School me on a Mopar 361 engine
#1070799
09/07/11 12:20 PM
09/07/11 12:20 PM
Posts: 248 Ohio
aquamist60
Ohio
I am fixing to buy a parts car that comes with a 361 engine. That's really all I can tell you about the engine. The 361 has me somewhat intriguedfrom some of the things I've read. Available in Plymouth, Dodge or Desoto, different intakes, different hp ratings.
Re: School me on a Mopar 361 engine
[Re: Scottmon]
#1070801
09/07/11 03:27 PM
09/07/11 03:27 PM
Posts: 305 CA
David Lee
CA
if you plan on making a period correct car, keep the 361, it basically an early B engine. May I ask what car this came out of?
Ah...so many pedestrians, so little time...
[Re: David Lee]
#1070802
09/07/11 09:18 PM
09/07/11 09:18 PM
Posts: 248 Ohio
aquamist60
Ohio
It is a 1960 Plymouth Savoy. The engine in the parts car is a 361 Golden Commando with an automatic trans. My car will be a driver when done. I'm not definate on what engine I want to use just yet. It came with a /6 with a 3spd stick shift.
[Re: aquamist60]
#1070803
09/07/11 09:25 PM
09/07/11 09:25 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
The 361 can get pricey to build if you need pistons , I don't think there is anything off the shelf for it. if you want a period correct motor then use it , otherwise I would build something that would give you the same look but has better parts availability ... your choice though.
[Re: mopower440]
#1070805
09/07/11 11:25 PM
09/07/11 11:25 PM
Posts: 905 SD
zrxkawboy
SD
How about building a 383, dressed up to look like a 361? Could be fun. I understand you already have the 361, though.
It's Swifty! Swifty, you toad sucker!
[Re: zrxkawboy]
#1070806
09/08/11 08:40 AM
09/08/11 08:40 AM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
I had 3 of them.The one that was in my 65 I tried to blow up many times.Id float the valves till it missed.Then it would just come back to life.It ran very good.Only reason I pulled it was because I put the 440 in.Rocky
Chrysler Firepower
[Re: Pentastar440]
#1070808
09/08/11 04:23 PM
09/08/11 04:23 PM
Posts: 616 TP Exit 7, NJ, USA
DANA60
TP Exit 7, NJ, USA
I'm sorry, as far as performance, the 361 is a piece of junk. If you want it for the correctness in the Savoy, then cool, keep it in there, but if you want performance , and with the same "look", then build a 383 for it, paint it like the "Commando" and away you go with a whole lot more HP. Nobody is going to know except when you put your foot in it.
[Re: zrxkawboy]
#1070811
09/09/11 08:43 AM
09/09/11 08:43 AM
Posts: 248 Ohio
aquamist60
Ohio
I do also have a 383 and a 440. I'm actually leaning toward the 440, but since the parts car has a 361 it added another potential. Were the Golden Commando engines painted all gold or were they red with gold parts? I've heard some say one way, some the other.
[Re: aquamist60]
#1070812
09/09/11 10:36 AM
09/09/11 10:36 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
I'll buy your air cleaner if it's still there !!
Also,red block with gold covers and air cleaner if it's a 60.
[Re: 62maxwgn]
#1070813
09/09/11 07:54 PM
09/09/11 07:54 PM
Posts: 248 Ohio
aquamist60
Ohio
[Re: 62maxwgn]
#1070814
09/09/11 07:55 PM
09/09/11 07:55 PM
Posts: 248 Ohio
aquamist60
Ohio
[Re: jcc]
#1070816
09/09/11 09:29 PM
09/09/11 09:29 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
B's and RB's are quite different to the eye in my opinion.
