Re: Solid Cams who runs them?
[Re: SCATPK]
#1071795
09/09/11 10:39 PM
09/09/11 10:39 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If your talking a road car I'd go hyd roller BUT stay away from the big lifts and fast ramps and just enjoy the car.... if you want FAST go solid roller and quit playing
[Re: SCATPK]
#1071799
09/09/11 11:27 PM
09/09/11 11:27 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
Don, it would be you with a story of despair and destruction! I have had good luck in the past with solid cams and thinking about stepping the power up on the gtx a bit. Look for me in Sac this weekend as I think I may take a run or two down the track and see if I remember how to drive the thing.
Why the heck do you want to step up the power? You have a beautiful car that is the envy of everyone that see's it.. You run some mighty impressive 11 second numbers for a street car.. AND you get 16 mpg driving the car on 1000 mile road trips..
And besides.. if you step up on the power, I'll have to do the same in the 73.. just so I can say I'm faster than you.. lol
[Re: SCATPK]
#1071800
09/10/11 12:26 AM
09/10/11 12:26 AM
Posts: 2,177 ill
dennismopar73
ill
[Re: Moparmal]
#1071802
09/10/11 12:41 AM
09/10/11 12:41 AM
Posts: 2,103 East Coast, NJ
fig426
East Coast, NJ
Solid flat here. 628 lift. Broke in with comp's additive. About 14 passes and 10 hard street miles. Changed the oil once so far with another pint of comp's additive. So far so good.
Chris from New Jersey
[Re: fig426]
#1071803
09/10/11 01:24 AM
09/10/11 01:24 AM
Posts: 3,685 South San Francisco, Ca
70sixpkrt
LEAVE IT ALONE!!!!!!! You might open up a can of worms.
[Re: rowin4]
#1071804
09/10/11 01:52 AM
09/10/11 01:52 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Forgot to add I broke in my cam on just the outer springs also. Then I used this tool to install the inner springs on the car. This tool worked great and made it easy installing the inners on the car. Ron
What brand of spring remover is that? Does it work on #7 valves?
I bought it from Mancini but I dont remember what brand it is. I just told them I wanted a good tool to replace valve springs on the car. I will have to look on their site and see if they show a pic of it. That just happens to be what they sent me as I did not point out what I wanted I just asked for the valve spring tool. I really like it as it makes the job so much easier then using the old screw type. Ron
[Re: 383man]
#1071805
09/10/11 03:11 AM
09/10/11 03:11 AM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
520 lift solid (racer brown) cam in the 360 engine in my duster. Best run was a 10.22 and stepping up to a 560 lift (racer brown) cam in the 408 stroker that will hopefully be in the 9's.
[Re: pittsburghracer]
#1071806
09/10/11 04:22 AM
09/10/11 04:22 AM
Posts: 3,210 robin hood country
deaks
robin hood country
Wow, a .520 lift cam runs 10.22, my 3200# Dart is slower than that with the .590. What is the spec and weight. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
