Trans problems... What caused this???? Pics #1077624
09/18/11 07:33 PM
09/18/11 07:33 PM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
I'd like to know what your guys thought are.....
Everything in the trans looks like new, like when i put it together except the front drum (high/reverse I believe is the other name)
What caused this??? The clutch pack is welded together and the aluminum in the bottom of the drum is melted everywhere. I literally had to pound the front drum off the input shaft.
Here are the rear clutch discs... They are still like new..
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Trans problems... What caused this???? Pics [Re: DemonDust] #1077625
09/18/11 07:54 PM
09/18/11 07:54 PM
Guitar Jones Offline
Well either the front clutch was slipping in high or it was dragging in 1st and 2nd. It's pretty hard to say from what is pictured as to what happened though. What exactly was the progression of systems?
Re: Trans problems... What caused this???? Pics [Re: Guitar Jones] #1077626
09/18/11 07:56 PM
09/18/11 07:56 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
is the shift cable adj. correct ?
Re: Trans problems... What caused this???? Pics [Re: Guitar Jones] #1077627
09/18/11 08:03 PM
09/18/11 08:03 PM
Menomonee Falls
Menomonee Falls
Ok here goes;
Burnout 2-3 no problem. Staged in 1st, checked pressure gauge had 200 lbs. Left the lights at 3800. Got out a ways and the engine was bouncing off the rev limiter at 9600 rpms. I then realized i forgot to turn my air bottle on. I shifted to 2nd manually, then 3rd no problems. when thru the lights and pulled it into neutral, but it didn't go into neutral it proceeded to slow down with the engine for about 100 ft and then went into clean neutral. I got stopped, put it in reverse to turn around into the return lane. Put it in first and there didn't seem to be anything there until I hit about 2000. Then I shifted to 2nd and limped to the pits.
SDG Motorsports
Re: Trans problems... What caused this???? Pics [Re: DemonDust] #1077628
09/18/11 08:22 PM
09/18/11 08:22 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Without seeing it in person,it is hard to say for sure. I would bet if you take the return spring out of it,it is bent/broke/or twisted.
High r.p.m's and the return spring unwinding,added up to cause the clutches to drag all the time.
Keith
Re: Trans problems... What caused this???? Pics [Re: Dunnuck Racing] #1077629
09/18/11 08:47 PM
09/18/11 08:47 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Get rid of the single wound spring in the front drum and go with 24 spring kit..
the single wound spring will unwind at high rpms and allow the disc to drag..
http://www.tcsproducts.com/products/product/15/
A&A sells it also
Tony
70 AARCuda Vitamin C
Re: Trans problems... What caused this???? Pics [Re: 70AARcuda] #1077630
09/18/11 08:51 PM
09/18/11 08:51 PM
I would have to agree, 9600 rpm's, youza, that single spring needs to go.
Re: Trans problems... What caused this???? Pics [Re: Guitar Jones] #1077631
09/18/11 09:58 PM
09/18/11 09:58 PM
Menomonee Falls
Menomonee Falls
Yes I did check the valve body/shifter adjustment.
So the spring is more than likely the culprit? If so this thing has been 39 runs shifting at 8800 rpms. I guess it was a matter of time before something bad happened with it.
Are there any other internals that don't agree with the high rpms that I should look into upgrading while I have the trans apart?
SDG Motorsports
Re: Trans problems... What caused this???? Pics [Re: Guitar Jones] #1077632
09/18/11 10:02 PM
09/18/11 10:02 PM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
It looks like the front drum piston was touching the rear drum when the front clutch was applyed.
if you have a 4 disc fron drum, and you use a rear drum made for a 5 disc drum (taller splines), when the piston applys the clutches, it will hit/rub the rear drum.
Re: Trans problems... What caused this???? Pics [Re: CRT] #1077633
09/18/11 10:08 PM
09/18/11 10:08 PM
Menomonee Falls
Menomonee Falls
The rear drum is a stock 4 disc. The front drum I had 5 thin discs in with proper snap ring for proper clearance.
SDG Motorsports
Re: Trans problems... What caused this???? Pics [Re: DemonDust] #1077634
09/18/11 10:12 PM
09/18/11 10:12 PM
I've seen a rear clutch hub made for a 4 disc front clutch not have a long enough hub to engage all 5 disc lugs in the front drum.
Re: Trans problems... What caused this???? Pics [Re: DemonDust] #1077635
09/18/11 10:15 PM
09/18/11 10:15 PM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
In your pics, looks like the front pistion was hitting /rubbing the rear drum. a 904 rear drum for the 5 disc front drum, only takes 4 clutches in the rear drum, but the splines for the front clutch, holds when applyed are taller. Take a pic of the rear drum splines with a ruler.
Re: Trans problems... What caused this???? Pics [Re: CRT] #1077636
09/18/11 10:27 PM
09/18/11 10:27 PM
Menomonee Falls
Menomonee Falls
Here ya go
SDG Motorsports
Re: Trans problems... What caused this???? Pics [Re: DemonDust] #1077637
09/18/11 10:32 PM
09/18/11 10:32 PM
1.25 is a four disc front clutch drum, I just measured 2 of them.
Re: Trans problems... What caused this???? Pics [Re: Guitar Jones] #1077638
09/18/11 10:46 PM
09/18/11 10:46 PM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
OK, remove the piston from the front drum, to make sure the drum & the piston are a match set.
Re: Trans problems... What caused this???? Pics [Re: CRT] #1077639
09/18/11 10:47 PM
09/18/11 10:47 PM
Menomonee Falls
Menomonee Falls
Maybe a stupid question, How do you know if they are a match set?
SDG Motorsports
Re: Trans problems... What caused this???? Pics [Re: DemonDust] #1077640
09/18/11 10:53 PM
09/18/11 10:53 PM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
904 4 disc drun will have a flat pistion bottom and flat in the drum, a 5 disc will have a beveled piston bottom and beveled drum, I see you do not have the beveled 5 disc drum, so check the piston.
Re: Trans problems... What caused this???? Pics [Re: 70AARcuda] #1077641
09/18/11 10:58 PM
09/18/11 10:58 PM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
Re: Trans problems... What caused this???? Pics [Re: CRT] #1077642
09/18/11 11:22 PM
09/18/11 11:22 PM
Menomonee Falls
Menomonee Falls
Piston won't be coming out any time soon...
SDG Motorsports
Re: Trans problems... What caused this???? Pics [Re: DemonDust] #1077643
09/19/11 10:58 AM
09/19/11 10:58 AM
Might as well get an aluminum or steel drum for it now especially if you are turning it that high. You have to be careful about the 4/5 disc thing though. The 5 disc front clutch trans takes a different rear drum, reaction shaft and input shaft. Good luck.
