2-bolt M/C for 4 wheel manual disc conversion?
#1072129
09/09/11 02:24 PM
09/09/11 02:24 PM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
I finally figured out why I have so little rear brake... I'm using the m/c from a truck with manual disc/drum so the rears are not getting the needed volume.
What is the OEM application I should look for, bearing in mind I need the O-ring retaining groove?
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: 2-bolt M/C for 4 wheel manual disc conversion?
[Re: 67Charger]
#1072131
09/09/11 02:55 PM
09/09/11 02:55 PM
67Charger
Erda, UT
...right, and that's the truck I'm using it from. None of those are 4 wheel disc. The rears are not getting the volume they need from a drum m/c.
[Re: 67Charger]
#1072132
09/09/11 03:06 PM
09/09/11 03:06 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
I wouold give Cass, a.k.a. Dr Diff a call, give him te specifics of your brake system and see what he says. He's a very knowlegable man.
I have two complete 4 wheel disc conversions, one power & one manual, using his recomended parts set-ups. Both are amazingly balanced, predictable and cost-effective.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: 67Charger]
#1072133
09/09/11 04:06 PM
09/09/11 04:06 PM
Posts: 25,794 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I'm curious why you think the rears aren't getting the needed volume? Is the pedal bottoming out?
Unless the MC bore is stepped, the needed volume will be supplied by a longer pedal stroke.
[Re: John_Kunkel]
#1072134
09/09/11 06:18 PM
09/09/11 06:18 PM
RapidRobert
What John said, was wondering that myself as usually they have 2 much bias
[Re: savoy64]
#1072137
09/10/11 03:40 AM
09/10/11 03:40 AM
67Charger
Erda, UT
I have NO prop valves, either factory or aftermarket. The reason I don't think the back brakes are working is after 200 miles of road racing at 140 mph and probably 100 1/4 mile passes I can still see the factory grind pattern in the rear rotoer, whereas the front rotors are worn about .030" each and at about 80% pad life.
[Re: 67Charger]
#1072138
09/10/11 05:05 AM
09/10/11 05:05 AM
Posts: 27,468 So Cal
autoxcuda
So Cal
Throwing this out...
Heavy car high center of gravity lot of front end weight (?60/40?)
What's the size of your front torsion bars. Could be transfering a lot of weight to the front too.
Have you four corner scaled your car?
[Re: AndyF]
#1072143
09/10/11 04:15 PM
09/10/11 04:15 PM
RapidRobert
Put a pressure gauge in both circuits and see what it says.
As double R would say ding ding ding I do believe we have a winna EDIT U can get a 2000 lb psi gauge for $15 (likely 1/4" NPT male) & the hardest part is the proper fittings 2 connect it
[Re: RapidRobert]
#1072144
09/11/11 01:18 PM
09/11/11 01:18 PM
67Charger
Erda, UT
Thanks guys, and sorry for such a delay in replying. We've been in a 2 month thrash getting the second car ready for Silver State.
As I stated before, there are NO dividers, prop valves, adjustable whatevers, just m/c feeding lines. Front port to rear brake line, hits a tee on the rear axle and goes to the calipers. Rear port to flex line to line-lock to tee to front calipers. The systems NEVER meet.
Weight bias of the car is 54/46, T-bars were .925, now 1.12.
I will try to get gauges plumbed in and see what's going on up there.
