Re: Trans problems... What caused this???? Pics
[Re: DemonDust]
#1077625
09/18/11 07:54 PM
09/18/11 07:54 PM
Posts: 20,679 in a cattle trailer down by th...
Guitar Jones
Well either the front clutch was slipping in high or it was dragging in 1st and 2nd. It's pretty hard to say from what is pictured as to what happened though. What exactly was the progression of systems?
[Re: DemonDust]
#1077628
09/18/11 08:22 PM
09/18/11 08:22 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
Without seeing it in person,it is hard to say for sure. I would bet if you take the return spring out of it,it is bent/broke/or twisted. High r.p.m's and the return spring unwinding,added up to cause the clutches to drag all the time. ![](/ubbthreads/images/graemlins/Twocents.gif) Keith
[Re: Dunnuck Racing]
#1077629
09/18/11 08:47 PM
09/18/11 08:47 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
Get rid of the single wound spring in the front drum and go with 24 spring kit.. the single wound spring will unwind at high rpms and allow the disc to drag.. http://www.tcsproducts.com/products/product/15/A&A sells it also
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#1077630
09/18/11 08:51 PM
09/18/11 08:51 PM
Guitar Jones
I would have to agree, 9600 rpm's, youza, that single spring needs to go.
[Re: Guitar Jones]
#1077631
09/18/11 09:58 PM
09/18/11 09:58 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
Yes I did check the valve body/shifter adjustment.
So the spring is more than likely the culprit? If so this thing has been 39 runs shifting at 8800 rpms. I guess it was a matter of time before something bad happened with it.
Are there any other internals that don't agree with the high rpms that I should look into upgrading while I have the trans apart?
[Re: Guitar Jones]
#1077632
09/18/11 10:02 PM
09/18/11 10:02 PM
Posts: 2,771 Cedar Lake IN
CRT
Cedar Lake IN
It looks like the front drum piston was touching the rear drum when the front clutch was applyed. if you have a 4 disc fron drum, and you use a rear drum made for a 5 disc drum (taller splines), when the piston applys the clutches, it will hit/rub the rear drum. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: DemonDust]
#1077634
09/18/11 10:12 PM
09/18/11 10:12 PM
Guitar Jones
I've seen a rear clutch hub made for a 4 disc front clutch not have a long enough hub to engage all 5 disc lugs in the front drum.
[Re: DemonDust]
#1077637
09/18/11 10:32 PM
09/18/11 10:32 PM
Guitar Jones
1.25 is a four disc front clutch drum, I just measured 2 of them.
[Re: CRT]
#1077639
09/18/11 10:47 PM
09/18/11 10:47 PM
DemonDust
Menomonee Falls
OK, remove the piston from the front drum, to make sure the drum & the piston are a match set.
Maybe a stupid question, How do you know if they are a match set?
[Re: 70AARcuda]
#1077641
09/18/11 10:58 PM
09/18/11 10:58 PM
CRT
Cedar Lake IN
![](/ubbthreads/images/graemlins/iagree.gif)
[Re: DemonDust]
#1077643
09/19/11 10:58 AM
09/19/11 10:58 AM
Guitar Jones
Might as well get an aluminum or steel drum for it now especially if you are turning it that high. You have to be careful about the 4/5 disc thing though. The 5 disc front clutch trans takes a different rear drum, reaction shaft and input shaft. Good luck.
