Re: Solid Cams who runs them? [Re: SCATPK] #1071795
09/09/11 10:39 PM
09/09/11 10:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If your talking a road car I'd go hyd roller BUT stay
away from the big lifts and fast ramps and just enjoy
the car.... if you want FAST go solid roller and quit
playing
Re: Solid Cams who runs them? [Re: SCATPK] #1071796
09/09/11 10:51 PM
09/09/11 10:51 PM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
Solid cam here Comp Cams .650 - 324.
Re: Solid Cams who runs them? [Re: 540dust] #1071797
09/09/11 11:12 PM
09/09/11 11:12 PM
OHIO THE HEART OF IT ALL
64hemi330sedan Offline
stx 21 racer brown in mine.i street drive and race it.
Re: Solid Cams who runs them? [Re: 64hemi330sedan] #1071798
09/09/11 11:23 PM
09/09/11 11:23 PM
IN
ahy Offline
ahy  Offline
IN
MM lobe solid flat tappet in a BB for me and love it. 9k miles running Rotella T + STP for lube. Lash is very steady and no problems.
Re: Solid Cams who runs them? [Re: SCATPK] #1071799
09/09/11 11:27 PM
09/09/11 11:27 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Don, it would be you with a story of despair and destruction! I have had good luck in the past with solid cams and thinking about stepping the power up on the gtx a bit. Look for me in Sac this weekend as I think I may take a run or two down the track and see if I remember how to drive the thing.
Why the heck do you want to step up the power? You have a beautiful car that is the envy of everyone that see's it.. You run some mighty impressive 11 second numbers for a street car.. AND you get 16 mpg driving the car on 1000 mile road trips..
And besides.. if you step up on the power, I'll have to do the same in the 73.. just so I can say I'm faster than you.. lol
Re: Solid Cams who runs them? [Re: SCATPK] #1071800
09/10/11 12:26 AM
09/10/11 12:26 AM
ill
dennismopar73 Offline
ill
racer brown cams for years stx 21
Re: Solid Cams who runs them? [Re: Jeepmon] #1071801
09/10/11 12:30 AM
09/10/11 12:30 AM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
Comp XS282S - Broke in with Comp Cam lube and Zinc additive.
I had a Hyd Comp cam which went to smoking on me...switched to the Comp Solid Flat Tappet , had no problems at break in, and it feels far "snappier" for a similar duration.
Re: Solid Cams who runs them? [Re: Moparmal] #1071802
09/10/11 12:41 AM
09/10/11 12:41 AM
East Coast, NJ
fig426 Offline
fig426  Offline
East Coast, NJ
Solid flat here. 628 lift. Broke in with comp's additive. About 14 passes and 10 hard street miles. Changed the oil once so far with another pint of comp's additive. So far so good.
Chris from New Jersey
Re: Solid Cams who runs them? [Re: fig426] #1071803
09/10/11 01:24 AM
09/10/11 01:24 AM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
LEAVE IT ALONE!!!!!!!
You might open up a can of worms.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Solid Cams who runs them? [Re: rowin4] #1071804
09/10/11 01:52 AM
09/10/11 01:52 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Forgot to add I broke in my cam on just the outer springs also. Then I used this tool to install the inner springs on the car. This tool worked great and made it easy installing the inners on the car. Ron
What brand of spring remover is that? Does it work on #7 valves?
I bought it from Mancini but I dont remember what brand it is. I just told them I wanted a good tool to replace valve springs on the car. I will have to look on their site and see if they show a pic of it. That just happens to be what they sent me as I did not point out what I wanted I just asked for the valve spring tool. I really like it as it makes the job so much easier then using the old screw type. Ron
Re: Solid Cams who runs them? [Re: 383man] #1071805
09/10/11 03:11 AM
09/10/11 03:11 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
520 lift solid (racer brown) cam in the 360 engine in my duster. Best run was a 10.22 and stepping up to a 560 lift (racer brown) cam in the 408 stroker that will hopefully be in the 9's.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Solid Cams who runs them? [Re: pittsburghracer] #1071806
09/10/11 04:22 AM
09/10/11 04:22 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Wow, a .520 lift cam runs 10.22, my 3200# Dart is slower than that with the .590.
What is the spec and weight.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Solid Cams who runs them? [Re: deaks] #1071807
09/10/11 05:11 AM
09/10/11 05:11 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
ha, thats what i was thinking mick...
must be 2400lbs , 14:1 , on nitrous ?
