Dot 3 vs Dot 5 Brake Fluid #1070491
09/06/11 08:35 PM
09/06/11 08:35 PM
Sacramento CA
Morty426 Offline OP
Morty426  Offline OP
Sacramento CA
For my 71 Challenger R/T restoration project.
Should / can I use Dot 5 over Dot 3? Everything is new or rebuilt.
Re: Dot 3 vs Dot 5 Brake Fluid [Re: Morty426] #1070492
09/06/11 08:42 PM
09/06/11 08:42 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I've used dot 5 in the Torana after building it all from scratch with new stuff....no problems and if you do spill it doesn't matter
Re: Dot 3 vs Dot 5 Brake Fluid [Re: Morty426] #1070493
09/06/11 08:49 PM
09/06/11 08:49 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
dot 3 and 4 both produce water and eventually will rust out your lines/parts. dot 5 is silicone based and won't do that. if you use 5, you can ONLY use 5.
Re: Dot 3 vs Dot 5 Brake Fluid [Re: OzHemi] #1070494
09/07/11 12:21 PM
09/07/11 12:21 PM
jamestown, ny
71scamp440 Offline
Hinged
71scamp440  Offline
Hinged
jamestown, ny
71 scamp big block with 915 heads 727 trans
Re: Dot 3 vs Dot 5 Brake Fluid [Re: Morty426] #1070495
09/07/11 12:35 PM
09/07/11 12:35 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Ive used DOT5 on all my own and all customers vehicles and never had a single issue. Some say its not safe to use, I dunno. All i'll say is one single mishap with the DOT 3 and the paint will be destroyed..If that's not enough to scare anyone, then
You could bathe the car in DOT 5 and there will be no issues.
MB
Re: Dot 3 vs Dot 5 Brake Fluid [Re: HPMike] #1070496
09/07/11 01:16 PM
09/07/11 01:16 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
My paint job cost......well, more than I care to admit, so using DOT 5 is a no-brainer. Also FWIW, despite the urban myth, your brakes will still work and your car will not explode spontaneously if you mix a little DOT 3, 4 or 5.1 in.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Dot 3 vs Dot 5 Brake Fluid [Re: DPelletier] #1070497
09/07/11 01:20 PM
09/07/11 01:20 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
This guy was just topping off his car with some Dot 3, despite having had Dot 5 in it previously...
Re: Dot 3 vs Dot 5 Brake Fluid [Re: OzHemi] #1070498
09/07/11 01:43 PM
09/07/11 01:43 PM
the house on the left.
cogen80 Offline
cogen80  Offline
lmao
Re: Dot 3 vs Dot 5 Brake Fluid [Re: Morty426] #1070499
09/07/11 01:55 PM
09/07/11 01:55 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Yep, DOT5 in my car. I had done a road ralley last year and was onthe brakes pretty hard. Non-power discs. I had no issues. I had all new components. One trick someone told me about was to place the open can in a pan of boiling water. It could be a romur, but DOT5 will entrain air a little easier. So by heating it up, you are expanding the bubbles enough to rise to the surface. I did it, I figured it couldn't hurt.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Dot 3 vs Dot 5 Brake Fluid [Re: OzHemi] #1070500
09/07/11 02:02 PM
09/07/11 02:02 PM
DPelletier Offline
DPelletier  Offline
Re: Dot 3 vs Dot 5 Brake Fluid [Re: DPelletier] #1070501
09/07/11 02:07 PM
09/07/11 02:07 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
And this lady mixed Dot 4 with Dot 5....
Re: Dot 3 vs Dot 5 Brake Fluid [Re: OzHemi] #1070502
09/07/11 03:00 PM
09/07/11 03:00 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I've used Dot 5 in every car I've done in the past 10 years. Haven't had an issue yet that I attribute to the fluid.
Re: Dot 3 vs Dot 5 Brake Fluid [Re: mikemee1331] #1070503
09/07/11 03:24 PM
09/07/11 03:24 PM
cogen80 Offline
cogen80  Offline
produce water? they absorb moisture which can rust your entire system. the dot5 doesn't absorb moisture but i have read that since it doesn't absorb moisture that the moisture can collect at the wheel cyl and calipers. just bleed the system once a year and you should be fine.
Re: Dot 3 vs Dot 5 Brake Fluid [Re: cogen80] #1070504
09/07/11 05:35 PM
09/07/11 05:35 PM
DPelletier Offline
DPelletier  Offline
the correct term is "Hygroscopic" which means that a substance readily absorbs moisture. Dot 4 (and the other polyethylene glycol based fluids) is hygroscopic and will absorb water from the atmosphere.....which is why you aren't supposed to use old fluid, particularly if it has had the lid off for some time. Moisture absorbed by polyethelene glycol brake fluid will rust all interior components of the brake system over time.
Dot 5 (not 5.1) is silicone based and will not absorb moisture. Since Dot 5 won't absorb the moisture, there is no danger of rust from water in the brake fluid, BUT any moisture in the system will tend to migrate to a dead end or high spot and rust in that area would then be free to form. Frequent use, bleeding or the use of stainless steel brake lines and components are methods of combating this corrosion.
There, clear as mud?
Re: Dot 3 vs Dot 5 Brake Fluid [Re: cogen80] #1070505
09/07/11 05:35 PM
09/07/11 05:35 PM
Sacramento CA
Morty426 Offline OP
Morty426  Offline OP
Sacramento CA
Thanks guys - DOT 5 it will be.
Re: Dot 3 vs Dot 5 Brake Fluid [Re: DPelletier] #1070506
09/07/11 05:39 PM
09/07/11 05:39 PM
cogen80 Offline
cogen80  Offline
so basically what i said but not needing a Thesaurus.. lmao
Re: Dot 3 vs Dot 5 Brake Fluid [Re: cogen80] #1070507
09/07/11 06:48 PM
09/07/11 06:48 PM
DPelletier Offline
DPelletier  Offline
Sure, but mine sounds much more authoritative, does it not?
Re: Dot 3 vs Dot 5 Brake Fluid [Re: DPelletier] #1070508
09/07/11 07:36 PM
09/07/11 07:36 PM
cogen80 Offline
cogen80  Offline
yea it does..lol
