How to remove key cylinder from ign switch? #1071547
09/08/11 07:27 PM
09/08/11 07:27 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
I need to re-key the ignition switch in a 1966 satellite,there is a pin that holds the lock cylinder into the switch housing.How do i get the pin to retract so i can slide out the cylinder?
Re: How to remove key cylinder from ign switch? [Re: ogopogo] #1071548
09/08/11 08:02 PM
09/08/11 08:02 PM
Lakewood, WA
rick@laysons Offline
Lakewood, WA
Re: How to remove key cylinder from ign switch? [Re: rick@laysons] #1071549
09/08/11 08:19 PM
09/08/11 08:19 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
I had a quick look in my 66 service manual and didnt see anything about the ign switch,i better check again,here s a pic of the switch
Re: How to remove key cylinder from ign switch? [Re: ogopogo] #1071550
09/08/11 08:34 PM
09/08/11 08:34 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Put the key in the cylinder.
Rotate the key/cylinder to ON. The pin should depress. Try other positions to see which allows the pin to be pushed.
Pull the key/cylinder out of the switch.
Of course, most of the time you are replacing the cylinder due to missing key or damaged key or cylinder.
In this case, you can try drilling it out, but it's often a better idea to replace that old worn switch too and just toss the whole mess out.
Re: How to remove key cylinder from ign switch? [Re: RodStRace] #1071551
09/08/11 11:29 PM
09/08/11 11:29 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
i should have posted that I dont have the key,I figured that the pin would only retract with the key.........
Re: How to remove key cylinder from ign switch? [Re: ogopogo] #1071552
09/08/11 11:53 PM
09/08/11 11:53 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Of course, that's why I typed the second part.
Rock auto has the starter switch for under 18 bucks and a new lock cylinder for under 18 bucks too.
STANDARD MOTOR PRODUCTS Part # US50 switch
STANDARD MOTOR PRODUCTS Part # US12L cylinder
If you have a new lock and a new switch, you are ready to install.
