Ignition switch - best replacement #1069078
09/04/11 03:02 PM
09/04/11 03:02 PM
The Historic Hudson Valley
MONC Offline OP
MONC  Offline OP
I see Year One has replacement ignition switches, but not sure of their quality or correctness:
http://www.yearone.com/serverfiles/fbshopmain2.asp?input=ignition+switch&SM=1&SC=1
Since they're also the middle man, figured I could maybe get it cheaper.
Any better places or experiences?
Never replaced an ignition switch before ( did a turn signal switch on a 70 GTX once) . Do you have to change the locks, as the Year One ad seems to infer?
This is for a 70 E body.
Re: Ignition switch - best replacement [Re: MONC] #1069079
09/04/11 07:10 PM
09/04/11 07:10 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
The one in the YearOne catalog is an aftermarket switch. I have seen NOS and reproduction switches on Ebay. I bought a Mopar bagged switch on there. Whether it was NOS or a reproduction, I do not know. The quality was the same as the original one I took out. Keep an eye out for them, they are around.
Craig
Re: Ignition switch - best replacement [Re: denfireguy] #1069080
09/04/11 07:31 PM
09/04/11 07:31 PM
okla.
O
okie Offline
okie  Offline
O
okla.
Year One and Classic ind. has a big sale going on right now for the next day are two. 20-30% off so it would be a good time to get one ordered. Ronnie
Re: Ignition switch - best replacement [Re: denfireguy] #1069081
09/04/11 07:52 PM
09/04/11 07:52 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ever think about the local parts store?Last one I bought at NAPA for the 66 Charger was like 10 bucks.Rocky
Chrysler Firepower
Re: Ignition switch - best replacement [Re: therocks] #1069082
09/04/11 08:44 PM
09/04/11 08:44 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Napa carries it for $45...
Not for tilt wheel..
https://www.napaonline.com/Catalog/Catal...0+50056+2056004
Use Auto Club for a discount..
Just my $0.02..
Re: Ignition switch - best replacement [Re: Sinitro] #1069083
09/04/11 08:54 PM
09/04/11 08:54 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
The tumbler part that the ignition key goes into is a seperate part from the electrical ignition switch. I don't see why you could not just use your existing tumbler so long as it works smoothly.
Re: Ignition switch - best replacement [Re: Sinitro] #1069084
09/04/11 09:31 PM
09/04/11 09:31 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Just my $0.02..
Yeah, Autozoo has them for 40 also, I just changed mine.
Re: Ignition switch - best replacement [Re: ireland383] #1069085
09/04/11 09:38 PM
09/04/11 09:38 PM
Connecticut
biginchmotor Offline
Connecticut
Bought a standard motor products ignition switch (china) over the summer, good thing I plugged it into my harness before I assembled the column. Was defective. Bought a Wells brand from animalzone and it works fine. Plug it in and try it out before installing it, John.
Re: Ignition switch - best replacement [Re: ireland383] #1069086
09/04/11 10:18 PM
09/04/11 10:18 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Just my $0.02..
Looking further..
RockAuto has them even cheaper..
http://www.rockauto.com/catalog/moreinfo.php?pk=944615
Plus add the 5% discount..
Just my $0.02...
Re: Ignition switch - best replacement [Re: Sinitro] #1069087
09/05/11 09:44 AM
09/05/11 09:44 AM
MONC Offline OP
MONC  Offline OP
Cool thanks for the links guys.
Ireland383, so how difficult was it to change out?
My concerns is pulling that part of the column off.
How did you do it without scratching/denting the column?
Did you use a special tool?
Re: Ignition switch - best replacement [Re: MONC] #1069088
09/05/11 10:08 AM
09/05/11 10:08 AM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
https://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=5870068&an=&page=0&vc=1 You need a steering wheel puller and some snap ring pliers. It's a bit of a pain in the but. Bring your patience and line up everything you take off in order. I scratched mine a little. Are you sure your switch is bad? As another member said test the new one first before tearing the column apart.
Re: Ignition switch - best replacement [Re: MONC] #1069089
09/05/11 10:13 AM
09/05/11 10:13 AM
Central TX
roe Offline
roe  Offline
Central TX
How did you do it without scratching/denting the column? Did you use a special tool?
I went to check on mine and was nervous about doing some damage to my column or the wiring. Mine has an intermittent no start from the key, so I wired in a push button. Would like to see about changing mine too. Haynes manual does not do a good job explaining this repair
roe
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Ignition switch - best replacement [Re: ireland383] #1069090
09/05/11 12:49 PM
09/05/11 12:49 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Re: Ignition switch - best replacement [Re: ireland383] #1069091
09/05/11 05:45 PM
09/05/11 05:45 PM
MONC Offline OP
MONC  Offline OP
This is the one I followed.
https://board.moparts.org/ubbthreads/show...page=0&vc=1
Thanks, good info.
Did you end up pulling the column section off without damaging or scratching the piece or the rest of the column?
Re: Ignition switch - best replacement [Re: MONC] #1069092
09/05/11 08:24 PM
09/05/11 08:24 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
A tiny piece cracked more towards the bottom where you can't really see it. I used some permanent marker on the scratch and crack. It really doesn't look bad. That's why you need your patience and walk away if you have to.
Re: Ignition switch - best replacement [Re: ireland383] #1069093
09/06/11 09:40 AM
09/06/11 09:40 AM
MONC Offline OP
MONC  Offline OP
Indeed...
Not so easy to hide/fix when it's not black, unfortunately...
Re: Ignition switch - best replacement [Re: MONC] #1069094
09/06/11 05:19 PM
09/06/11 05:19 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
i just went through my -70 column,i got the miller tool for pulling the section with the bearing in it on ebag.no scratches that way,you coud build it yourself or buy it in the tool section here on moparts,i think.i bought a nos switch on ebag,spendy,over 100 ballobas.and im still not satisfied cause it had an extra black wire witch my oem didnt have.for the auto floor shift light i believe.i have a 4speed.anyway i liked the nos cause the cables were flat,sort of in a row.as it was on the one i removed.ok, overandout from sweden.my oem switch only has 5 wires.the nos and all others ive seen has 6? hm did they really make a special for the 3-4 speed floor shifters?
