Re: 8 3/4 vs Dana 60 weight difference?
[Re: mokid]
#1075001
09/14/11 06:56 PM
09/14/11 06:56 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Same set up I have in my Barracuda, But I still can't change gears at the track. 9 inch all the way
When was the last time you changed gears at the track... I've got a 8 3/4 in the P-Body and a 9" in the Rampage and I've NEVER changed gears at the track ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1075002
09/14/11 07:49 PM
09/14/11 07:49 PM
Challenger 1
Cincinnati, Ohio
Sure would be nice to be able to, if you hurt a rearend on a Fri at a 3 day race. I know I have more than once in my dragsters. I have ran 2 different gear sets during TNT.
[Re: Challenger 1]
#1075003
09/14/11 09:59 PM
09/14/11 09:59 PM
Posts: 1,169 MI
68shifter
MI
![](http://i953.photobucket.com/albums/ae16/68shifter/securedownload9.jpg) This is a Dana I finished tonight. Everything new except the housing - A body width. Posi, green bearings, 35 spline dr. diff axles, 11" brake setup etc. As pictured with perches and lines but no fluid was - 240lbs Sorry, but no 8-3/4 to compare to. Last year I put Wilwoods on my Dana and lost 45 lbs, so getting under 200 no problem.
68' Barracuda (4 speed)
64' Savoy (4 speed)
65' Satellite (girl tranny)
[Re: Challenger 1]
#1075005
09/14/11 10:06 PM
09/14/11 10:06 PM
Posts: 8,016 Polson, MT
DoctorDiff
Polson, MT
"Why would you want to run a heavy dana 60 that have few aftermarket parts made for them with limited gear ratios?"
Heavy?? Few aftermarket parts?? Limited gear ratios??
A NEW Dana 60 weighs about the same, costs less, and is MORE EFFICIENT than a COMPARABLE 9".
Commonly available Dana 60 gear ratios:
3.54, 3.55, 3.73, 3.90, 4.09, 4.10, 4.30, 4.56, 4.88, 5.13, 5.38, 5.86, 6.17, 6.50, 7.17
Commonly available Dana 60 spools:
35 spline 40 spline
Commonly available Dana 60 traction differentials:
30 spline 35 spline 40 spline
As far as I know, there are only 3 35 spline traction differentials available for a 9" and NO 40 spline units.
Unless you are talking about light duty 28 spline street/cirle track gears, few ratios are available for "big pinion" 9" and 9.5" rears.
Dana 60s are very strong street/strip rears. Once again, application is everything.
[Re: 68shifter]
#1075006
09/14/11 10:09 PM
09/14/11 10:09 PM
MR_P_BODY
Do you have a P/N for the Y block/vent... I still need to put one on my diff ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1075007
09/14/11 10:11 PM
09/14/11 10:11 PM
Posts: 1,169 MI
68shifter
MI
Mr. P I dont on me. But its for a 76 Powerwagon front axle 4wd. Any advance etc for $18, usually a day to get.
PN - 77171Z from autozones website. They list it as an inner. Should be a Dorman number
64' Savoy (4 speed)
[Re: 68shifter]
#1075008
09/14/11 10:16 PM
09/14/11 10:16 PM
MR_P_BODY
Thanks... I'll hit the parts store tomorrow ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1075009
09/14/11 10:23 PM
09/14/11 10:23 PM
Posts: 20,669 in a cattle trailer down by th...
Guitar Jones
As I weighed my aluminum center A body 8.75 with a steel spool to a Ford truck Dana housing, bare, unshortened there was a 50 pound difference. No brakes on either one but the Dana housing did still have the full floating ends on it. If I had it to do over again I'd have a Dana in my car. With a pro gear I'd probably never break it and if I have to do major work at a track, I'm taking it home. Breaking something at the track is one thing but I've driven a lot of miles just to red light in the first round so what's the big deal, I can't fix the red light. If it's something simple I'll fix it, if it's major it's not going to be a permanent repair at the track anyway so it's just going home. Might just as well drink a few beers and watch the rest of you for awhile. ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: Guitar Jones]
#1075010
09/14/11 10:37 PM
09/14/11 10:37 PM
MR_P_BODY
I have a alum center 8 3/4 with back brace, steel spool,narrowed and disc brakes.... I never did weigh it but its alot light than the dana I narrowed for a buddies car... basically the same set up
[Re: DoctorDiff]
#1075012
09/15/11 09:29 AM
09/15/11 09:29 AM
Posts: 3,943 Melbourne.....Oz-land
Moparmal
35 spline 40 spline
The Dr is 'in'. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: 340B5]
#1075014
09/15/11 03:27 PM
09/15/11 03:27 PM
Posts: 5,080 organ
maximum entropy
organ
i've broken an 8 3/4. i've broken a 9". i put a dana in, and it runs EXACTLY the same et. exactly. mr dana laughs at my attempts to hurt him. i recommend the dana. get close on your gear ratio, and fine tune using tire diameter (how you should be doing it anyway).
[Re: WheelsUp73]
#1075015
09/15/11 05:30 PM
09/15/11 05:30 PM
Posts: 834 Beavercreek, Ohio
OA5599
Beavercreek, Ohio
30 lbs-60 lbs right over the wheels where ya need it.
Not when its "unsprung" weight !!!
Agree 100%.
You lost me. It's primarily a street car that sees track 3 or 4 times a year. Also, I understand why some of you recommend a 9", but the Dana is bought and paid for. 35 spline with power lock and a 4.10. No desire to gear swap...just bought it so I would get more sleep the night before raceday. Thanks for all of the responses. We will weigh both and post numbers when it comes time to do the swap.
[Re: OA5599]
#1075016
09/15/11 06:22 PM
09/15/11 06:22 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
For a A body why not just run the 8 3/4? I have a 8 3/4 in my B body seems to work good! 35 spline axles, spool, m/w cap and back braced. ![](/ubbthreads/images/graemlins/Twocents.gif) Iknow the thread says whats the weight difference! ![](/ubbthreads/images/graemlins/stirthepot.gif)
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#1075017
09/15/11 07:40 PM
09/15/11 07:40 PM
Posts: 2,177 ill
dennismopar73
ill
and the debate goes on, 8 3/4 is a very strong carrier, if set up right. a dana does weigh more thats a fact , but the hp it gains far outwieghs that issue, i have run both, and have realy picked up et by going with a dana, gear for gear change. i cant say nothin for 9" i figure they belong to ford, so i leave them there ![](/ubbthreads/images/graemlins/wave.gif)
[Re: dennismopar73]
#1075018
09/15/11 08:37 PM
09/15/11 08:37 PM
Posts: 5,895 Florida
Locomotion
I've heard of Mopar Stock racers do the comparison, compensated for the weight so the car maintained the same total weight, and the car ran the same! The ring & pinion relationship in the housing is more efficient in a Dana 60. ![](/ubbthreads/images/graemlins/Twocents.gif) Personally, I think the "unsprung weight" issue has been overblown in drag racing involving most cars. While I'm sure it's a factor, the "action" of that weight is minimal during a drag strip run when compared to a circle track or road course car where suspension movement is constant as well as constantly variable. But the faster you go on a drag strip, the more important it does become as small surface imperfections have to be compensated for quickly - i.e.: Pro Stock, Funny Car, Top Fuel, etc. The unsprung weight of wheels and tires is a different situation and more important. That weight is not only unsprung, but it is rotating weight with a lot of it a good distance from the center of rotation, similar to the rotation of a crankshaft and its counterweights.
