Re: buffing glass (scratches/sandblast)
[Re: GLR]
#1076590
09/17/11 01:36 PM
09/17/11 01:36 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
It is very hard to remove scratches , and when the glas has been etched by a sandblaster, Well..I would replace the glass.
this , you pretty much ruined the glass
[Re: JohnRR]
#1076591
09/17/11 09:43 PM
09/17/11 09:43 PM
Challenger 1
Cincinnati, Ohio
yup...
[Re: JohnRR]
#1076592
09/18/11 10:51 AM
09/18/11 10:51 AM
Posts: 21,498 It's a dry heat
gtx6970
It's a dry heat
Agreed, live with it or toss it and find another one.
BTW, don't bother with the Eastwood glass polishing kits. I bought one and it's a complete waste of $50
[Re: Challenger 1]
#1076594
09/19/11 11:54 AM
09/19/11 11:54 AM
Posts: 4,799 ILL
MLR426
ILL
I just had the door glasses in my 71 cuda convertible surface finished by a professional in Michigan. I had all the surface imperfections /scratches removed and Dave Walden reapplied the date code marking in the corners. Although very expensive to have done I now have perfect glass in my convertible and will no longer receive a points deduction during professional judging. Real nice original glass is impossible to find especially for an e-body convertible. In order to remove the scratches correctly with out causing ripples in the glass the entire surface of the glass has to be worked and this requires a lot of hours cutting. My door glass took 6 hours and my passenger side took 17 hours. logan426
