fluid damper inst help #1076793
09/17/11 10:36 PM
09/17/11 10:36 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
does the damper needs to move alittle more or do i need a longer bolt it's a fluid damper on a 440 crank i have a inst tool maybe not using it right ( stock crank bolt)
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: fluid damper inst help [Re: 67mprfan] #1076794
09/17/11 10:37 PM
09/17/11 10:37 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
a few pic
Re: fluid damper inst help [Re: 67mprfan] #1076795
09/17/11 10:38 PM
09/17/11 10:38 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
1 more
Re: fluid damper inst help [Re: 67mprfan] #1076796
09/17/11 10:39 PM
09/17/11 10:39 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Not all the way there yet.I use anti seize on the damper hub also.
Nautilus Racing-
Re: fluid damper inst help [Re: 67mprfan] #1076797
09/17/11 10:51 PM
09/17/11 10:51 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Did you check the clearances? Alot of dampers, if not most, need honed to fit.
Re: fluid damper inst help [Re: Hot 340] #1076798
09/17/11 10:55 PM
09/17/11 10:55 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Every fluid dampener I have owned needed to be honed to fit
Re: fluid damper inst help [Re: Hot 340] #1076799
09/17/11 11:02 PM
09/17/11 11:02 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
are you talking inside clearance
Re: fluid damper inst help [Re: 67mprfan] #1076800
09/17/11 11:05 PM
09/17/11 11:05 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
not 2 sound dumb what would be the proper way to use the inst tool
Re: fluid damper inst help [Re: 67mprfan] #1076801
09/17/11 11:05 PM
09/17/11 11:05 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
yup he is
Re: fluid damper inst help [Re: 67mprfan] #1076802
09/17/11 11:20 PM
09/17/11 11:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Once you hone it a little I just use a grade 8 bolt
with 3 good washers and pull it on with my impact
wrench (use a couple different bolt lengths if needed
so you have at least the bolt diameter into the crank
and dont bottom out)
Re: fluid damper inst help [Re: MR_P_BODY] #1076803
09/17/11 11:23 PM
09/17/11 11:23 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
i'll chek it but thinkin it didn't need it i bought it used so should have been done.......but my thinking is not always the greastest
Re: fluid damper inst help [Re: 67mprfan] #1076804
09/17/11 11:44 PM
09/17/11 11:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If it was on another engine MORE THAN LIKELY it will
fit yours... pull it on with a impact and a grade 8 bolt
and a few good washers
Re: fluid damper inst help [Re: MR_P_BODY] #1076805
09/17/11 11:51 PM
09/17/11 11:51 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Maybe they sold it cause they could never get it on all the way. Hone it and use a good balancer pusher to install. And use anti seize as already mentioned.
Re: fluid damper inst help [Re: Bigcube] #1076806
09/18/11 06:48 AM
09/18/11 06:48 AM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Is that metal shavings or rust dust in your first picture? You might should pull it back off, clean it up to inspect it. If you keep trying to install it further, you may get thread damage if you already haven't yet.
Re: fluid damper inst help [Re: Bigcube] #1076807
09/18/11 06:49 AM
09/18/11 06:49 AM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
It's not on all the way in my opinion , and like already stated it probably needs honed . Mine needed honed also. I made my own install tool and I don't use the crank threads to pull it on.
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: fluid damper inst help [Re: 65dragnet] #1076808
09/18/11 10:57 AM
09/18/11 10:57 AM
st.cloud fl
d-150 Online content
Smarter than a 5th grader?
d-150  Online Content
st.cloud fl
if it was on a motor try to heat the damper in the oven
Re: fluid damper inst help [Re: d-150] #1076809
09/18/11 11:47 AM
09/18/11 11:47 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
thats not even close to being on, there should about 1/8 in. between the cover and the damper.pull, it back off and see if your pushing a ridge into it,if you are it needs to be honed.
Re: fluid damper inst help [Re: Hot 340] #1076810
09/18/11 12:17 PM
09/18/11 12:17 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Bingo...........mike the crank snout and the id of the dampner and go from there. Mine was about a .002 press fit iirc.
Re: fluid damper inst help [Re: Thumperdart] #1076811
09/18/11 12:38 PM
09/18/11 12:38 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
Mine won't fit cold. I heat it up 250 degrees or a little more and it slides right on. I also use a little anti-seize.
Yeah, it's got a smallblock.
Re: fluid damper inst help [Re: 340B5] #1076812
09/18/11 01:22 PM
09/18/11 01:22 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
And how much "grunt" on the puller do you have to use ...to pull it off?
