School me on a Mopar 361 engine #1070799
09/07/11 12:20 PM
09/07/11 12:20 PM
Ohio
aquamist60 Offline OP
Ohio
I am fixing to buy a parts car that comes with a 361 engine. That's really all I can tell you about the engine. The 361 has me somewhat intriguedfrom some of the things I've read. Available in Plymouth, Dodge or Desoto, different intakes, different hp ratings.
Re: School me on a Mopar 361 engine [Re: aquamist60] #1070800
09/07/11 12:44 PM
09/07/11 12:44 PM
Louisville, KY.
Scottmon Offline
Scottmon  Offline
Louisville, KY.
Cost just as much to build the 361 as the 440, and have a lot less power. I'd only keep it if it runs good and you don't plan to do much to it.
Re: School me on a Mopar 361 engine [Re: Scottmon] #1070801
09/07/11 03:27 PM
09/07/11 03:27 PM
CA
David Lee Offline
David Lee  Offline
CA
if you plan on making a period correct car, keep the 361, it basically an early B engine. May I ask what car this came out of?
Ah...so many pedestrians, so little time...
Re: School me on a Mopar 361 engine [Re: David Lee] #1070802
09/07/11 09:18 PM
09/07/11 09:18 PM
Ohio
Ohio
It is a 1960 Plymouth Savoy. The engine in the parts car is a 361 Golden Commando with an automatic trans. My car will be a driver when done. I'm not definate on what engine I want to use just yet. It came with a /6 with a 3spd stick shift.
Re: School me on a Mopar 361 engine [Re: aquamist60] #1070803
09/07/11 09:25 PM
09/07/11 09:25 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
The 361 can get pricey to build if you need pistons , I don't think there is anything off the shelf for it. if you want a period correct motor then use it , otherwise I would build something that would give you the same look but has better parts availability ... your choice though.
Re: School me on a Mopar 361 engine [Re: JohnRR] #1070804
09/07/11 09:49 PM
09/07/11 09:49 PM
middle Tennessee
mopower440 Offline
mopower440  Offline
middle Tennessee
my buddy bought a 1966 dodge coronet with 361/4-speed, it was stock and would flat out fly!! The 361 is just a smaller ci 383, fun car that was!
Re: School me on a Mopar 361 engine [Re: mopower440] #1070805
09/07/11 11:25 PM
09/07/11 11:25 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
How about building a 383, dressed up to look like a 361? Could be fun. I understand you already have the 361, though.
It's Swifty! Swifty, you toad sucker!
Re: School me on a Mopar 361 engine [Re: zrxkawboy] #1070806
09/08/11 08:40 AM
09/08/11 08:40 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I had 3 of them.The one that was in my 65 I tried to blow up many times.Id float the valves till it missed.Then it would just come back to life.It ran very good.Only reason I pulled it was because I put the 440 in.Rocky
Chrysler Firepower
Re: School me on a Mopar 361 engine [Re: aquamist60] #1070807
09/08/11 12:33 PM
09/08/11 12:33 PM
Indiana
P
Pentastar440 Offline
P
Indiana
That 361 parts car gives you a setup with everything you need to run any big block.
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
Re: School me on a Mopar 361 engine [Re: Pentastar440] #1070808
09/08/11 04:23 PM
09/08/11 04:23 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
I'm sorry, as far as performance, the 361 is a piece of junk. If you want it for the correctness in the Savoy, then cool, keep it in there, but if you want performance , and with the same "look", then build a 383 for it, paint it like the "Commando" and away you go with a whole lot more HP. Nobody is going to know except when you put your foot in it.
Re: School me on a Mopar 361 engine [Re: DANA60] #1070809
09/08/11 04:55 PM
09/08/11 04:55 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Nevermind even the 383, a 400 with a 440 crank = 451 and would externally look like the 361. That's 90 cubes of difference!
Re: School me on a Mopar 361 engine [Re: DaytonaTurbo] #1070810
09/08/11 06:54 PM
09/08/11 06:54 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
361 would be fine for a cruiser. A bigger engine would be better for power. Whether or not it should be used would depend on the intended usage of the car.
I'd tear the 361 down and see what kind of condition it is in. It may be that it doesn't need much more than a gasket set. In my limited experience with the earlier big blocks, it seems like the engines often outlasted the cars. So it wouldn't surprise me if the engine was good when the car was taken off the road.
Re: School me on a Mopar 361 engine [Re: zrxkawboy] #1070811
09/09/11 08:43 AM
09/09/11 08:43 AM
Ohio
Ohio
I do also have a 383 and a 440. I'm actually leaning toward the 440, but since the parts car has a 361 it added another potential. Were the Golden Commando engines painted all gold or were they red with gold parts? I've heard some say one way, some the other.
Re: School me on a Mopar 361 engine [Re: aquamist60] #1070812
09/09/11 10:36 AM
09/09/11 10:36 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
I'll buy your air cleaner if it's still there !!
Also,red block with gold covers and air cleaner if it's a 60.
Re: School me on a Mopar 361 engine [Re: 62maxwgn] #1070813
09/09/11 07:54 PM
09/09/11 07:54 PM
Ohio
Ohio
I haven't picked it up yet, waiting to see if my Dr says I need more surgery for my broken leg and my son to get a couple of days off to make the run with me.
Right now I'm leaning towards the 440 painted like the Golden Commando with the push button trans. I've got virtually everything to build a 1967 440 375 hp engine with a pushbutton trans.
I've got a list me and my dad put together before he died of mods I wanted to make. He was one that always said "keep it original." We talked the last 6 months about what to do and he liked my ideas and came up with some of his own.
Won't be long before we're back after it. Might post on another forum here what our plans are.
Re: School me on a Mopar 361 engine [Re: 62maxwgn] #1070814
09/09/11 07:55 PM
09/09/11 07:55 PM
Ohio
Ohio
Re: School me on a Mopar 361 engine [Re: DaytonaTurbo] #1070815
09/09/11 08:20 PM
09/09/11 08:20 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
, but for that matter, how many can spot the difference with just a quick glance between a 361 and a 440 with the id pad ground down?
Re: School me on a Mopar 361 engine [Re: jcc] #1070816
09/09/11 09:29 PM
09/09/11 09:29 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
B's and RB's are quite different to the eye in my opinion.
