Re: did some air bleed tests,?
[Re: Clanton]
#1077756
09/18/11 11:00 PM
09/18/11 11:00 PM
Posts: 876 Arizona
PolyDart
Arizona
Mine was stumbling when I tried to free rev the motor, or drive around the pits. Carb is a Pro-Systems 3 circuit Dominator with blocked powervalves. Patrick suggested running a 4.5 PV in the front and jetting down 10. Did that last night and the engine is running really clean now.
[Re: 3404]
#1077760
09/19/11 08:37 PM
09/19/11 08:37 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Shouldn't idle A/F be adjusted with the idle screws and not the air bleeds? also why are you hitting such lean numbers with the adjustments of the air bleeds?
i did open the idle air bleed because i could only turn it out 1/4 turn[8 screws on 2 4bbls] and it was still rich so now the idle screws are out 3/4 and i need the extra fuel for the intercooler effect on it.now for the lean # with the air bleed in the intermediat circuit i am not sure why but the reduction on bleed size and the result effect on the A/F ratio shows it has an effect so i am confident the readings are good for under load.i have results power braking the convertor from last yr and it was in the uppper teens a/f.i have a video of it and will get it.
[Re: RemCharger]
#1077765
09/21/11 09:13 PM
09/21/11 09:13 PM
Clanton
northern,Ohio,USA
Idle screws actually only meter the Volume of the emulsified idle mixture... The channel restriction changes the ratio...
so who has changed the channel restrictor or emulsion bleed and what was the result effect %?
[Re: Clanton]
#1077770
09/23/11 11:56 AM
09/23/11 11:56 AM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
i am not sure where the main discharge is in the plate.
Needs bigger jets..
[Re: RemCharger]
#1077771
09/23/11 12:22 PM
09/23/11 12:22 PM
Clanton
northern,Ohio,USA
Needs bigger jets..
i think i ment the intermediat discharge jet as shown above.my metering plate as above is not adjustable so maybe i will buy billet plates [34-77]
[Re: Clanton]
#1077772
09/23/11 01:44 PM
09/23/11 01:44 PM
Posts: 1,369 Ohio
3404
Ohio
Needs bigger jets..
Clanton, in my opinion you might want to have your carbs set up by someone who does that kind of work. With you being in Northern Ohio you have a few shops close by like APD in Sadusky and Dale Cubic (CFM) in Medina. Trying to run dual carbs is a bit of a different animal and like I said just my drilling holes may be a no no or a quick way to end up with 2 junk carbs. Air Bleeds and drilling holes is usually done after you have your carbs really close to being perfect and maybe something that is totally not necessary unless you are running pro-stock....
[Re: Clanton]
#1077773
09/23/11 01:46 PM
09/23/11 01:46 PM
RemCharger
Sk. Canada
Needs bigger jets..
Sorry, what i meant was,,, WHAT SIZE ARE THOSE JETS???
[Re: 3404]
#1077774
09/23/11 02:24 PM
09/23/11 02:24 PM
Clanton
northern,Ohio,USA
Needs bigger jets..
Thank you 3404 and i agree i dont want to endup with junk carbs! the jets in the plate are 110. the high speed does ok at 12.8 a/f but needs more with those jets.
[Re: Clanton]
#1077776
09/23/11 02:53 PM
09/23/11 02:53 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I cant believe you need 110 jets on a PAIR of carbs unless your running E-85 and then it still doesnt sound right
[Re: MR_P_BODY]
#1077777
09/23/11 02:58 PM
09/23/11 02:58 PM
Clanton
northern,Ohio,USA
i know mr p.some info on the carbs,it came with 100 jet and power valves so i blocked them and jettup.it is a 1250cfm carb. like i said the high speed is close at 12.8 a/f and i have not touched those bleeds.just the intermediat is lean.
[Re: Clanton]
#1077778
09/23/11 03:01 PM
09/23/11 03:01 PM
MR_P_BODY
i know mr p.some info on the car,it came with 100 jet and power valves so i blocked them and jettup.it is a 1250cfm carb.
I thought you had dual 4 barrels... so you only have a single
