Re: Request: Parts Catalog 1969-1971 edition(s)
[Re: cudaized]
#1075096
09/14/11 07:12 PM
09/14/11 07:12 PM
Posts: 3,810 New State
kidmopar
New State
Can anyone look up a part number for me? Part number is: 2808142 Application: 1970 `cuda
I would like to see if it shows up in the 1969-71 Parts Catalog edition(s). Could you post a scan of that page?
I have the JANUARY 1972 edition. [81-690-1000] which supersedes 81-690-0955. In my Parts Catalog, the same part shows part number: 3417412
Thank you.
Ola
What the heck is it? Would help in finding.....
[Re: az426john]
#1075098
09/14/11 09:35 PM
09/14/11 09:35 PM
kidmopar
New State
I looked in the numerical listings in the parts books I have access to for 1968 - 1971 and part number 2808142 was not shown.
I did to , that's why I asked: WHAT IS IT?
[Re: mccannix]
#1075102
09/15/11 06:41 PM
09/15/11 06:41 PM
Posts: 74,907 U.S.S.A.
JohnRR
U.S.S.A.
That may be a casting number as you know Ola, and may not be the actual part number. Sometimes part number and casting number vary.
[Re: cudaized]
#1075105
09/16/11 10:08 AM
09/16/11 10:08 AM
Posts: 641 western australia
1cuda
western australia
2808142 doesn`t come up for me either-my parts book is dated december 1970 3417412 seems to be the rear tail panel on a cuda. sorry it doesn`t help much all the best frank
[Re: BS27ROB]
#1075106
09/16/11 10:29 AM
09/16/11 10:29 AM
Posts: 2,309 South, FL
cudaized
South, FL
Hi Ola,
Not much help, but in my catalog (March 71, 81-690-0948) it is the 3417412 number.
Cy
Thank you Cy. I appreciate your help.
[Re: kidmopar]
#1075107
09/16/11 10:33 AM
09/16/11 10:33 AM
cudaized
South, FL
Thanks for looking Kevin.
It is an NOS 70-71 `cuda tail panel, without any part numbers stenciled on it, or parts tag taped on it.
[Re: az426john]
#1075108
09/16/11 10:34 AM
09/16/11 10:34 AM
cudaized
South, FL
Thank you for looking John.
[Re: twodoorpost]
#1075109
09/16/11 10:37 AM
09/16/11 10:37 AM
cudaized
South, FL
1970 only FSM (May 1970 81-690-0896) also shows 3417412.
Thank you for looking Steve.
[Re: mccannix]
#1075110
09/16/11 11:14 AM
09/16/11 11:14 AM
cudaized
South, FL
Terry,
This has to be the case. I have seen several NOS tail panels and all but two have had the 3417412 number stenciled onto it. Different colors: light gray, dark gray, red oxide, dark red oxide. Some still have the parts bin locator tag that identifies the part number, still taped to the piece. The NOS panel that I have, and one additional one that I have looked at, are the only two that I have seen without the 3417412 number. Both of these have the 2808142 number stamped into the rear, bottom lip (trunk pan attachment area). Silly me, I should have made note to see if the 3417412 stenciled ones have the 2808142 stamped into it?
Does anyone have an NOS panel to look at, maybe see if it has these same features. Does anyone know what the S15 A1 stamped information is? I think that I know, but want to be certain.
My initial thoughts were: The panel that I have may be an early example of a replacement part, instead of the [common] ones that were occasionally for sale these past 10-15 years. I have the same scenario with an NOS 1970 trunk pan. Usually you see the late 71-74 pans for sale. I have one that is an early 1970 part (date stencil and proper shock access holes). I thought that this tail panel might be a similar situation. Early vs. later. Maybe the initial part numbers were different? Thus my question for access to the early versions of the Parts Catalog.
Thank you all for your time on this search. I can only assume that the ONLY correct number is 3417412.
Ola
[Re: JohnRR]
#1075111
09/16/11 11:28 AM
09/16/11 11:28 AM
cudaized
South, FL
What he said
I'll agree. Thanks John.
[Re: 62maxwgn]
#1075112
09/16/11 11:31 AM
09/16/11 11:31 AM
cudaized
South, FL
And in most cases but not always only one number off.
True. Apparently, not on this tail panel.
[Re: 1cuda]
#1075113
09/16/11 11:33 AM
09/16/11 11:33 AM
cudaized
South, FL
Thank you for looking Frank.
