Can someone run me through adjusting the kickdown? #1077366
09/18/11 04:27 PM
09/18/11 04:27 PM
Badge Offline OP
Badge  Offline OP
I have a 360 motor and 727 trans out of a mid 70's dodge van. It came with the stock kickdown rod. It is attached at the transmission with a cotter pin to a separate arm that moves parallel to the trans. It swings from front to back. I have a high rise intake and a carter AFB. The carburetor has provision for attaching a kickdown to the lower part of the throttle linkage.
Re: Can someone run me through adjusting the kickdown? [Re: Badge] #1077367
09/18/11 06:33 PM
09/18/11 06:33 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
is the kickdown lever that attaches to the carb the slotted kind?
Re: Can someone run me through adjusting the kickdown? [Re: mikemee1331] #1077368
09/18/11 06:37 PM
09/18/11 06:37 PM
Badge Offline OP
Badge  Offline OP
yes, and it threads onto the rod to allow adjustment
Re: Can someone run me through adjusting the kickdown? [Re: Badge] #1077369
09/18/11 07:00 PM
09/18/11 07:00 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Carb wide open trans lever almost all the way to the rear.
Re: Can someone run me through adjusting the kickdown? [Re: Badge] #1077370
09/18/11 07:00 PM
09/18/11 07:00 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
hopefully it is running parallel to the engine........ un hook the lever from the carb, make sure the trottle is forward (idle), pull the kickdown forward and screw (or unscrew) the slotted 'head' of the lever until it just clears the lever part of your throttle linkage (the furthest back point of the slot). that should get you to a 'ballpark' area where you can take out and tweek it until you get it to down shift where you want
Re: Can someone run me through adjusting the kickdown? [Re: Badge] #1077371
09/18/11 10:46 PM
09/18/11 10:46 PM
scratchnfotraction Offline
do you have the mopar throttle adaptor on the AFB carb?
it will be needed to use the stock throttle stud that the TP linkage hooks to,and the tall intake may have to have a taller bracket and the rod to carb longer to get the correct adjustments.
can yo post any pics of the carb/stud/TP linkage rod?
