nhra winn again #1069848
09/05/11 06:32 PM
09/05/11 06:32 PM
tn
robnbird Offline OP
robnbird  Offline OP
tn
I can not understand how the rules can be fair to the mopars in prostock. they are almost alway .040 away from the GM cars. No more watching for me its a waist of time. johnson flawless on the tree.003 light against line and lost. bull
Re: nhra winn again [Re: robnbird] #1069849
09/05/11 06:46 PM
09/05/11 06:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
just have to come up with more HP POWER
Re: nhra winn again [Re: robnbird] #1069850
09/05/11 06:53 PM
09/05/11 06:53 PM
Guitar Jones Offline
AJ had a 1.00 60 foot, he was spinning the tires, they missed the setup.
What I found interesting was Jason Line commenting that his car was like a Cadillac, does that mean they'll be Cadillacs in PS next year?
Re: nhra winn again [Re: robnbird] #1069851
09/05/11 08:36 PM
09/05/11 08:36 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
what makes you think the rules have anything to do with them not winning?
all weigh 2350 lb and have 500" motors.
the only difference between GM and Mopar is design of the engine and body style.
Mopar built their engine starting with a clean sheet of paper. So they could have had near any configuration they wanted. After 12 years of racing with it plus research and improvements it still falls short. Body style may hurt them more than anything. Clbalts are near a mini car
home of the
Sox and Martin Hemi Duster
Re: nhra winn again [Re: HEMIFRED] #1069852
09/05/11 08:57 PM
09/05/11 08:57 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
As much as this hurts me, Them Summit cars are just really good cars. And the HOURS and HOURS they spend in the dyno rooms show. Not saying the Mopar boys dont spend time in the dyno either, but the Ken Black spends millions on R&D in the off season, and they are at the track testing all the time, set up tune ups all are practically duplicatable from their testing results. Thats what I heard Line saying to a fan at Topeka last year anyways. I dont think the Mopars are a lot less in the HP department either.
Kasey
Re: nhra winn again [Re: Moparnut426] #1069853
09/05/11 09:02 PM
09/05/11 09:02 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
seem's like the dodge boy's are missing the set-up alot, but when they do hit it, they are near impossible to out run.
Re: nhra winn again [Re: HEMIFRED] #1069854
09/05/11 10:27 PM
09/05/11 10:27 PM
tn
robnbird Offline OP
robnbird  Offline OP
tn
gm has about 6 part # for heads to start.
Re: nhra winn again [Re: robnbird] #1069855
09/05/11 10:35 PM
09/05/11 10:35 PM
Those GM heads look almost identical to the Mopar heads, I've heard the valve angles are all within 1 degree or so of each other but those builders can do what ever they want with them. Most of the gains with the Hemi I believe came from windage control and opening up the deep skirt block they used initially. Even the Ford engine is nearly identical to the others. There isn't any advantage there except the bodies and the teams R&D. Which is why I don't think the Mustang will ever be competive in PS, the car is just to fat.
Re: nhra winn again [Re: Guitar Jones] #1069856
09/05/11 11:02 PM
09/05/11 11:02 PM
tn
robnbird Offline OP
robnbird  Offline OP
tn
cadillac now that would be interesting.
Re: nhra winn again [Re: robnbird] #1069857
09/05/11 11:14 PM
09/05/11 11:14 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
Johnson was running with them and outrunning them early in the year. The summit cars have found a couple hundredths in the middle of the year here. Edwards cant hang with them either now.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: nhra winn again [Re: robnbird] #1069858
09/05/11 11:18 PM
09/05/11 11:18 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Mopars not winning has nothing to do with the rules. It's aero, HP or set up. The KB teams heve the best cars for the last month and a half. Allen was making some serious steam early on but has fell behind lately.
I'm not a GM fan by any means, but you can't beat on Anderson and Line, they are the class of the field right now.
Re: nhra winn again [Re: dartman366] #1069859
09/05/11 11:19 PM
09/05/11 11:19 PM
Rowlett, TX
74DusterP457 Offline
mopar addict
mopar addict
Rowlett, TX
Look at the MPH - that provides a good indication of horsepower. The MOPARs are pretty close in MPH.
Speaking of the competitive teams (as defined as teams that consistently go more than one round), its about chassis set up 75% of the time. The other 25% is the driver. I'm factoring in for track prep in my 75% estimate. Let's face it, most of the drivers are robots and you could swap them between teams, give them a couple practice runs and you wouldn't know the difference.
The thing you have to consider is Pro-Stock cars are run on the ragged edge of out of control. Roy didn't start making "GM" power levels until about 2008. When you add 10-20 HP on a car that's set up to a razor blade width, you've got to start all over. Throw in a new chassis and body and the learning curve is steeper. Remember, the Pontiac G6 platform has been in Pro-Stock for what, 4 or 5 years now? That's a lot of chassis set up experience!
I also think the Summit guys don't start to show all their cards until after the 10th race of the season. Check the results, I think they back me up. I think they do their "experimenting" early in the season and don't focus as much on winning races.
As far as testing goes, Johnson does a lot. Mark is a licensed Pro-Stock driver as well and gets his share of seat time. Do the Summit twins test more? Probably, but having a bigger bank roll than any other team in Pro-Stock at this point in time certainly doesn't hurt.
I can't resist saying this...y'all remember back when WJ's notebook went missing for a few months? That information sure gave one Pontiac driver a heck of a nice baseline to start from - if you catch my drift.
Paul
Re: nhra winn again [Re: Irun5snd8th] #1069860
09/05/11 11:21 PM
09/05/11 11:21 PM
tn
robnbird Offline OP
robnbird  Offline OP
tn
yea, Summitt definitely has the surge now. I just fill bad for the Mopar teams they work hard trying to win.
Re: nhra winn again [Re: 74DusterP457] #1069861
09/05/11 11:25 PM
09/05/11 11:25 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
as much as I hate to admit it..But AJ. has lost with a faster car....alot this yr..
his reaction times have not been there when he needed it to be...thats just a fact..
look at the mph..the dodge has plenty enough to win..
not that those other cars arent fast though..
but very often it won on the tree...just ask Jason line..he lost to greg with a faster car..
greg tree'd him..
just the way it is..
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: nhra winn again [Re: cheapstreetdustr] #1069862
09/05/11 11:30 PM
09/05/11 11:30 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
The one really good driver we have is Nobile.
Re: nhra winn again [Re: cheapstreetdustr] #1069863
09/05/11 11:31 PM
09/05/11 11:31 PM
65hardtop Offline
65hardtop  Offline
When I was in the stands on friday night I could hear a rpm difference between the summit cars and the rest of the feild. I only really noticed it on the 3rd and 4th shift. It deffinitly sounded different to me though.
Re: nhra winn again [Re: robnbird] #1069864
09/05/11 11:56 PM
09/05/11 11:56 PM
ill
dennismopar73 Offline
ill
there is a guy working on one as we speak ?? will n h r a accept it that the question,
i said it before, toyota's are comming!!!
Re: nhra winn again [Re: dennismopar73] #1069865
09/06/11 12:18 AM
09/06/11 12:18 AM
tn
robnbird Offline OP
robnbird  Offline OP
tn
yea, Totota will be there in the next couple of years. I think nhra' thinking is no different than in the 70' when the rules were made so the # 1 selling cars GM and then Ford could win. Bill Jenkins was give a lightwate 2300 pound vega with a heavily modified 350 and 400 ci. that won.so nhra could fill the stands with fans. You can't blame them for wanting to fill the stands.
Re: nhra winn again [Re: 65hardtop] #1069866
09/06/11 07:29 AM
09/06/11 07:29 AM
They definitely run those Summit cars at a higher RPM. If you noticed they moved the in car cam. Before they had tape over the tschometer so you couldn't read it. There is physics at work there, the more RPM you turn the engine in the same amount of time the more energy it converts thus the more work it produces.
There was a Cadillac in PS many years ago. It was entered at Gainsville one year. Built by Takash Race Craft, it was nice but didn't qualify.
Re: nhra winn again [Re: Guitar Jones] #1069867
09/06/11 08:13 AM
09/06/11 08:13 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
I think the G6 has a much better aero package than the Mopars. The question I have to ask is, how much longer can they run a body that is no longer available from GM? Will they go with a Camaro next, or something else?
KB Racing probably spends in R&D in 6 months that some well funded teams spend in a year, hard to compete with that.
Alan Jones
