Seat belt question #1071875
09/09/11 09:41 AM
09/09/11 09:41 AM
ont,canada
mopartuner Offline OP
ont,canada
My car has race belts in it from when I ran 10.90 but they are out of date, but will these be ok to go out with my small motor and run some low 12 sec passes?
410 pump gas solis flat tappet cam 10.95 so far
Re: Seat belt question [Re: mopartuner] #1071876
09/09/11 09:55 AM
09/09/11 09:55 AM
Ohio
aquamist60 Offline
aquamist60  Offline
Ohio
If you are doing a local track and they know you, they "might" let you pass. Depends on who does the tech. I've had some pick the car apart and some just sign the form. Roll of the dice.
Re: Seat belt question [Re: aquamist60] #1071877
09/09/11 10:33 AM
09/09/11 10:33 AM
Newark,Ohio
kissmyaspen Offline
kissmyaspen  Offline
Newark,Ohio
only need updated belts if you run 11.49. the belts i have in my dads car are about 5 years outdated. thats one of the smartest things NHRA has done IMO.
79 Dodge Aspen
12.265 at 109.75 MPH
67 Satellite NSS/E
11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street.
'07, '10, '12 Mopar Nats runner-up Street.
Re: Seat belt question [Re: kissmyaspen] #1071878
09/09/11 12:13 PM
09/09/11 12:13 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
They only need to be with in the date IF your car is REQUIRED to have them per the rules.
If it's nor going fast enough per the rules to require them then the date doesn't apply.
Re: Seat belt question [Re: WILD BILL] #1071879
09/09/11 12:53 PM
09/09/11 12:53 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
I never did like that 2 yr rule. It's stupid.
I ran 11.90's then 11.70's later w/belts that were 7 yrs old.
The tech guy couldn't believe they were that old, because they looked almost new.
Common sense comes to play here. If they're ragged, replace them. I could only wish that the tracks would leave it up to the tech inspector to determine whether the belts were safe or not. I have better things to spend money on than belts that don't need replacing.
Yeah, it's got a smallblock.
Re: Seat belt question [Re: 340B5] #1071880
09/09/11 02:13 PM
09/09/11 02:13 PM
Newark,Ohio
kissmyaspen Offline
kissmyaspen  Offline
Newark,Ohio
i would rather trust 10 year old race belts than my 30 year old stock belts.
79 Dodge Aspen
67 Satellite NSS/E
11.83 @ 110
Re: Seat belt question [Re: kissmyaspen] #1071881
09/09/11 02:52 PM
09/09/11 02:52 PM
ont,canada
ont,canada
Cool.........I found my old original belts to put in if that will make them happy,I should be o.k.Wish me luck,I haven't been able to race for about 4 years now(job change,wife's health)So I will need all the luck I can get.
Re: Seat belt question [Re: mopartuner] #1071882
09/09/11 04:31 PM
09/09/11 04:31 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I know with me that when I had stock belts in it they never said anything but with the race harness they wanted the right dated ones no matter what et I ran. Once you go with the race belts I believe they can make you run the dated ones if they want to hassle you. Ron
Re: Seat belt question [Re: 383man] #1071883
09/09/11 05:06 PM
09/09/11 05:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have heard that if you cut the SFI tag off its OK
for slower than 11.50... dont know for FACT... I need
2 sets of new belts and I want to see if I can get a
set re-webbed in black with no SFI sticker for the
pass side of my Rampage(they have the max re-web
on the hardware already... 5 times)
Re: Seat belt question [Re: MR_P_BODY] #1071884
09/09/11 05:53 PM
09/09/11 05:53 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
10:5 DRIVER RESTRAINT SYSTEMS
A quick-release, 3-inch driver restraint system, with a 2-inch crotch strap, meeting SFI Spec 16.1 is mandatory in all cars in competition required by the rules to have a roll bar or a roll cage. (Permitted in all other classes.) A 3-inch SFI Spec 16.5 driver restraint system is also acceptable wherever an SFI Spec 16.1 is mandatory or permitted. Driver restraint system must be clearly labeled as meeting SFI Spec 16.1 and be dated by manufacturer.
if you have a roll bar or cage, you need dated belts.
Re: Seat belt question [Re: ProStDodge] #1071885
09/09/11 08:15 PM
09/09/11 08:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I had planned on using a dated belt on the drivers seat
but I dont want to on the pass seat
Re: Seat belt question [Re: MR_P_BODY] #1071886
09/09/11 08:32 PM
09/09/11 08:32 PM
Ohio
aquamist60 Offline
aquamist60  Offline
Ohio
I don't think you need to worry about the pass. seat. Been through Stock Elimn. tech many times and they've never checked to even see if the pass. seat had a belt.
Re: Seat belt question [Re: aquamist60] #1071887
09/09/11 08:40 PM
09/09/11 08:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I want belts over there just to make it street legal
Re: Seat belt question [Re: MR_P_BODY] #1071888
09/10/11 12:55 AM
09/10/11 12:55 AM
ProStDodge Offline
ProStDodge  Offline
The passenger seat belts do NOT need to have current dates.
I regularly ran my outdated sets in prostreet cars.
Re: Seat belt question [Re: 340B5] #1071889
09/10/11 01:32 AM
09/10/11 01:32 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i agree with 340b5. changing perfectly good belts is bull. u don't see the state making u change belts in ur daily driver every 2 yrs. just some more bull to suck more money from our pockets. stay safe, seeya.
Re: Seat belt question [Re: ProStDodge] #1071890
09/10/11 01:33 AM
09/10/11 01:33 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
But your the TECH GUY!!!!!!! who would have thought you were illegal.
Re: Seat belt question [Re: rowin4] #1071891
09/10/11 01:44 AM
09/10/11 01:44 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I know at my local track when I go to just a test & tune they actually tech you in while in the staging lanes and most of the time they never look at anything on my car as they just give me a number. It seems most cars at T & T's thats what they do unless the car really looks unsafe. Seems like most of the time they have alot of cars to tech and they just roll along trying to get everyone teched in before the staging lane moves. Ron
Re: Seat belt question [Re: ProStDodge] #1071892
09/10/11 11:06 PM
09/10/11 11:06 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Wrong.
If you are REQUIRED by the rules to have a roll bar or cage the you need the belts.
