Cam endplay math? #1076051
09/16/11 07:22 PM
09/16/11 07:22 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Ok, I made a brass cam button and now I need to see if my numbers and assumptions are ok.
Superformance gasket thickness .051
total gap between cover and camshaft using clay with no gasket and bolts tight .648
cam button length .684
assumption 1: Roller cam end play .005-.010
assumption 2: Gasket crush .005-.010
So I get for math
gasket .051
minus crush -.005
plus gap +.648
equals =.694
minus button -.684
equals gap =.010
If I crush .010 on the gasket, my endplay would then be .005
Is my math ok? Are my tolerances ok? Did I miss anything?
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Cam endplay math? [Re: astjp2] #1076052
09/16/11 07:26 PM
09/16/11 07:26 PM
AndyF Online content
AndyF  Online Content
I'm not sure you can crush those gaskets that much. Your idea is correct, just not sure what the endplay is that you'll end up with. I'd recommend using a dial indicator to check the end play.
Re: Cam endplay math? [Re: AndyF] #1076053
09/16/11 07:30 PM
09/16/11 07:30 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
I will when I get it together but wanted to get the button close. I have some .006 shims that I can put behind the button. Thanks for the response. Tim
Re: Cam endplay math? [Re: astjp2] #1076054
09/16/11 07:34 PM
09/16/11 07:34 PM
I have an end plate with a window in it so I can quickly check the end play. I include these window plates with the timing covers that I sell.
Re: Cam endplay math? [Re: astjp2] #1076055
09/16/11 09:01 PM
09/16/11 09:01 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I have measured the crush of my stamped steel timing chain cover and water pump Felpro gaskets (0.031" if I remember correctly) was like 0.001" FWIW
Re: Cam endplay math? [Re: astjp2] #1076056
09/16/11 09:24 PM
09/16/11 09:24 PM
NC
440Jim Offline
440Jim  Offline
NC
Your math looks right to me.
But....
I agree with Andy you likely won't crush the gasket that much.
And I don't think you are going to get a clay reading within plus or minus 0.005"
Third, depending on the timing cover stiffness, that will help you determine the desired end play. i.e. a stock timing cover will flex a bunch, so you don't need much end play. A cast aluminum cover won't flex much, so you need a couple thousandths more.
Re: Cam endplay math? [Re: 440Jim] #1076057
09/16/11 10:18 PM
09/16/11 10:18 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
there is a .045 4130 chromoly plate welded inside the stock cover which is shaped like the original V recess. I just hope that I can shimm up any extra with my .006 shims....
Re: Cam endplay math? [Re: AndyF] #1076058
09/16/11 10:36 PM
09/16/11 10:36 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Andy, your cover is wonderful and excellent quality, just beyond my price range for this engine. Hopefully I can get one on my next hemi! Tim
Re: Cam endplay math? [Re: astjp2] #1076059
09/17/11 08:44 PM
09/17/11 08:44 PM
NC
440Jim Offline
440Jim  Offline
NC
I did that for a friend of mine back in 2004 when he built his roller cam, Indy headed, big block. It works fine, but any off the self button needs more taken off when it is welded to the inside. But it looks nicer that way after the motor is put together. We used a dial indicator on the cam during assembly to set the end play. I forget the number, but it was pretty tight since the cover will still flex some.
