Re: Ignition switch - best replacement
[Re: MONC]
#1069079
09/04/11 07:10 PM
09/04/11 07:10 PM
Posts: 1,822 Colorado
denfireguy
Colorado
I see Year One has replacement ignition switches, but not sure of their quality or correctness: http://www.yearone.com/serverfiles/fbshopmain2.asp?input=ignition+switch&SM=1&SC=1
Since they're also the middle man, figured I could maybe get it cheaper.
Any better places or experiences? Never replaced an ignition switch before ( did a turn signal switch on a 70 GTX once) . Do you have to change the locks, as the Year One ad seems to infer?
This is for a 70 E body.
The one in the YearOne catalog is an aftermarket switch. I have seen NOS and reproduction switches on Ebay. I bought a Mopar bagged switch on there. Whether it was NOS or a reproduction, I do not know. The quality was the same as the original one I took out. Keep an eye out for them, they are around. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: denfireguy]
#1069081
09/04/11 07:52 PM
09/04/11 07:52 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
Ever think about the local parts store?Last one I bought at NAPA for the 66 Charger was like 10 bucks.Rocky
Chrysler Firepower
[Re: Sinitro]
#1069084
09/04/11 09:31 PM
09/04/11 09:31 PM
Posts: 843 Suffolk,VA
ireland383
Suffolk,VA
Napa carries it for $45... Not for tilt wheel.. https://www.napaonline.com/Catalog/Catal...0+50056+2056004
Use Auto Club for a discount..
Just my $0.02..
Yeah, Autozoo has them for 40 also, I just changed mine.
[Re: MONC]
#1069088
09/05/11 10:08 AM
09/05/11 10:08 AM
ireland383
Suffolk,VA
Cool thanks for the links guys.
Ireland383, so how difficult was it to change out? My concerns is pulling that part of the column off. How did you do it without scratching/denting the column? Did you use a special tool? Thanks
https://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=5870068&an=&page=0&vc=1 You need a steering wheel puller and some snap ring pliers. It's a bit of a pain in the but. Bring your patience and line up everything you take off in order. I scratched mine a little. Are you sure your switch is bad? As another member said test the new one first before tearing the column apart.
