
09/23/11 02:53 PM
09/23/11 02:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thank you 3404 and i agree i dont want to endup with junk
carbs!
the jets in the plate are 110. the high speed does ok at 12.8 a/f but needs more with those jets.
I cant believe you need 110 jets on a PAIR of carbs
unless your running E-85 and then it still doesnt sound
right
Re: did some air bleed tests,? [Re: MR_P_BODY] #1077777
09/23/11 02:58 PM
09/23/11 02:58 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
i know mr p.some info on the carbs,it came with 100 jet and power valves so i blocked them and jettup.it is a 1250cfm carb. like i said the high speed is close at 12.8 a/f and i have not touched those bleeds.just the intermediat is lean.
Re: did some air bleed tests,? [Re: Clanton] #1077778
09/23/11 03:01 PM
09/23/11 03:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
i know mr p.some info on the car,it came with 100 jet and power valves so i blocked them and jettup.it is a 1250cfm carb.
I thought you had dual 4 barrels... so you only have
a single
Re: did some air bleed tests,? [Re: MR_P_BODY] #1077779
09/23/11 03:14 PM
09/23/11 03:14 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
i still have 2 1250's on it so i believe the lean condition because i an only using the pri side of the carbs reving it and load testing in gear.i have no down track data other than in the traps at 12.8 a/f.
Re: did some air bleed tests,? [Re: Clanton] #1077780
09/26/11 01:33 PM
09/26/11 01:33 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
i am realy thinking about drilling powervalve blanks/plugs as an inrichment meter.i can start with the pri side starting small.030 and go up.the plugs are cheap.[3$]
Re: did some air bleed tests,? [Re: Clanton] #1077781
09/27/11 03:10 PM
09/27/11 03:10 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
update:i talked to APD and i need to drill the hole next to the main jet in this pic and i will be able to come down in the airbleed eventualy so now the pv drill is no longer an option.
