Seat belt question
#1071875
09/09/11 09:41 AM
09/09/11 09:41 AM
Posts: 614 ont,canada
mopartuner
ont,canada
My car has race belts in it from when I ran 10.90 but they are out of date, but will these be ok to go out with my small motor and run some low 12 sec passes?
410 pump gas solis flat tappet cam 10.95 so far
Re: Seat belt question
[Re: aquamist60]
#1071877
09/09/11 10:33 AM
09/09/11 10:33 AM
Posts: 1,413 Newark,Ohio
kissmyaspen
Newark,Ohio
only need updated belts if you run 11.49. the belts i have in my dads car are about 5 years outdated. thats one of the smartest things NHRA has done IMO.
79 Dodge Aspen 12.265 at 109.75 MPH
67 Satellite NSS/E 11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street. '07, '10, '12 Mopar Nats runner-up Street.
[Re: kissmyaspen]
#1071878
09/09/11 12:13 PM
09/09/11 12:13 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
They only need to be with in the date IF your car is REQUIRED to have them per the rules.
If it's nor going fast enough per the rules to require them then the date doesn't apply.
[Re: WILD BILL]
#1071879
09/09/11 12:53 PM
09/09/11 12:53 PM
Posts: 1,532 off the grid
340B5
off the grid
I never did like that 2 yr rule. It's stupid.
I ran 11.90's then 11.70's later w/belts that were 7 yrs old.
The tech guy couldn't believe they were that old, because they looked almost new.
Common sense comes to play here. If they're ragged, replace them. I could only wish that the tracks would leave it up to the tech inspector to determine whether the belts were safe or not. I have better things to spend money on than belts that don't need replacing.
Yeah, it's got a smallblock.
[Re: kissmyaspen]
#1071881
09/09/11 02:52 PM
09/09/11 02:52 PM
mopartuner
ont,canada
Cool.........I found my old original belts to put in if that will make them happy,I should be o.k.Wish me luck,I haven't been able to race for about 4 years now(job change,wife's health)So I will need all the luck I can get.
[Re: mopartuner]
#1071882
09/09/11 04:31 PM
09/09/11 04:31 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I know with me that when I had stock belts in it they never said anything but with the race harness they wanted the right dated ones no matter what et I ran. Once you go with the race belts I believe they can make you run the dated ones if they want to hassle you. Ron
[Re: 383man]
#1071883
09/09/11 05:06 PM
09/09/11 05:06 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have heard that if you cut the SFI tag off its OK for slower than 11.50... dont know for FACT... I need 2 sets of new belts and I want to see if I can get a set re-webbed in black with no SFI sticker for the pass side of my Rampage(they have the max re-web on the hardware already... 5 times)
[Re: MR_P_BODY]
#1071884
09/09/11 05:53 PM
09/09/11 05:53 PM
Posts: 2,586 Illinois, Indiana, Louisiana
ProStDodge
10:5 DRIVER RESTRAINT SYSTEMS A quick-release, 3-inch driver restraint system, with a 2-inch crotch strap, meeting SFI Spec 16.1 is mandatory in all cars in competition required by the rules to have a roll bar or a roll cage. (Permitted in all other classes.) A 3-inch SFI Spec 16.5 driver restraint system is also acceptable wherever an SFI Spec 16.1 is mandatory or permitted. Driver restraint system must be clearly labeled as meeting SFI Spec 16.1 and be dated by manufacturer.
if you have a roll bar or cage, you need dated belts.
[Re: ProStDodge]
#1071885
09/09/11 08:15 PM
09/09/11 08:15 PM
MR_P_BODY
I had planned on using a dated belt on the drivers seat but I dont want to on the pass seat
[Re: MR_P_BODY]
#1071886
09/09/11 08:32 PM
09/09/11 08:32 PM
Posts: 248 Ohio
aquamist60
Ohio
I don't think you need to worry about the pass. seat. Been through Stock Elimn. tech many times and they've never checked to even see if the pass. seat had a belt.
[Re: ProStDodge]
#1071892
09/10/11 11:06 PM
09/10/11 11:06 PM
WILD BILL
BROOK PARK, OH
Wrong.
If you are REQUIRED by the rules to have a roll bar or cage the you need the belts.
