Ford 9" rearend swap in 68-69 Dart?
#1071111
09/07/11 09:52 PM
09/07/11 09:52 PM
Posts: 265 Rapid City, South Dakota
six-pack-mopar
Anybody have any experience using a Ford 9" in a Dart? I was told that there is a great weight advantage going this way plus you have a rearend that can stand up to the abuse of most Hemi powered motors. I've hear it might even be a directly bolt up and save over 100 lbs in weight. Also mentioned is that exhaust pipes will clear the Ford rearend much better than a Dana fitted rearend car. You also get a 5 on 4 1/2" bolt pattern which Mopar and Fords share as a bonus. Thoughts? Thanks, Buddy 605 390 1950 cell ebelzer@aol.com
Re: Ford 9" rearend swap in 68-69 Dart?
[Re: nomore65BelvJim]
#1071113
09/07/11 10:23 PM
09/07/11 10:23 PM
Posts: 15,487 Florida
scratchnfotraction
IIRC,there is a early ferd rustang/mavrick 8" maybe a 9" rear hosing that bolts in an A-body. may or may not have to move spring perches I have been looking at some of the jeep cherokee rear axles,the one my son has has the same 43" spring perch centers as a-bodys,not sure it would hold up to a BB or hemi but disc brakes maybe a plus. with my 68 Dart,I got tired of looking and just had a c-body 8 3/4 cut down to a-body specs and got a set of large brake 5 on 4.5 wbp axle from moser. then it bolted right in my 88 440 truck and tucks 12s with 29x15x15 M/Ts in the fenders good luck ferd hunting
[Re: savoy64]
#1071117
09/08/11 08:33 AM
09/08/11 08:33 AM
Posts: 1,511 AZ
Mike P
AZ
......Unfortunately, there is no "cheap" 9" rear that will bolt into an A-body that will handle much power. 28 spline axles and small bearings will not last long
Aint that the truth. The narrowest factory 9 rears are 58 (axel flange to axel flange). The 58 version is found under 57-59 Ford Station Wagons and has 28 spline axels, usually an open differential, and rear brake drums are almost impossible to find. The other 58 unit is under the first generation Broncos, big advantage is they are 31 spline axels. Both are getting hard to find and usually not that cheap when you do. The Maverick rears are all 8 by the way.
I recently built a 9 for my 507 Cadillac powered El Camino. I started out with a $100 junk yard 59 wagon rear end and by the time it was under the El Camino I had well over $1000 in it (using the original 28 spline axels and brake drums, doing all the work myself and buying parts at my shop cost....if I had farmed it out double that cost). When you start adding up the cost of really setting up a 9 for other than just mild street use (which is how mine is) the built it gets real expensive.
Most of the 9 rears you are going to find will be too wide anyway, so figure adding the cost of narrowing the housing and custom axels. With what junk yard truck Dana 60s can be found for (often with decent gears and LSDs) and the cost they are getting for narrowing them, youre not any ahead using a Ford 9.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
[Re: Mike P]
#1071118
09/08/11 12:05 PM
09/08/11 12:05 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
The Lincoln Versaille rear will bolt in with disc brakes. I found one once. didn't have the time or money to snag it. Brake parts are not easy to find either.
How much power you gonna throw to it?
Ford Explorer rears are good.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: scratchnfotraction]
#1071119
09/08/11 12:58 PM
09/08/11 12:58 PM
Posts: 612 Nampa, ID
None2Slow
Nampa, ID
I have a ford 8" rear out of a maverick. It will bolt in, but you need to add a bushing to the leaf spring pin. At least this is true for the 7 1/4. I am putting 1 into a 63 Valiant Convertable. I bought an instrument cluster from a guy on craigslist that had a 64 wagon that had the 8" in. Direct bolt in. He was parting the car, but keeping the rear because of this. Hes also a member at FABO.
[Re: six-pack-mopar]
#1071120
09/08/11 01:01 PM
09/08/11 01:01 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Thoughts? 100lbs? I don't think so...compared to what? Use an 8 3/4 or a Dana if you are running slicks and big power. Hard to beat the cost of a ready to run Dana 60. Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: Challenger 1]
#1071123
09/08/11 04:52 PM
09/08/11 04:52 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Doctor Diff, do you sell 9" stuff?
I got my axles and complete 3rd member from Cass for the 9" I put into the Torana
[Re: DPelletier]
#1071126
09/08/11 08:10 PM
09/08/11 08:10 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
I used a Lincoln Versailles housing in my Savoy with Moser 33 spline axles and spool.I also snagged a nodular carrier with a Daytona pinion support.I raced it for one season 100 or so passes without issues but I wouldn't run a "stock" carrier at my current power level and weight I swapped it for a Dana one of my buddies had in a Camaro. I really do miss the ease of gear changes and ratio choices out there though I hate having to plan a build around the limited gear options you have with a Dana I had about $1000 in the 9" with the factory housing and nodular carrier with S-10 calipers and Jeep front rotors. It would stay together in an automatic car under 3200# Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
