LCA Bushings Removal
#1071901
09/09/11 11:37 AM
09/09/11 11:37 AM
Posts: 3,288 Stroudsburg, PA
Erik
Stroudsburg, PA
Anyone have any tricks for pressing out the LCA bushings? I don't have a press, so maybe someone has a good tip. Thanks!
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: LCA Bushings Removal
[Re: 340SHORTY]
#1071903
09/09/11 12:22 PM
09/09/11 12:22 PM
Erik
Stroudsburg, PA
I did, and they had them for almost two months and did nothing other than let them sit on the floor. Hence why I have them at home and will do them myself.
[Re: hemi71x]
#1071906
09/09/11 12:44 PM
09/09/11 12:44 PM
Erik
Stroudsburg, PA
Thanks. I already pressed out the pivots, but don't remember the inner sleeve of the bushing coming out with them. I'll check this weekend. I already removed/installed the UCA bushings using hand tools made for that purpose (you can get them at Mancini). I will use them to install the LCA bushings, too. Getting the old ones out is the problem.
[Re: Erik]
#1071907
09/09/11 01:10 PM
09/09/11 01:10 PM
Posts: 21,453 It's a dry heat
gtx6970
It's a dry heat
Uppers are a piece of cake and can be R+R'd in a bench vice with sockets to press into and out of.
But on the lowers - 99% of the time the outer sleeve stays in . I use an air chisel to cut a slit in the side of the sleeve and pull it out.
Press the new bushing in the arm, then support the bushing fron the backside when pressing the pin back in or you will push the rubber/inner sleeve out of the bushing out the backside.
trust me, been there done that
[Re: Erik]
#1071908
09/09/11 06:01 PM
09/09/11 06:01 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Thanks!
No mention of replacements?...if your going with Poly (which I recommend) you need to leave the other bushing shells in the LCA, I just usually torch the rubber out, leaving the shell, then glassbead the assy, then paint, or cosmoline, or both,...the poly bushings just slide in with lube, depending on the poly bushing of choice some require the inner sleeve stay on the pivot shaft as well, that installs by hand with lube as well,...so basically with poly you just need to burn out the rubber, and clean up the assys/install bushings by hand...
if your doing factory style, I still like to torch out the rubber, collaspe the outer shell in the LCA to remove, and carefully grind a slot on the inner sleeve to remove the inner shell from the pivot shaft,....a press is the only correct way to install a new bushing,....do the poly, you'll never look at a factory bushing again
[Re: DAYCLONA]
#1071911
09/12/11 04:13 PM
09/12/11 04:13 PM
Erik
Stroudsburg, PA
Thanks!
Yes, the new bushings are poly. The ones I have are complete with shells, so I need to get the old shells out. All that is left in the control arm at this point is the outer shell. The old rubber pulled right out with no problems.
