Parked it 12 years ago......Fired it up yesterday #1068782
09/04/11 08:30 AM
09/04/11 08:30 AM
FL
HelleOnWheels Offline OP
FL
Here is the story of my 1967 Dodge Coronet RT.
I bought the RT back in 5/99 from a guy who ended up with it in 1991 as a partial trade on a Corvette he was trying to sell. He told me that he parked it in his garage when he got it and never drove it. He was a die hard Corvette fanatic and had little interest in the RT. He left it in the back of his garage from 91-99 until I bought it in '99. I was just out of high school and had a blast driving it around from 5/99 until it broke down in 11/99. The radiator busted a seam and had to be replaced. Here comes the sad part:( I parked it in my garage and never got around to it fro the next 12 years!! The car has not been fired up and even run since it broke down in '99. Same old story we've all heard. I got married and had 3 kids and priorities changed.
Here comes the good part....I decided it was time to get it back on the road. I drained the oil, changed oil filters and put new oil in. Sprayed the tops of the heads with Marvel Mystery Oil and put new valve cover gaskets on to seal it up. I put 3/4 tsp of Marvel in each cylinder and turned the motor over by hand to make sure the rings/pistons were not stuck. I installed new spark plugs with new wires. I installed a new battery and hooked up a gas can to provide me with fresh gas for start up.
We rolled the car out of the garage and proceeded to check everything one last time before we attempted a re-start. This is the crazy part. After the second attempt to re-fire it, it fired right up and went into a somewhat smooth idle. WOOHOO!!! Within 20 seconds I developed a tranny fluid leak and had to shut it down. We fixed the leak and fired it back up. This time it sat at a very nice sounding smooth idle for approx 45 seconds and then it died. Turns out the carb is all gummed up and it is not shutting off the gas flow when it should. You can hear the gas just pouring out from the carb.
This has given me a new found excitement about getting my car back on the road and I have now decided that I am going to spend the next 75 days working feverishly so it can be ready for the Turkey Rod Run in my hometown of Daytona Beach, FL. This is the last place it drove to back in '99.
I am sure I will be on here much more in the very near future!!
Thanks for reading:)
Re: Parked it 12 years ago......Fired it up yesterday [Re: HelleOnWheels] #1068783
09/04/11 08:39 AM
09/04/11 08:39 AM
SE Pa.
LimeliteAero Offline
SE Pa.
cool story....we want more pics though.
Re: Parked it 12 years ago......Fired it up yesterday [Re: LimeliteAero] #1068784
09/04/11 10:08 AM
09/04/11 10:08 AM
MO
cdp Offline
cdp  Offline
MO
I recommend putting some TransX or Lucas in the trans to swell the seals back up. Once you drive it a little, it should be fine.
I bought a 71-GTX way back in 98 that was real solid, but really should be restored. I'm just tinkering with it now. Finally got it running again and slowly repairing the things to make it roadable.
Re: Parked it 12 years ago......Fired it up yesterday [Re: HelleOnWheels] #1068785
09/04/11 10:38 AM
09/04/11 10:38 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Cool deal, I understand when life get's busy.
My black 74 with 340 in it sat from 1987-2003. I did start it a couple times a year and kept straight race gas in it for storage. It has lot's of stabilzers in it. Then have driven it lot's since then all over the country as we take on vacation and use as a driver being towed behind our RV.
Just recently did it start to act up at idle. Yesterday I pulled the carb off of it and plan on rebuilding it today as soon as I get home from work. Every time I drive my old cars it allows me relive a little of my youth!!
Good luck with yours and enjoy!!
Re: Parked it 12 years ago......Fired it up yesterday [Re: HelleOnWheels] #1068786
09/04/11 12:07 PM
09/04/11 12:07 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
Troy
Houston Mopar Connection Club
Re: Parked it 12 years ago......Fired it up yesterday [Re: HelleOnWheels] #1068787
09/04/11 12:24 PM
09/04/11 12:24 PM
My Garage / Museum
idrivevintage Offline
Chrysler Plant
Chrysler Plant
My Garage / Museum
Nice looking r/t...dig the color
Re: Parked it 12 years ago......Fired it up yesterday [Re: cdp] #1068788
09/04/11 02:13 PM
09/04/11 02:13 PM
Oahu, Hawaii
P
ParadiseCuda Offline
P
Oahu, Hawaii
Would that be trans-x stop leak? Which of the lucas products transmission fix or conditioner?
Re: Parked it 12 years ago......Fired it up yesterday [Re: idrivevintage] #1068789
09/04/11 04:35 PM
09/04/11 04:35 PM
FL
FL
It has been this color since sometime before '91, but the fender tag says it was originally an HH1 dark copper metallic car. Can't decide if I want to put it back to original color because I like the poly red metallic color that it is right now. Decisions, decisions........
Re: Parked it 12 years ago......Fired it up yesterday [Re: HelleOnWheels] #1068790
09/04/11 06:01 PM
09/04/11 06:01 PM
MO
cdp Offline
cdp  Offline
MO
I think trans-x is a stop leak/conditioner. My experience is that when our mopars sit for extended amounts of time, the front seal dries up and leaks real bad.
I've had this happen on a couple of cars. Added the trans-x, drove for a while, and it never leaked again.
Re: Parked it 12 years ago......Fired it up yesterday [Re: cdp] #1068791
09/04/11 09:28 PM
09/04/11 09:28 PM
MAIne
MoparABE Offline
MoparABE  Offline
MAIne
cool
Re: Parked it 12 years ago......Fired it up yesterday [Re: MoparABE] #1068792
09/05/11 01:03 AM
09/05/11 01:03 AM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Cool R/T!!
Re: Parked it 12 years ago......Fired it up yesterday [Re: cdp] #1068793
09/05/11 01:12 AM
09/05/11 01:12 AM
Oahu, Hawaii
P
P
Oahu, Hawaii
Thanks cdp
Re: Parked it 12 years ago......Fired it up yesterday [Re: LimeliteAero] #1068794
09/05/11 04:54 PM
09/05/11 04:54 PM
FL
FL
Here you go...........
Re: Parked it 12 years ago......Fired it up yesterday [Re: LimeliteAero] #1068795
09/05/11 04:56 PM
09/05/11 04:56 PM
FL
FL
It sounds pretty darn good for not being fired up for the last 12 years!!!
Re: Parked it 12 years ago......Fired it up yesterday [Re: HelleOnWheels] #1068796
09/06/11 12:00 PM
09/06/11 12:00 PM
Bloomington, IN
HoosierTA Offline
HoosierTA  Offline
Bloomington, IN
Easy decision- if you leave it the color it is, you can DRIVE IT NOW!
'70 Challenger R/T 383
'16 Hemi Durango SSV (work vehicle)
'15 Ram Police SSV
Re: Parked it 12 years ago......Fired it up yesterday [Re: HoosierTA] #1068797
09/06/11 09:05 PM
09/06/11 09:05 PM
FL
FL
That isn't even a question.....I would drive it in primer gray at this point!!!! I have an itch and it needs to be scratched
Re: Parked it 12 years ago......Fired it up yesterday [Re: HelleOnWheels] #1068798
09/09/11 02:09 PM
09/09/11 02:09 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
Very cool story! I'd love to have a '67 R/T.
Re: Parked it 12 years ago......Fired it up yesterday [Re: Blues_Cuda] #1068799
09/09/11 07:08 PM
09/09/11 07:08 PM
People's Republic of Kali
70runner Offline
70runner  Offline
Nice ride! I think you were pretty fortunate that it started up after sitting that long. A neighbor bought a survivor 69 Charger RT (440 auto) after it had sat approx 8-9yrs, stored inside. There was a big dent in the orig gas tank so we replaced it. The orig owner had actually used the car for off road camping trips in the 70s. True story - I've known the orig owner for 35yrs. Anyway, the muck and grime inside that tank was unbelievable. Had we tried to start it, well, it wouldn't have been pretty. Had to get the carb rebuilt also.
Of course this is California, land of crappy gas and tuition support for illegal immigrants.
Re: Parked it 12 years ago......Fired it up yesterday [Re: HelleOnWheels] #1068800
09/09/11 07:14 PM
09/09/11 07:14 PM
cataclysm80 Offline
cataclysm80  Offline
Nice car & story I'm local also,... DeLand FL.
The Turkey Rod Run is a HUGE show at 5000 to 6000 cars. If your car is ready in time, you should deffinately go to Mopars with Big Daddy at the Don Garlits Drag Race Museum over by Ocala on November 5th & 6th. It's easy to get to,... Take Hwy 40 from Ormond Beach west to I-75 in Ocala, then go south 11 miles. Should take you about an hour and a half to get there. Easy drive, straight shot, not much traffic except other old mopars. It's about 1/10th the size of the Turkey Rod Run, which still makes it a pretty big show.
If your car isn't quite ready in time for the Garlits show, Go without your car. You'll still have a blast.
Tav
Re: Parked it 12 years ago......Fired it up yesterday [Re: cataclysm80] #1068801
09/09/11 09:38 PM
09/09/11 09:38 PM
FL
FL
I would love to try and have it ready for the Ocala show. That would also give me a trial run to tweak anything before I go to the Turkey Rod Run. I am not to excited about the thoughts of breaking down while driving through a crowd of 3000 people and trying to fix it as a crowd gathers to watch:)
