2-bolt M/C for 4 wheel manual disc conversion? #1072129
09/09/11 02:24 PM
09/09/11 02:24 PM
Erda, UT
67Charger Offline OP
Erda, UT
I finally figured out why I have so little rear brake... I'm using the m/c from a truck with manual disc/drum so the rears are not getting the needed volume.
What is the OEM application I should look for, bearing in mind I need the O-ring retaining groove?
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: 2-bolt M/C for 4 wheel manual disc conversion? [Re: 67Charger] #1072130
09/09/11 02:38 PM
09/09/11 02:38 PM
BDW Online content
BDW  Online Content
Saved this from a Dr Diff post
Re: 2-bolt M/C for 4 wheel manual disc conversion? [Re: 67Charger] #1072131
09/09/11 02:55 PM
09/09/11 02:55 PM
Erda, UT
Erda, UT
...right, and that's the truck I'm using it from. None of those are 4 wheel disc. The rears are not getting the volume they need from a drum m/c.
Re: 2-bolt M/C for 4 wheel manual disc conversion? [Re: 67Charger] #1072132
09/09/11 03:06 PM
09/09/11 03:06 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I wouold give Cass, a.k.a. Dr Diff a call, give him te specifics of your brake system and see what he says. He's a very knowlegable man.
I have two complete 4 wheel disc conversions, one power & one manual, using his recomended parts set-ups. Both are amazingly balanced, predictable and cost-effective.
Re: 2-bolt M/C for 4 wheel manual disc conversion? [Re: 67Charger] #1072133
09/09/11 04:06 PM
09/09/11 04:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I'm curious why you think the rears aren't getting the needed volume? Is the pedal bottoming out?
Unless the MC bore is stepped, the needed volume will be supplied by a longer pedal stroke.
Re: 2-bolt M/C for 4 wheel manual disc conversion? [Re: John_Kunkel] #1072134
09/09/11 06:18 PM
09/09/11 06:18 PM
What John said, was wondering that myself as usually they have 2 much bias
Re: 2-bolt M/C for 4 wheel manual disc conversion? [Re: RapidRobert] #1072135
09/09/11 08:31 PM
09/09/11 08:31 PM
Tampa FL
hemibeep Offline
hemibeep  Offline
Tampa FL
i have the wilwood 4 piston on all corners. using 1 1/8 mc. I had to turn down rear brakes with adjustable prop valve. car would not stop as rear was trying to do all of the work. I am thinking of going to the 1 1/32 for more stroke and higher pressure. my current pedal travel is short and it takes a lot of leg to make hard stop. It is all manual setup.
Re: 2-bolt M/C for 4 wheel manual disc conversion? [Re: hemibeep] #1072136
09/09/11 11:59 PM
09/09/11 11:59 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
the modern mopar master is set up 70/30 bias---did you bypass the line divider for the rear brake line? you need to for proper funtion-the line divider may be restricting by doing the 70/30 bias over again--- and disc brakes dont need a big volume of fluid to move---the pads are riding on the rotors all the time--they barely move when you hit the petal---and on the other hand drum brakes need alot of fluid to apply the shoes------i am running my 64 with the d150 manual master and 4 wheel disc brakes---works great----on my 71 dodge military truck i run the same master on dana 60 with 4 wheel disc brakes and they work and if you really wanted to we could take the original tiny master from my 64 and run 4 wheel disc brakes off of it--it would take a while to bleed it out because the resevoir is small ---and hey can anybody tell me how wilwood got there start?----bob
Re: 2-bolt M/C for 4 wheel manual disc conversion? [Re: savoy64] #1072137
09/10/11 03:40 AM
09/10/11 03:40 AM
Erda, UT
Erda, UT
I have NO prop valves, either factory or aftermarket. The reason I don't think the back brakes are working is after 200 miles of road racing at 140 mph and probably 100 1/4 mile passes I can still see the factory grind pattern in the rear rotoer, whereas the front rotors are worn about .030" each and at about 80% pad life.
Re: 2-bolt M/C for 4 wheel manual disc conversion? [Re: 67Charger] #1072138
09/10/11 05:05 AM
09/10/11 05:05 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Throwing this out...
Heavy car
high center of gravity
lot of front end weight (?60/40?)
What's the size of your front torsion bars. Could be transfering a lot of weight to the front too.
Have you four corner scaled your car?
Re: 2-bolt M/C for 4 wheel manual disc conversion? [Re: 67Charger] #1072139
09/10/11 09:24 AM
09/10/11 09:24 AM
140 MPH , Well that would sure exp all the front weight transfer!
Re: 2-bolt M/C for 4 wheel manual disc conversion? [Re: RapidRobert] #1072140
09/10/11 02:29 PM
09/10/11 02:29 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
are you using that brass brake line divider?---in the older cars that is the prop and residual valve---when you disc up the rear you bypass it--if you car was a drum brake car you throw it away---or as i read what you are saying you ran all new brake lines front and rear and you used a plain T to split the front brakes-if the line to the rear of the car is still original i would suspect it is obstructed or pinched shut--bob
Re: 2-bolt M/C for 4 wheel manual disc conversion? [Re: savoy64] #1072141
09/10/11 02:51 PM
09/10/11 02:51 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
thought of one more idea---if everthing is new--sometimes guys mix up the brake lines---the front hole in the master goes to the rear brakes----the rear hole goes to the front brakes---bob
Re: 2-bolt M/C for 4 wheel manual disc conversion? [Re: 67Charger] #1072142
09/10/11 04:10 PM
09/10/11 04:10 PM
AndyF Offline
AndyF  Offline
Put a pressure gauge in both circuits and see what it says.
Re: 2-bolt M/C for 4 wheel manual disc conversion? [Re: AndyF] #1072143
09/10/11 04:15 PM
09/10/11 04:15 PM
As double R would say ding ding ding I do believe we have a winna EDIT U can get a 2000 lb psi gauge for $15 (likely 1/4" NPT male) & the hardest part is the proper fittings 2 connect it
Re: 2-bolt M/C for 4 wheel manual disc conversion? [Re: RapidRobert] #1072144
09/11/11 01:18 PM
09/11/11 01:18 PM
Erda, UT
Erda, UT
Thanks guys, and sorry for such a delay in replying. We've been in a 2 month thrash getting the second car ready for Silver State.
As I stated before, there are NO dividers, prop valves, adjustable whatevers, just m/c feeding lines. Front port to rear brake line, hits a tee on the rear axle and goes to the calipers. Rear port to flex line to line-lock to tee to front calipers. The systems NEVER meet.
Weight bias of the car is 54/46, T-bars were .925, now 1.12.
I will try to get gauges plumbed in and see what's going on up there.
Re: 2-bolt M/C for 4 wheel manual disc conversion? [Re: 67Charger] #1072145
09/11/11 01:25 PM
09/11/11 01:25 PM
& in the meantime take it out & slam on the brakes & see how close all 4 skid marks are 2 being equal which'll give you more real world info than even the gauge plus you'll have an ans today
