Trying to Qualify for the CRT 10.00 shoot out......
#1076651
09/17/11 02:37 PM
09/17/11 02:37 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
First I get a TT for the Pro class and it goes a 10.49.
I think OK If I can cut a light I can hold on some.
Then we get the qualifying runs.
First pass I get held up as someone let some anti freeze in the shut down area. When we re lite em and do another burn out the engine temp is up to 175 instead of 160.
Dam things runs a 9.996@131.61. A new personal best but dam now I'm in the bottom of the ladder for going under
So, 2nd qualifier I decide I'm gonna short shift it by 200 RPM and that should put me right there.
NOPE.It decides to run a 9.985@131.55.
WTH. I'm trying to slow down and run a new best
Only me right
Re: Trying to Qualify for the CRT 10.00 shoot out......
[Re: WILD BILL]
#1076652
09/17/11 02:42 PM
09/17/11 02:42 PM
Posts: 1,532 off the grid
340B5
off the grid
Thats the best bad luck you've had.
Yeah, it's got a smallblock.
[Re: WILD BILL]
#1076653
09/17/11 03:32 PM
09/17/11 03:32 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Dam things runs a [Email]9.996@131.61.[/Email] A new personal best but dam now I'm in the bottom of the ladder for going under
NOPE.It decides to run a [Email]9.985@131.55.[/Email]
Only me right
Bill your running alky now right... maybe it likes it warmer for your fuel ratio.... congrats on the NB... so far
[Re: MR_P_BODY]
#1076654
09/17/11 08:20 PM
09/17/11 08:20 PM
WILD BILL
BROOK PARK, OH
I think your right Raff.
I ended running Lonnie in the 10.0 and slept on the tree. I also didn't have the oil temp up as high (only in the 120ish range) and the car ran a 10.049
Made sure I got the water to 180 and the oil to 150 for the first round of no box and it picked back up and ran a 10.000@132.09.
Ive really learned a lot in just today's runs.
[Re: WILD BILL]
#1076655
09/17/11 08:51 PM
09/17/11 08:51 PM
Posts: 16,929 NC
440Jim
NC
That would have been nice in the 10-oh shoot out. I watch water, oil, and trans temp to fine tune the ET. In cool weather (50's) it can be a challenge to get them the same every round, so once you start making laps and the oil temp goes up, I dial lower.
In that cool weather, I have been known to even warm the water up to 190-200 and shut it down to heat soak before they call up my class. Just to get some heat in the oil. Alky likes some water temp, 160 minimum, and 170-180 is fine.
[Re: 440Jim]
#1076656
09/17/11 09:59 PM
09/17/11 09:59 PM
WILD BILL
BROOK PARK, OH
Oil pan heaters and lean out valves ROCK
DA went down to 1161 and I got the heat in it for rnd 2 of no box. He went RED and I put down another personal best of 9.976@131.88
With a .007 light no less. I could get used to this going rounds
