Request: Parts Catalog 1969-1971 edition(s) #1075094
09/14/11 03:59 PM
09/14/11 03:59 PM
South, FL
cudaized Offline OP
cudaized  Offline OP
South, FL
Can anyone look up a part number for me?
Part number is: 2808142
Application: 1970 `cuda
I would like to see if it shows up in the 1969-71 Parts Catalog edition(s). Could you post a scan of that page?
I have the JANUARY 1972 edition. [81-690-1000] which supersedes 81-690-0955. In my Parts Catalog, the same part shows part number: 3417412
Thank you.
Ola
Re: Request: Parts Catalog 1969-1971 edition(s) [Re: cudaized] #1075095
09/14/11 04:01 PM
09/14/11 04:01 PM
South, FL
cudaized Offline OP
cudaized  Offline OP
South, FL
Re: Request: Parts Catalog 1969-1971 edition(s) [Re: cudaized] #1075096
09/14/11 07:12 PM
09/14/11 07:12 PM
New State
kidmopar Offline
kidmopar  Offline
New State
Thank you.
Ola
What the heck is it? Would help in finding.....
Re: Request: Parts Catalog 1969-1971 edition(s) [Re: cudaized] #1075097
09/14/11 08:33 PM
09/14/11 08:33 PM
Arizona
az426john Offline
az426john  Offline
Arizona
I looked in the numerical listings in the parts books I have access to for 1968 - 1971 and part number 2808142 was not shown.
Re: Request: Parts Catalog 1969-1971 edition(s) [Re: az426john] #1075098
09/14/11 09:35 PM
09/14/11 09:35 PM
New State
kidmopar Offline
kidmopar  Offline
New State
I did to , that's why I asked: WHAT IS IT?
Re: Request: Parts Catalog 1969-1971 edition(s) [Re: cudaized] #1075099
09/14/11 10:16 PM
09/14/11 10:16 PM
PA
BS27ROB Offline
BS27ROB  Offline
PA
Hi Ola,
Not much help, but in my catalog (March 71, 81-690-0948) it is the 3417412 number.
Cy
Re: Request: Parts Catalog 1969-1971 edition(s) [Re: BS27ROB] #1075100
09/15/11 03:13 PM
09/15/11 03:13 PM
NY
twodoorpost Offline
twodoorpost  Offline
NY
1970 only FSM (May 1970 81-690-0896) also shows 3417412.
Re: Request: Parts Catalog 1969-1971 edition(s) [Re: twodoorpost] #1075101
09/15/11 04:07 PM
09/15/11 04:07 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
That may be a casting number as you know Ola, and may not be the actual part number.
Sometimes part number and casting number vary.
Re: Request: Parts Catalog 1969-1971 edition(s) [Re: mccannix] #1075102
09/15/11 06:41 PM
09/15/11 06:41 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What he said
Re: Request: Parts Catalog 1969-1971 edition(s) [Re: JohnRR] #1075103
09/15/11 09:05 PM
09/15/11 09:05 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
And in most cases but not always only one number off.
Re: Request: Parts Catalog 1969-1971 edition(s) [Re: JohnRR] #1075104
09/15/11 09:19 PM
09/15/11 09:19 PM
western australia
1cuda Offline
1cuda  Offline
western australia
i`ll get back to you on it when i find more time-looks like a rear panel for e body.
all the best
frank
Re: Request: Parts Catalog 1969-1971 edition(s) [Re: cudaized] #1075105
09/16/11 10:08 AM
09/16/11 10:08 AM
western australia
1cuda Offline
1cuda  Offline
western australia
2808142 doesn`t come up for me either-my parts book is dated december 1970 3417412 seems to be the rear tail panel on a cuda.
sorry it doesn`t help much
all the best
frank
Re: Request: Parts Catalog 1969-1971 edition(s) [Re: BS27ROB] #1075106
09/16/11 10:29 AM
09/16/11 10:29 AM
South, FL
cudaized Offline OP
cudaized  Offline OP
South, FL
Hi Ola,
Cy
Thank you Cy. I appreciate your help.
Re: Request: Parts Catalog 1969-1971 edition(s) [Re: kidmopar] #1075107
09/16/11 10:33 AM
09/16/11 10:33 AM
South, FL
cudaized Offline OP
cudaized  Offline OP
South, FL
Thanks for looking Kevin.
It is an NOS 70-71 `cuda tail panel, without any part numbers stenciled on it, or parts tag taped on it.
Re: Request: Parts Catalog 1969-1971 edition(s) [Re: az426john] #1075108
09/16/11 10:34 AM
09/16/11 10:34 AM
South, FL
cudaized Offline OP
cudaized  Offline OP
South, FL
Thank you for looking John.
Re: Request: Parts Catalog 1969-1971 edition(s) [Re: twodoorpost] #1075109
09/16/11 10:37 AM
09/16/11 10:37 AM
South, FL
cudaized Offline OP
cudaized  Offline OP
South, FL
Thank you for looking Steve.
Re: Request: Parts Catalog 1969-1971 edition(s) [Re: mccannix] #1075110
09/16/11 11:14 AM
09/16/11 11:14 AM
South, FL
cudaized Offline OP
cudaized  Offline OP
South, FL
Terry,
This has to be the case. I have seen several NOS tail panels and all but two have had the 3417412 number stenciled onto it. Different colors: light gray, dark gray, red oxide, dark red oxide. Some still have the parts bin locator tag that identifies the part number, still taped to the piece.
The NOS panel that I have, and one additional one that I have looked at, are the only two that I have seen without the 3417412 number. Both of these have the 2808142 number stamped into the rear, bottom lip (trunk pan attachment area). Silly me, I should have made note to see if the 3417412 stenciled ones have the 2808142 stamped into it?
Does anyone have an NOS panel to look at, maybe see if it has these same features.
Does anyone know what the S15 A1 stamped information is? I think that I know, but want to be certain.
My initial thoughts were: The panel that I have may be an early example of a replacement part, instead of the [common] ones that were occasionally for sale these past 10-15 years. I have the same scenario with an NOS 1970 trunk pan. Usually you see the late 71-74 pans for sale. I have one that is an early 1970 part (date stencil and proper shock access holes). I thought that this tail panel might be a similar situation. Early vs. later. Maybe the initial part numbers were different? Thus my question for access to the early versions of the Parts Catalog.
Thank you all for your time on this search. I can only assume that the ONLY correct number is 3417412.
Ola
1970 `cuda340 convertible 4-speed Rallye Red with Red interior
cudaized.com
1970-71 Plymouth and Dodge E-Body Convertible Registry
ebodyconvertibleregistry.com
Re: Request: Parts Catalog 1969-1971 edition(s) [Re: JohnRR] #1075111
09/16/11 11:28 AM
09/16/11 11:28 AM
South, FL
cudaized Offline OP
cudaized  Offline OP
South, FL
What he said
I'll agree. Thanks John.
Re: Request: Parts Catalog 1969-1971 edition(s) [Re: 62maxwgn] #1075112
09/16/11 11:31 AM
09/16/11 11:31 AM
South, FL
cudaized Offline OP
cudaized  Offline OP
South, FL
True. Apparently, not on this tail panel.
Re: Request: Parts Catalog 1969-1971 edition(s) [Re: 1cuda] #1075113
09/16/11 11:33 AM
09/16/11 11:33 AM
South, FL
cudaized Offline OP
cudaized  Offline OP
South, FL
all the best
frank
Thank you for looking Frank.
