Having trouble with Rally dash - Cuda #1073070
09/11/11 01:55 PM
09/11/11 01:55 PM
Houston Texas
PAINT IT BLACK Offline OP
Got a CHIP on my shoulder
Houston Texas
I have taken this dash apart many times. I recently installed a new clock cable and now I can't get the knob to screw on (the cable is too deep behind the fascia). I don't have my original cable anymore - but it seems like this cable is too short on the front side. I got the cable from Dashworx but I figure its the same as the one from Year One....?
Are there different length cables between E bodys? What am I missing?
Re: Having trouble with Rally dash - Cuda [Re: PAINT IT BLACK] #1073071
09/11/11 02:24 PM
09/11/11 02:24 PM
Houston Texas
Houston Texas
BTW the threads on the cable aren't stripped because I can screw it on when the fascia isn't in the way.
I am frustrated as hell... It'll almost screw on, but its just about 1/8" too deep.
Re: Having trouble with Rally dash - Cuda [Re: PAINT IT BLACK] #1073072
09/11/11 02:51 PM
09/11/11 02:51 PM
Houston Texas
Houston Texas
My response to a frustrating situation in a hot/humid environment:
A couple of beers and an angle grinder. I fixed you, you piece of #U%k*ng $#!+ !!!!!
Re: Having trouble with Rally dash - Cuda [Re: PAINT IT BLACK] #1073073
09/11/11 04:04 PM
09/11/11 04:04 PM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
Here is your solution.
Take the brass threaded end and screw it by turning it into the plastic tube more.
This will reveal more of the threaded shaft and you will now be able to
put the knob on.It simply was not adjusted properly when made.
Very simple fix.
Jules
Re: Having trouble with Rally dash - Cuda [Re: JulesdaWiperman] #1073074
09/11/11 10:48 PM
09/11/11 10:48 PM
Houston Texas
Houston Texas
Thanks. Wish I'd have known that... its all installed now. The knob still doesn't stick out enough.... we'll see if I feel like taking it all apart tomorrow...
