fluid damper inst help
#1076793
09/17/11 10:36 PM
09/17/11 10:36 PM
Posts: 1,030 ohio
67mprfan
ohio
does the damper needs to move alittle more or do i need a longer bolt it's a fluid damper on a 440 crank i have a inst tool maybe not using it right ( stock crank bolt)
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
Re: fluid damper inst help
[Re: 67mprfan]
#1076796
09/17/11 10:39 PM
09/17/11 10:39 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Not all the way there yet.I use anti seize on the damper hub also.
[Re: 67mprfan]
#1076801
09/17/11 11:05 PM
09/17/11 11:05 PM
Posts: 6,780 Alabama
Mopar-Al
Alabama
Did you check the clearances? Alot of dampers, if not most, need honed to fit.
are you talking inside clearance
yup he is
[Re: 67mprfan]
#1076802
09/17/11 11:20 PM
09/17/11 11:20 PM
Posts: 52,972 Romeo MI
MR_P_BODY
not 2 sound dumb what would be the proper way to use the inst tool
Once you hone it a little I just use a grade 8 bolt with 3 good washers and pull it on with my impact wrench (use a couple different bolt lengths if needed so you have at least the bolt diameter into the crank and dont bottom out)
[Re: MR_P_BODY]
#1076803
09/17/11 11:23 PM
09/17/11 11:23 PM
Posts: 1,030 ohio
67mprfan
ohio
i'll chek it but thinkin it didn't need it i bought it used so should have been done.......but my thinking is not always the greastest
[Re: 67mprfan]
#1076804
09/17/11 11:44 PM
09/17/11 11:44 PM
MR_P_BODY
If it was on another engine MORE THAN LIKELY it will fit yours... pull it on with a impact and a grade 8 bolt and a few good washers
[Re: MR_P_BODY]
#1076805
09/17/11 11:51 PM
09/17/11 11:51 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
Maybe they sold it cause they could never get it on all the way. Hone it and use a good balancer pusher to install. And use anti seize as already mentioned.
[Re: Thumperdart]
#1076811
09/18/11 12:38 PM
09/18/11 12:38 PM
Posts: 1,532 off the grid
340B5
off the grid
Mine won't fit cold. I heat it up 250 degrees or a little more and it slides right on. I also use a little anti-seize.
Yeah, it's got a smallblock.
[Re: 340B5]
#1076812
09/18/11 01:22 PM
09/18/11 01:22 PM
Posts: 30,453 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
And how much "grunt" on the puller do you have to use ...to pull it off?
