fitting a cordoba tilt column into a 71 charger #1070422
09/06/11 05:20 PM
09/06/11 05:20 PM
minnarusta
TX9H6E4CUDA Offline OP
minnarusta
I recently saw frankendusters car and he had a tilt column out of a Cordoba installed. I want to put one of these into my 1971 superbee. Anyone have any luck modifying one for their mopar?
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
Re: fitting a cordoba tilt column into a 71 charger [Re: TX9H6E4CUDA] #1070423
09/06/11 11:22 PM
09/06/11 11:22 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I may have neglected to mention......
The distance from the firewall where the column bolts down TO the underdash area where the column hangs is slightly different from the A body to the Cordoba. The Cordoba column is slightly longer. The plastic "breakaway capsules" do allow some fore and aft movement though, as they are slotted. The wiring is a mix of GM and Chrysler, but it connected to my Duster harness without mods. I had to use a flat faced steering wheel because the column is LONGER from the dash outward, and a dished steering wheel would make the car uncomfortable to drive for anyone that didn't have Pteradactal arms!
