Page 1 of 3 1 2 3
8 3/4 vs Dana 60 weight difference? #1074979
09/14/11 01:10 PM
09/14/11 01:10 PM
Beavercreek, Ohio
OA5599 Offline OP
OA5599  Offline OP
Beavercreek, Ohio
All things being equal, does anyone know the weight of a complete assembled 8 3/4, and the weight of a Dana? Doing the swap this winter, and wondered what kind of weight gain I am looking at.
Re: 8 3/4 vs Dana 60 weight difference? [Re: OA5599] #1074980
09/14/11 01:59 PM
09/14/11 01:59 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
60lbs
Re: 8 3/4 vs Dana 60 weight difference? [Re: scatpacktom] #1074981
09/14/11 02:17 PM
09/14/11 02:17 PM
Renton Washington
Triple Threat Offline
Renton Washington
I went from a 8 3/4 with sure grip to a Dana with a spool and only gained 30 pounds.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: 8 3/4 vs Dana 60 weight difference? [Re: Triple Threat] #1074982
09/14/11 02:35 PM
09/14/11 02:35 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
30 lbs-60 lbs right over the wheels where ya need it.
Yeah, it's got a smallblock.
Re: 8 3/4 vs Dana 60 weight difference? [Re: 340B5] #1074983
09/14/11 02:39 PM
09/14/11 02:39 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
30 pounds is a ton on a race car, a ton.
Re: 8 3/4 vs Dana 60 weight difference? [Re: 340B5] #1074984
09/14/11 02:42 PM
09/14/11 02:42 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Some of the weight difference can be diminished by changing a few components. 10" drums instead of 11" were worth 20-something. Then there's always other places...spool instead of a diff, drag discs instead of drums, stamped aluminum cover instead of cast, and so on
Rich H.
Esse Quam Videri
Re: 8 3/4 vs Dana 60 weight difference? [Re: OA5599] #1074985
09/14/11 02:46 PM
09/14/11 02:46 PM
It depends on which parts in each one, if you are using the same brakes and a posi unit versus a spool the weight differences could be as small as 20 lbs, if your going from a A body 8 3/4 with a spool to a Dana 60 with B body brakes and a posi it will be more It also depends on which Dana 60 housing your going to use
Re: 8 3/4 vs Dana 60 weight difference? [Re: Cab_Burge] #1074986
09/14/11 02:55 PM
09/14/11 02:55 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
As a side note the Dana is a more efficient axle. The ET difference is small.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: 8 3/4 vs Dana 60 weight difference? [Re: OA5599] #1074987
09/14/11 02:56 PM
09/14/11 02:56 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
honest true story here! my back has been wrecked for 3 months because of a dana!!!!! i'd say 50 to 70lbs diff between that and my bullet proof 8 3/4...the pain down my leg reminds me of DANA~!
Re: 8 3/4 vs Dana 60 weight difference? [Re: Challenger 1] #1074988
09/14/11 03:17 PM
09/14/11 03:17 PM
Renton Washington
Renton Washington
IF we're talking street strip cars that bracket race like mine and the OP's, 30# aint much. The stereo components I just removed from my car weighed 90#.
But you are correct, 30# on a heads up dedicated race car such as your TAD is a bunch.
-Dustin
Re: 8 3/4 vs Dana 60 weight difference? [Re: sixpackbee] #1074989
09/14/11 03:57 PM
09/14/11 03:57 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I went from a 4.30 geared 8 3/4 to a 4.10 geared Strange S-60 and got quicker. This a pump gas stroked small block street/strip car. Real race cars may have different results.
Re: 8 3/4 vs Dana 60 weight difference? [Re: justinp61] #1074990
09/14/11 04:04 PM
09/14/11 04:04 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Do the Dana....
You get a stronger, more efficient rear and if weight is a big issue, gundrilled and scalloped axles with titanium studs, lightened gear and spool, lightweight brakes and cover.
Re: 8 3/4 vs Dana 60 weight difference? [Re: jim sciortino] #1074991
09/14/11 04:47 PM
09/14/11 04:47 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Not when its "unsprung" weight !!!
Re: 8 3/4 vs Dana 60 weight difference? [Re: OA5599] #1074992
09/14/11 05:57 PM
09/14/11 05:57 PM
Cincinnati, Ohio
Cincinnati, Ohio
If your gonna take out a 8 3/4, then invest in a 9" and have a more modern race car with plenty of gear ratios available.
Why would you want to run a heavy dana 60 that have few aftermarket parts made for them with limited gear ratios?? Why?
Re: 8 3/4 vs Dana 60 weight difference? [Re: OA5599] #1074993
09/14/11 06:17 PM
09/14/11 06:17 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
45# at the most...Dana is peace of mind...install it and don't worry about it again.
Nautilus Racing-
Re: 8 3/4 vs Dana 60 weight difference? [Re: Challenger 1] #1074994
09/14/11 06:35 PM
09/14/11 06:35 PM
St.Louis, Mo.
mokid Offline
mokid  Offline
St.Louis, Mo.
Your right on that one, I wish I would have went to a 9inch but wanted to stick with all mopar. Big mistake
Re: 8 3/4 vs Dana 60 weight difference? [Re: mokid] #1074995
09/14/11 06:40 PM
09/14/11 06:40 PM
Cincinnati, Ohio
Cincinnati, Ohio
Just trying to help guys see the big picture, who cares who makes it?
Re: 8 3/4 vs Dana 60 weight difference? [Re: Chris2581] #1074996
09/14/11 06:41 PM
09/14/11 06:41 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
My Dana 60 ended up 15 lbs. lighter than the 8 3/4".
Mark Williams 40 spline gun-drilled axles, aluminum spool, and Aerospace discs in place
of the 11" x 3" drums. The brakes was the big savings.(45 lbs. lighter)
Re: 8 3/4 vs Dana 60 weight difference? [Re: S/ST 3040] #1074997
09/14/11 06:42 PM
09/14/11 06:42 PM
S/ST 3040 Offline
S/ST 3040  Offline
Re: 8 3/4 vs Dana 60 weight difference? [Re: Stanton] #1074998
09/14/11 06:42 PM
09/14/11 06:42 PM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
Agree 100%.
Page 1 of 3 1 2 3
